2012 Jeep Wrangler JK Rubicon
I have recently noticed that when I turn my ignition to the ON position, the battery light stays on and that’s when the vehicle will not start unless I take it out, crank it ON again, and then the battery light disappears and is able to turn the engine on. I’ve tried two different keys as well. Maybe it could be the ignition switch inside? I have had the battery tested - they said it’s still good, voltage is good, etc. I’ve attempted exchanging the PCM relays and others with new ones just to see if that would make a difference. Nothing. Has anyone had this issue?
