JKU Hemi Swap - Reference Guide & Swap Info
pc1p
Hills of NE Pennsylvania
Introduction & Hemi Basics
If anyone has ever spent time on the Wrangler TJ Forum, you may have seen my Gen III Hemi swap info there. I figured since I'm going through the work on my JKU, that it just makes sense to do that here as well. There are plenty of YouTube videos, some done by vendors selling swap parts (such as Jeep Speed Shop, which is who I'm primarily sourcing my part from), and some done by people trying to help others out.
Some worthwhile videos to check out:
JKB Off-Road: https://www.youtube.com/@JKB_OFFROAD_olllllllo
JK Gear and Gadgets: https://www.youtube.com/@JKGearandGadgets
Jeep Speed Shop: https://www.youtube.com/@jeepspeedshop
While I love YouTube videos, and I may even make a few of my own in those instances where I think other videos may fall short, I think there's a lot to be said of having a step-by-step forum post that can be referenced, corrected, and added to as needed. I'll be building this thread out as I go through my swap, where I'll be putting a 5.7L VVT LX Hemi and 8HP70 into my 2008 JKU. I'll have some info about the Hemi swap in My Build Thread, but the bulk of the technical information, references, and more, will be saved here for future easy reference by myself and by anyone else who needs it.
If there's something I glossed over or something you want expanded up, just let me know!
What is a Hemi?
The Gen III Hemi ("gen three", or generation three), is, as the name would suggest, the third iteration of the Mopar Hemi engine. In 2002, the Gen III Hemi was debuted in the Ram 2500/3500 pickup line, followed by the Ram 1500's in 2003. It boasted 345 hp and 375 lb-ft of torque and was immediately recognized as an excellent engine platform (it has made the "Ward's 10 Best Engine" list six times). By 2005, the 5.7L Hemi was available in pickup trucks as well as the LX-series of Chrysler-family cars.
Some say that the Gen III Hemi, commonly short-handed as the "G3" to help differentiate it from the Gen-III GM motors, is not a "true" Hemi since it doesn't have a traditional hemispherical head design. These people usually eat their own boogers and think that boys shouldn't be allowed to play with dolls. Ignore them, you don't need that negativity in your life... :)
Much like the GM and Ford counterparts, the Gen III Hemis took advantage of engineering and computer-aided design advancements. As a result, the Gen III retains a traditional push-rod orientation but with significant flow improvements over the previous Gen II V8 engines (such as the Magnum).
In 2009, the 5.7L Hemi received some major internal changes and an even larger use of technology. The block was new, the crank was upgraded, the cylinder heads were better and the cam got a tad more aggressive - all while sporting better power and economy. The 5.7L Ram engine - known as the "Eagle 5.7" was now rated at an honest 390 hp and 407 ft-lb of torque. Some people consider the 2009+ engines to be the "Gen IV Hemi", but this naming convention has not caught on. Most people simply refer to them as the "VVT engines".
The biggest change was the use of VCT - variable cam timing. The ECM can now vary the valve opening to optimize flow throughout the RPM range. The use of MDS - or multi-displacement system technology was continued but improved upon and matched with the VCT for significant gains in economy. It isn't uncommon for swapped rigs to push 18 MPG in Jeeps (when coupled with the Dodge transmissions).
Later Eagle updates also included a "SRV" (short runner valve), which is essentially part of the Hemi "active intake". This valve provides a bypass for incoming air and moves it from the plenum directly to the cylinder heads. The shorter route allows for more power at higher RPMs while allowing the nice long, wide torque curves of a traditional long runner.
What Hemi Should I Swap?
While some older JKU Hemi swaps indeed utilized earlier, non-VVT Hemi swaps, this has all but stopped. The VVT engines make more power, are easier to find, and are cheaper due to availability. There's no compelling reason to use a non-Eagle/VVT Hemi in a JKU swap.
That said, there are some considerations to be made for what platform you got your donor from. The donors are usually broken up into car/SUV, often referred to as the 'LX-platform" motors (not to be confused with LSx), and "truck-VVT" motors. Internally, all the engines are the same. The differences come on the exterior.
The 5.7L truck engines are often easier to find, and many include an 8HP70 if you're considering that swap as well. The truck engines have physically longer front end accessory drives (FEAD). Essentially, the water pump, power steering pump, A/C compressor, etc. all stick out further from the timing cover than car/SUV FEADs do. This means you are unable to run your OEM Jeep fan. You need to either run a manual fan, or go with the common "Camaro fan" (which is thinner profile than the Jeep fans).
LX (car/SUV) engines can reuse your OEM fan. 6.4L engines (from car or truck) must move the air cleaner to the driver side fender due to how the intakes are shaped on both. Any and all engines can be made to work, you may just need some different parts to make it all work together (more on this below).
Foreword – Considerations & Project Planning
Why Hemi?
One of the first things I get asked by folks is "why a Hemi?". One of the first things Jason, the person I just sold my old 3.8L to, asked me was "why not an LS?". It's a good question that for me, has a really simple answer: integration.
[2010 5.7L Eagle Hemi that I originally bought but ended up having a chewed up cam lobe... more on that later]
The LS is a great motor and has certainly helped paved the way for "modern HP" in many classics and swap candidates. That said, the LS in a JKU has a lot of headaches. Even @rockvegas555 has said that if he were to do another V8 swap, that it would likely be a Hemi, and he's got a 6.2L LS3 with 525 horsepower and 486 lb.-ft. of torque!
The Hemi is natively part of the Chrysler ecosystem and already uses shared CAN protocols, which are easily integrated with the OEM TIPM, and offers OEM-functionality with things like cruise control, EVIC, stability/ABS control, A/C request logic, cooling fan logic, and OBD-II. Compared to an LS swap, you often need to bypass several functions, often have to manually control A/C, may or may not have functioning cruise control, and more.
