Had to do an unexpected 5 hour round trip to pick up my daughter 4 days earlier than expected (her finals were mostly cancelled or exempted, and she now only has one to do online), but I was able to meet up with a lady selling this…
This fits nicely and will help with the “look like it came from the factory” part after all is said and done. This is OEM Mopar PN# 53013789AA, coming from any Jeep with a 5.7L from 2005-2010.
I hate engine covers, but I'm not gonna lie that one is pretty sweet.
I'm generally in agreement - but I saw this one and really liked the shape/style (the GC versions are slightly different than the car styles)... then the fact that it says "JEEP" on it sold me. With a little silver touch-up paint on the "HEMI" raised sections and then some engine detailer, it should look good as new. For $40, if I don't like it, it becomes a cool wall hanger :)
Reactions: WSS and tJKrider
Prepping for my front locker and future accessories, I figured that while half the engine bay is apart and since I'll need to run new battery cables in the near future, it makes sense to start thinking about wiring. Truth be told, I have already started working on wiring, but ran into a few snags. Before I started my build thread, I picked up a Painless "Trail Rocker" off someone nearby selling it on Facebook Marketplace:
I like it because it seemed to look "factory" and took common Carling Contura Rocker style switches. It also supported up to 8 switched devices, not that I would likely ever need that many. It even has the option to switch-control a winch via some pre-wired controls (that are there but tucked away). Anyway, long before I even did the lift kit, I tried fitting the relay box where it was supposed to be mounted.
According to the instructions, and the Painless technician that I spoke with, this is supposedly exactly where it needs to go. Unfortunately, the mounting bracket isn't even close to fitting, and the rocker prevents the hood from properly closing. I spoke with the Painless tech many times and came to the conclusion that they were going to essentially be zero help with this issue. Knowing I was going to do the Hemi swap anyway, I figured it wasn't too much to get worked over and I would figure it out at a later time. Well, it's now "later"...
Unfortunately, with the Hemi, and due to the height of the relay box itself, there's no way this Trail Rocker is going to work for me. Thinking about it more and more, I realized that I would probably prefer a pillar-mounted switch setup anyway. In my TJ and LJ, having the locker and light switches down low were hard to reach (depending on shifter location) and even harder to see. So with that in mind, I'll be putting the Trail Rocker back on Marketplace and am working through my future setup.
I ordered Rugged Ridge PN# 17235.56, their pillar switch pod specifically for 07-10 Jeep JK's. It generally gets good reviews and seems to be mostly out of my way, while being completely in reach (I did do some test "presses" while being firmly cinched back in the seat in my daughter's Islander!). I really only need three circuits at the moment (front locker, off-road lights, rock/area lights), with a fourth being optional for future changes (I would still like to potentially run a UD60 rear if I can find one reasonably priced, so I would need one for the rear locker too). The pillar pod comes with the cutouts in place, so I can "install as I go" and not have an ugly open spot or dead switch in the meantime.
For relays, the Trail Rocker seems like super nice quality, but as I said, there is just no way it is going to fit under the hood without hitting something. So, in my attempt to find a good alternative, I remembered seeing some people use the MSD "solid state" relays for their hot rods. I did some digging and the MSD 4-Channel Relay Module #7566-4 is highly regarded for its ability and reliability in handling four 40A circuits. I don't need nearly that much, but if this thing can handle that much juice, it's likely well made and long lasting.
The only accessible place I will have to mount this is likely right over the ABS module. Barnes4x4 sells a mount designed for the ARB Dual Compressor setup. This seems like it would work, though worst cast I may need to clearance it a little around the J8 setup.:
A company called Rain Rock Offroad also sells something similar, which I found randomly posted on Facebook. They can make this out of aluminum, but the response time from that company is slow. Still, I do like the simple design and if they can't supply it, I may just end up making it myself:
I did a parts recon and it looks like I need to order a few DT connectors and 18AWG pins, but thankfully I mostly have everything I need for wiring, loom, clips, and more.
