I have an 07 JKU 6-speed manual 2WD and the weirdest thing happened the other day. While driving I had the airbag light come and then go off. Then several other lights came on at once and went away. The head unit turned on and then off and on.
I checked the battery and tightened all the connections at the battery. I even took terminals off and cleaned them. Since I have only owned it for 9 months I did look at the battery sticker and the battery is almost 5 years old. I have a ton of aftermarket electronics on this Jeep as well.
With all this info, can you help point me in the right direction or what do you think it might be? I thought it might be battery but everything is tight and the Jeep is firing up fine. Thanks in advance.
