Yea. The filter design on the 3.6 is dumb. It doesnt have a drain back valve causing an almost dry start every time.
EVERY F N TIME!
That's interesting. I had to put a zip tie to hold the headlight plug to 3 prong adapter in the factory wiring harness night before last. I thought I had a LED headlight going out. I have these in my JK & TJ. I really like them, if you decide to change yours.Well today was headlight repair day!!!! The LED's someone installed before I got it, the harness was loose.
Took more time to remove the grill than actually tighten up the harness. No pictures of this....
Then it was decal install time. This is did get pictures of.
The dog decals are of my ACD Andie and my Australian Shepard Bailey. The wife and oldest granddaughter got those for me.
https://www.amazon.com/dp/B0BJF3LR9N?tag=wranglerorg-20
The JK doesn't come with them, but you can add them very easily. Well at least on the 2012+. I think the only way they came factory with the 2012+ is IF it had the auto climate controls. They take about 5 minutes to add on the 2012+.Changed the oil, filter and engine air filter.
Does the JK have a cabin filter???? If so anyone got the part number??
I think the only way they came factory with the 2012+ is IF it had the auto climate control.
Weather was a bit milder today so changed my belt. Not too bad with one person. I found that the tensioner is much like a compound bow - once you get it to the limit its fairly easy to hold. Getting it there is a chore, though. I used my long breaker bar with an extra hunk of pipe!
Ok I am at a total loss now. Today I did:
New starter
New alternator
New serpentine belt
New plugs
New battery and grounding cables
New battery
My Jeep will still not start. It will turn on but if I try to start it, I get one click and the radio resets. I am also not getting power it seems to the ODB II port. Everything else works. Windows, radio, lights, etc. Just no start.
Check your frame grounds too.
Well if it was a TJ. I ain't hip on all the intricate things on my JK yet.
But still sounds like a ground issue.