After what feels like a month, my KBD flares showed up!
I took an hour or two before making dinner to get them installed. Yesterday was one of the coldest of the season so far, so when I saw that they got delivered, I threw them in the garage next to the heater. This certainly helped with the installation, which itself was really easy. Push in the plastic clips, then screw the flares to the Jeep.
Overall I'm really happy that I went with these flares. They're simple, follow the body lines really well, and won't cause any issues with rust. They also seem really unlikely to get ripped off during wheeling trips. I hope they hold up well to the sun and weather. I may, depending on how they hold up, paint them at some point. I have seen where people have had a hard time painting these, and let's be honest - this Jeep isn't a show stopper - so that is a big "maybe" at this point.
As you can clearly see, these don't cover much, but hopefully they keep at least SOME stuff from getting on the windshield in the winter. My LJ had a variety of flares and winter driving was the worst part about running "skinny" flares.
Well - I fuc%ed up...
2007-jeep-wrangler-jk-rubicon-2dr-4x4-jcr-s-project-crusader-07-1a4ddc34-1755053899243.jpg
2007-jeep-wrangler-jk-rubicon-2dr-4x4-jcr-s-project-crusader-09-e9990fd6-1755053895927.jpg
2007-jeep-wrangler-jk-rubicon-2dr-4x4-jcr-s-project-crusader-14-a21c8b69-1755053896633.jpg
I stumbled across JCR's "Project Crusader" and then Offroad Power Products "Ultimate JK Build", and now I want to build a 2-door JK with a Jeepworks JKL kit next (well, next-next... my son is heart set on doing a STI/WRC replica project for him next) :ROFLMAO:
On an unrelated topic/update, I was pleased to find out that the generic "firewall boots" commonly sold on Amazon fit perfectly inside the clutch slave cylinder hole in the booster/firewall plate:
That should make running the wires to the relays considerably easier! Speaking of running wires to the relays, I have always been a big fan of using DT connectors for this. I dug through my stock and apparently I must have used up a bunch of stuff on my LJ and forgot to restock the connectors. As I started adding things up, it just made sense to order a new "mini kit" from Deutsch Connector Store (my go to!). I got the last one in stock:
I've used the "ProWireUSA" kits a handful of times and they're CONSIDERABLY better than the ones off of Amazon (which break nearly every single time I've had to disassemble one).
The Mopar A/C kit came fast and I got it mocked up. Now I've gotta find a belt that works for this... the 2012 Challenger setup takes a 2100mm/820K6 belt but that was just a smidge short. I'm guessing this is because the PSC pump and pulley size is a bit off of the original size and location.
Some more good news - some of the hard parts for the Jeep Speed Shop Hemi Swap kit have shipped!
Timing wise this is excellent! I really need the motor mounts and steering shaft relocation parts to show up. This will let me keep moving and cross off some other items that need to be done, like finalize the J8 Booster & Master install, which will let me be able to start working on the wiring stuff. My hope is to get the brakes buttoned back up, steering reconnected, and the engine test-fit the week between Xmas and New Years when I have some time off...
The car I lusted after for a long time. 1998 22B:
That's a sweet one! My son, much like me (and totally independently, as his fascination with turbo AWD cars is somewhat new) loves everything about the 2004-05 STI S10 WRC:
Those are hard years to find in decent shape, and especially at a price I'm willing to spend on a 16 year old's first car. We did find a 05 STi "replica" that was a decent option, but it needed a good bit of engine work (to make reliable) AND body work (no rust, but faded paint, flaking clear coat, lots... LOTS of random dents and dings, etc.). I'd rather find one that has a clean body and blown up engine (easy with a non-STI!) that we can build something fun for.
There are a couple of Hawkeyes in the area that pop up so I'm slowly trying to convince him that they might be a better option. We found a white-on-black one in NJ that would be a good option. It has a "Rebuilt" title due to a deer strike, but the guy supposedly has the receipts and photos of everything, so I am not hesitant about that (and it's priced accordingly). It's also a true STi and adult owned its entire life.
Right now we are casually looking but if a good deal pops up we'd buy it and park it at my friend's mom's house (she has a detached garage on her property with 1/4 of asphalt and nothing nearby!). We will likely get much more serious once my Hemi swap is done, and at that point we'll have the garage open to start working on something.
  • Love
I've got about a half dozen "mini" projects underway (which drives me nuts but also keeps my ADHD brain happy), but with parts in the mail, it's the only option I have to keep moving along with the project.
I confirmed fitment of the Rugged Ridge pillar switch mount. Despite how it looks in the photo, it does match the interior quite well and I really like the position of the switches from the driver's seat.
I'm not sure why these things don't come with all the holes punched out and with little "plugs" in place, but this was such a pain in the a$$. It took me about an hour to get the holes properly cut out and trimmed. I just need to figure out what style switches I want. I'm leaning towards the typical Carling-style switches with the descriptive text laser etched on the surface.
I will likely need to "massage" the firewall a bit and since I'm not a fan of fiberglass dust all over my face and garage, I removed the insulation (aka "silencers") from the trans tunnel and firewall. As you can see, the passenger side has a bit of damage, and the passenger side heat shield is missing.
You can see how much material is missing on the passenger side when it is off the Jeep. The left and right sides are supposed to match (for the most part).
The part is still available, but is NOT cheap. I found some good prices on eBay and after going back and forth with myself, I decided to skip the generic insulation and go with the factory pieces.
The parts are Mopar Silencer Floor Pan Front Tunnel 2007-2010 OE 55361340AC (#15 in the diagram below):
and Dash Panel Silencer - Mopar 55361339AE (#12 below):
I saw that someone suggested removing the ABS/ECM tray to install the J8 Booster and Master Cylinder (to make alignment easier and reduce the risk of damaging the master). My washer tank has been leaking since last year, so I needed to replace it anyways. Seems like a good time to be doing all of this. I got a good deal on an OEM Mopar replacement from Quadratec, so in the meantime, I pulled the old one and strapped the ABS pump out of the way.
I had the grinder out to prep the frame for the Hemi mounts, so I spent ~15 minutes getting the upper control arm mounts cleaned up and trimmed. This isn't "required" per JSS, but it was required for the old AEV Hemi Swap conversion, which the JSS kit shares much similarity with. I'll be using the JSS headers, but having some extra space and clearance down there isn't a bad thing...
Once the UCA mounts were trimmer, I marked and then took a flapdisk to the frame where the JSS mounts attach. A few minutes of clean up and beveling of the mounts themselves and I got them all tacked in place. The passenger side mount didn't want to sit as flush as I wanted, so I ended up tacking it at the bottom, and then used my floor jack and a 4x4" to leverage it upward...
The Speedway Motors Hemi lift plate I ordered was originally shipped to me incorrectly made. I shipped it back and have been on backorder since Nov 29th. It's still on backorder, so I ended up cancelling that and just ordered the Summit Racing lift plate. This will let me get the engine test-fit this week...
I got the J8 Booster and MC bench bled (twice!) and installed. I left the lines disconnected for the time being to allow me to get the ABS pump and inner fender back in place.
I temporarily installed the new Mopar washer-tank/ABS tray. This allowed me to mock up the Rain Rock Offroad accessory tray. Unfortunately, as you can see below, it is clearly designed for the 2011+ inner fenders. I spoke out to the owner of RRO and he confirmed that he indeed never tried these on an earlier rig (it was mainly designed as a vacuum pump relocation + Spod mount) and he didn't realize that they were differently sized.
It's not the end of the world and although I paid a premium for a "direct fit", a piece of flat 1/8" aluminum and 20 minutes of playing around should make this super easy to make work. Overall, I like the design, and having the small adapter piece may make tweaking fitment, and removal, easier (perhaps I'll weld a stud to the adapter and use a wing nut).
Since I was waiting for parts to arrive and was already "thinking" about wiring needs, I spent some time trying to figure out where I can place some rear-facing lights. The obvious, and commonly used location, is the "utility mast" on the AEV tire carrier. My concern is that the tire will block too much of the light. As you can see below, even the small-for-its-size 37" will block a good bit of it.
The post offers a very secure mounting option. Perhaps I can make a "riser" of some sort, or even some sort of "T" or "wings" that mount the a pair of lights to the sides of the tire.
I really like the size, shape, and light pattern of the Rigid SR-Q lights, but they're overpriced IMO (and I rarely find them second hand).
Rigid has some "Revolve Pods" on clearance at the moment, so I may pick up a pair or two and see if they may be useful. My concern is overall light output, but if I'm limited on what I can install on top of the utility mast, two smaller pods on the side may be really handy. I don't want these as backup lights, but rather "utility" lights when out at night and unloading or doing something like hooking up a trailer.
After fiddling around with motor mount orientation and location, the Hemi fits!
I used a set of motor mounts from AutoZone, PN#3277 and #3243. The fitment is from a 2009-2010 WK2 with a 5.7L. AutoZone.com shows that #3243 (the longer mount) is for the "Front right" (passenger side). However, Liz from JSS confirmed that the long mount is indeed for left/driver side. Oddly enough, when I looked up all the motor mount options at AutoZone, it shows a Marmon-brand mount that appears to be the long-mount, though it lists it as the "Front left".
When I originally tried setting the motor in with the mounts based on the AutoZone orientation, the fitment wasn't even close and the motor was tilted down to the driver-side by about 5°. However, once I flipped the mounts it was night-and-day different and fit perfectly.
"Long" mount, installed pointed down, on Driver Side
Short mount, installed pointed down, on Passenger Side
With that confusion cleared up, clearances and level checked, I started to take note of a few things. I'm still waiting on some hardware to be delivered so that I can fit/modify the A/C compressor (needs to be clearanced for the PSC Big Bore):
While waiting on hardware, I went ahead and cut the OEM heater hoses. The AEV Hemi Swap kit has a real good diagram about where to cut the hoses. I will likely replace these 209,000+ mile hoses before final install (though these "feel" much newer) but at least it helps confirm fitment and where to cut when I do.
Next up:
- Pull the motor back out and burn these mounts in 100%, then throw some paint on the frame rails...
- Get the 8HP70 on the bench and pull the TCM out so it can be sent to JSS for reprogramming
My local powder coater, Route 247 Powder Coating & Sand Blasting, did an amazing job on my JSS brackets and parts:
Since the shifting on the 8HP70 is all done electronically, the OEM shifter gets removed and replaced with either a Charger or Challenger shifter. I found a 2016 Challenger shifter on eBay for a good price, complete with leather boot and illuminated shifter handle. I'm going to bring my floor plates to the powder coater as well. The time I'd spend cleaning them up and putting some paint on them isn't worth the $100 to get them blasted clean and coated.
I had to clearance the A/C compressor mount to fit the PSC Big Bore (I'll update the Hemi swap page shortly), but thought I'd share just how tight this is. The Hemi swap is quite literally a game of millimeters! I think PSC sells a smaller, 4.5" pulley, that I may end up swapping to depending on how everything falls once the transmission is in place.
That's ~1/4" between the pulley and steering box:
Reactions: Artisanau
The motor mounts are all welded up and painted...
So I turned my attention back to the Rugged Ridge Switch Pod. I got the switches off of eBay and ordered a set of the back panel clips with terminals to make life easier. I always get worried about Chinese/eBay/Amazon terminals, but these actually seemed to be decently made and held the wire and insulation well, with no cracked ends (using a proper crimper helps I think).
I will probably order a set of custom, horizontally laid out switch covers at some point, but for now, these are good. The icons light up when activated, and the text lights up with the illumination circuit coming off the radio adapter. The small switch at the very top is my "locker circuit activation", meaning the "Front Locker" switch itself does nothing unless the top switch is also armed. Not a fail safe, but will prevent me from accidentally engaging the locker at speed when I meant to engage the off-road lights.
In order to maintain quick and easy serviceability, all the wires from the switch pod come down the side of the dash, into an 8P DT connector.
I didn't realize just how low the factory upper Jeep trim piece came down over the switch pod. I simply notched out the switch area a little and it works fine. Actually, the little notch sort of shields the switch, preventing accidental "swipes" as well. The next time I'm working on interior stuff, I might pull this piece back down and square up the notch with the switch face, rather than square with the edge of the piece itself.
I found some 1/8" thick, closed-cell marine foam on Amazon:
All the reviews on Amazon talk about how sticky the adhesive it (I can confirm!) and how well it holds up. It's more rubbery than foamy, which is exactly what I wanted. I cut out a small piece and stuck to to the front side of the steering block relocation bracket. Since the OEM steering block has a seal and will seal to the relocation bracket, my hope was that the foam would duplicate that seal against the firewall. It seemed to work as intended, so hopefully it holds up long term. I certainly don't want to be replacing this with the engine and steering column back together!
Here's a shot of the relocation bracket as installed, from under the dash:
Here's the view from the engine compartment side - you can see the black foam around the pillow block. This is essentially exactly as the OEM seal works, though obviously not as large...
Reactions: Cimmerian
The shifter and e-brake floor pans came back from powdercoat. The first step was to glue the tub seal back into the bottom. I think the OEM seal used some self adhesive tape of some sort, but the Gorilla Clear Grip worked out great for gluing back in.
I took apart the T-case shifter and cleaned out all the bug bits and grime. I also wiped down the floor boards with mineral spirits and it helped get a bunch of the sticky, goo-like unknown stains off the sheet metal. With the floor sufficiently clean, I reassembled. You can see the Challenger shifter in place of the OEM shifter. It's very "car like". I don't hate it, but I will likely consider finding a Gladiator version at some point.
It's OEM looking and completely functional, so thumbs up across the board...
From a positional standpoint - in "park", the shifter is barely above the reach of my fingers sitting in my normal driving position. A small lean forward puts it firmly in hand, which is nearly identical to the OEM shifter handle location (I double checked on my daughter's Islander)... #GOBILLS
With the shifters installed and out of the way, I went back under hood to make some progress on the driver side inner fender. I still needed to make a bracket to connect the accessory mount I bought to something solid. I loosely bolted everything back together and then mocked up a bracket on some paperboard, then transferring that to some 1/8" thick aluminum.
Similar to how it would on the 2011+ JK's, the bracket ties into the ECM mounting bolt. I need to find a smaller screw but this is what it will look like when installed fully.
There's a lot of real estate on this, so I may try to keep it offset in case I want to put something else up there.
There's a lot of clearance with the hood, so I won't have any worries about pinched items or too little airspace.
One thing I noticed when I got the inner fender completely reassembled is how the ABS wiring is run. It's going to get damaged when run like it was before the J8 booster, so I'll tinker with this some more in the coming days.
After seeing @Hogges post about his heater core issues, it reminded me that I should tackle mine while I have it all torn apart. When I first got my JKU, the heater sucked on the driver's side and had a smell of mouse poop. I cleaned out all the nest material and rinsed it to high heaven. I got the smell to go away, but the issue with the no heat on the drivers side remained. I saw so many reports about blocked heater cores that I gave it a thorough flush with the garden hose (also did a coolant flush at the same time since it was disgusting looking). The flush helped, I did get slightly more heat on the driver side but it was nothing like my daughter's 2010 JKU that will literally cook me to death if I let it!
Fast forward to my current efforts. I've seen a lot of people use chemical flushes of various kinds and almost all of them had good success. Hogges also mentioned a fancy hose attachment that lets you purge and flush the heater core with not only a garden house, but also some metered compressed air. With the engine out of the way and me still waiting on some parts, I ordered the Lisle nozzle adapter and some other DIY flush items, and got to work...
A lot of people who've done this "pump flush" style clean out use an external, transfer-style pump. In my head, and maybe because I've had a few fish tanks over the years, a submersible pump just made more sense to me. I found this CreekStone pump for sale at Harbor Freight for $20 and picked up the jug of CRC Evapo-Rust while I was there. The 5/8" hose is just some clear vinyl tubing I got from the local hardware store.
I did a quick proof-of-concept test with some warm water and a drop of dish soap (to reduce surface tension), and much to my surprise, after only ~15 minutes of run time, I was already getting a bunch of particulates in the bucket! Keep in mind, I did a thorough flush, frontward and backward, in Nov of last year when I did the coolant and radiator flush.
Once I was happy with the setup, I wanted to do the mechanical flush first. I hooked up the Lisle handle to my hose (which I can run with hot water, ~135°F) and air compressor, and then flushed ~5-gallons through, alternating between water and air bubbles (as instructed by Lisle's packaging).
I ran that container of material through a coffee filter and found not only a bunch of grit, but also a lot more aluminum flakes than I was expecting, plus what I think is the "jiggler" from a thermostat.
After the proof of concept and first mechanical flush, I set the pump bucket back up and ran the full gallon of Evapo-Rust (plus just a small amount of water to keep the pump fully submerged).
I ran the pump for about 3 hours, then let it sit for about 3 hours, at which point I drained all the Evapo-Rust that I could, and then repeated the mechanical flush using the Lisle flush handle. Some more material came out, at which point I switched back to the Evapo-Rust flush and let it run for about 3 hours, before turning off for the night. I turned it back on first thing this AM and saw a bunch of particulates come out as soon as I turned the pump back on. I'm going to rinse + repeat this as much as I need to until I don't see any more grit coming out... I really want this to work, as I do not want to tear the full dash apart in the spring, so I don't need to "rush it" at all.
Reactions: tJKrider and Hogges
Thanks for sharing this radiator core flush method. I may give it a shot next time my daughter comes home and temperatures are above freezing. I hadn’t really been able to remove the thermostat and really flush all parts of the coolant system in this last attempt, due to approaching single digit temperatures, so there is a good chance that remaining debris got flushed back into the heater core.
Very cool build threat, by the way! Thanks for tagging me to find it.
Reactions: tJKrider and pc1p
What I thought would take an overnight soak ended up taking ~3 days of pumping/recirculating to finally get all the grit out of the heater core. I would pump the Evapo-Rust for ~3-4 hours, let it sit for ~3-4 hours, then mechanically flush with the Lisle flush nozzle. Each and every time I would get a good number of black deposits into the flush bucket...
I would drain the water and feel the particulates. It was certainly rust, in a very fine powder form that was aggregated together into small bunches. Every rinse had essentially the same amount. I ended up, on the 3rd night, letting it pump continuously for almost 15 hours. Finally, at that point, the flushes had a really small amount of particulates but they were barely visible, only able to be spotted floating on the edge of the water-bucket line. I figured the majority of the particulates were gone at this point since there wasn't enough for them to flocculate together.
I drained and flushed the core once more, then pumped a dilute 10:1 solution of hot water and Simple Clean (degreaser), roughly for about an hour. I figured any organics remaining in the core would be taken care of, plus the surfactants in the degreaser would help get any remaining particulates up and out of the core. At that point, I did 4 "rounds" of mechanical flushing (1 round = filling a 5 gallon bucket and observing for particulates). I alternated the flush direction, just to make sure nothing was getting missed, and viola! - clean rinse water.
With the heater core finally done, I had a perfectly timed delivery - my TCM came back from JSS, allowing me to fully reassemble the 8HP70...
Before I can drop the engine into her final resting place, there were a few things left that needed to be tackled. First was getting the rest of the (grinder) grit and grime off of the firewall and frame rails. Although I power washed the heck out of this thing before starting the swap, there are always spots you miss with things in the way. Throw in the grinding work to get the Hemi motor mounts in place, place clearance the control arm brackets to fit the headers, and I'm really glad I was able to get this scrubbed up. In a near miraculous instance of timing, Mother Nature gave me almost two full days of mid 40° temps. My son and I pushed the JKU out of the garage and got to spraying, scrubbing, and rinsing:
With the firewall and front end cleaned up, I was able to install the new firewall insulation, which then finally let me install the new steering shafts. I had ordered these from PSC during December and they've been sitting in a box every since. I don't know if it's because the lower shaft has been sitting still for so long, but it was even stiffer than it was when I first pulled it out. The upper joint is so hard to move that it actually pinched by finger trying to unjam it. I'm hoping this translates into even smoother steering and better feel.
Firewall insulator on and steering shafts in place, I reassembled the rest of the driver-side inner fender. I had previously run into some tight quarters with the ABS wiring alongside the new J8 booster and master cylinder. After bolting everything down snug, I was able to route the ABS harness in such a way that kept the wires clear. It necessitated drilling a 1/4" hole and using a stud-style zip-tie . You can see it below here:
I added another stud-style zip tie on the other side of the master, as the original one was no where near where it needed to be. On the bench, the J8 doesn't appear much bigger than the OEM JKU booster and master. However, you can see below just how much further forward the J8 master cylinder ports are compared to the OEM one...
Everything in place and I'll be able to hook up the brake lines today and then drop the engine and trans in this weekend...
Those of you with ADHD will understand the joys of a good "side quest". I was itching for something to do, but didn't want to jump into hoisting the engine/trans just yet. Instead, I crossed off a "future to do" - the door hinges. Opening and closing the doors has always required significant and conscious effort. The hinges often squeaked and it was generally a pain in the a$$ (except when parking on a hill when the door stayed open for you lol).
I bought these liners when I first got the Jeep but have been unable to get the doors off the hinges, no matter what I did or how much I tried. And boy did I try - I used heat, spray lubes, worked the door back and forth a thousand times, used jacks, air chisels, and more. Nothing could get more than a millimeter of separation at the hinges, in particular the front passenger door (the hardest one to open and close). Then it dawned on me - why not just remove the hinge from the door and see if that would help?
Sure as can be, that did the trick! I was able to use my 1/2" drive Torx impacts on my "Mid Size" Ridgid impact gun and every single Torx bolt came free without stripping a single one! On the passenger side, both sets of OEM liners came out with little issue. On the drivers side, both doors, I actually had to use a small flat-head screwdriver to chisel out the liners and separate it from the barrel of the hinge. I was then able to use the pin punch to get it the rest of the way out.
You can see in this one, there appears to be a plastic liner inside the factory liner. I don't know if this is factory, but clearly it didn't work as well as intended...
From all the jacking and pounding since originally trying to get these out, I will need to do some door adjustments in the summer. I moved a couple hinges in the meantime to get things to open and close smoothly, but I think I can get all the door gaps to be perfect with just a few minutes of tweaking. For now, the doors open and close with ease, and they all come off the hinges with ease. There's a lot of bubbling and corrosion under the paint, so I'm likely to replace these with some new ones at some point. Admittedly, finally getting the full doors off has finally inspired me to start looking for some OEM half-doors as well for summer driving...
It is a curse! But gets things done.
You managed way more room than I thought was possible on the ABS harness. All said, the booster swap is more than worth it.
Reactions: Cimmerian and pc1p