Aside from some of the integration headaches, the Hemi fits well (in particular the 2009+ VVT) and now has the option of the 8HP70/75 transmissions. With the exception of the motor mounts, a modern Hemi swap can be done with nearly 100% OEM, off-the-shelf Mopar parts.
Why 8HP70?
If you want the Jeep to feel modern, fast, strong, and factory V8-correct, the 8HP70 wins everywhere except cost and wiring complexity. While you can use the NAG1 if your JKU is equipped with one, it’s older, weaker, and has fewer gears, making it less ideal for heavy rigs pushing big tires.
[A low mile, 2019 8HP70 originally sourced from LQK with TC]
The Hemi-era 8-speed autos are incredibly strong, shift fast, and offer excellent on-road and off-road drivability thanks to well thought out gear ratios. The fact that they're offered in Ram 1500s for a number of years now makes them readily available. These can be picked up cheaply from nearly any parts recycler or yard. I only paid $500 for the one above and this isn't an uncommon find.
For me, while there is an added expense and wiring integration is a bit more involved, the advantages far outweigh the small expense and hassle. Again, going back to my point above, getting 3 additional gears, with OEM integration, that runs cooler, offers better engine braking, and gives lower cruise RPMs while also a better 1st gear ratio is, for all intents and purposes, a decision that makes itself.
Intended Use & Needs
When I started the JKU project, I had a modest, but critical list of criteria:
  • Overbuilt - always a long-time build approach, regardless of purpose, mainly because "I have to drive this home"
  • Reliable - if I am not confident enough to drive the Jeep across the country to Moab, I'm doing something wrong
  • Street friendly handling/manners - for sanity and in case the Mrs. needs to drive it for any reason
  • Ability to keep the Jeep "mostly" inspection friendly - PA requires annual "safety inspections"
The Hemi swap fits well into my overall needs and vision - a reliable, daily driver than can a tough weekend warrior.
[A cartoon rendering of an actual photo of my JKU, with some artistic tweaks made]
More importantly, it's something I will enjoy driving, which I can honestly say that with the 3.8L, was not the case. While the new axles I just built and installed in my daughter's Islander have helped, driving a rig around the hills of NEPA gets exhausting. The engine is always struggling and the transmission is constantly searching for gears on hills. Throw in the fact that it barely has enough power to maintain 65 mph while towing a small utility trailer is simply not something I would deal with for long.
Budget scope
I am fortunate in that I don't have a budget limit for this build. This does not mean that I'll be going full blown crazy and am going to slap in a HellCrate (well, not yet at least), but I'm making decisions based on value, and not necessarily on cost. That said, I will be keeping track of all the costs associated with this swap and will share the total when all is said and done.
Time expectations
Right now, I'm driving my daughter's Islander around and will do so until my project is done. She's coming back from college for the summer in mid-May, so that seems like my natural target completion date, though I would prefer to have it done much, much earlier. I'm targeting a first-drive sometime in mid-March. This will give me a few weeks to work out the kinks and will be late enough into winter/early spring that weather should hopefully not be too problematic should I need to do anything outside.
Full Parts List + Part Numbers
Todd at JSS has lots of BOM sheets on his site and updates them periodically. If you're doing anything but a LX-based engine and 8HP70 swap, you should head on over to his home page and find the BOM you need.
I am actually helping Liz (Todd's wife) update some of the BOM lists as there has been some confusion and I volunteered to help clean them up. I will update the link and document once Todd has a chance to work through these updates and give the thumbs up.
3.8L & Transmission Removal
Best practices
Since I'm doing my Hemi swap right after doing my D60/14B swap, my undercarriage was already fairly clean. Even still, I gave it a second blast of Simple Clean and hot pressure water before tackling the engine and trans removal. Remember, more often than not, an ounce of preparation prevents a ton of headache. Spend the time to get things cleaned, and preventing dirt, oil, and grim from falling on your face makes crawling under a rig much more pleasant.
[Weather can turn quick here in NEPA, so I power washed the Jeep as soon as I was able to wheel the rig back outside following the axle swaps]
I'm sure there are a million and one different ways people have done this, so I'll simply focus on what I did. Since I was snatching both the engine + trans together, I opted to remove my entire front radiator support before attempting to do anything else. Doing so allowed me keep the cherry picker much lower than I would have otherwise, which adds to the safety factor, while also allowing me to do this inside my garage (it was in the 40°s out there!).
There's no big secret in removing your 3.8L. Make sure you get your A/C system evacuated prior to starting the work, and then it's just a matter of draining the engine and transmission oils, then draining the coolant, followed by unhooking everything attached to the radiator and condenser.
[Draining the radiator via the petcock at the front, passenger side of the radiator]
After all fluids are drained, you disconnect the wiring connected to and around the grill support, securing the wires out of the way as you go. If you have a lot of grit and grim on the connectors, I found that a quick squirt of WD-40 helps loosen things up enough to make removal much easier (and less likely to damage the connector). There are a number of "cam" style connectors. They're all different but follow the same basic order of operations - you depress the safety interlock (often near or just under the "handle" of the cam), then you slowly and smoothly rotate the cam away from the connector. Doing so pushes the connectors apart and allows for full disconnect.
With everything drained, you can now remove the radiator/condenser as a single unit. You'll have to disconnect your transmission cooler lines from the factory cooler, which means you'll likely have some spills to deal with even with good catch pan placement. Use rubber or silicon caps, as well as metal drip pans and cardboard to keep your shop tidy. It's the small things, like having ways to quickly and efficiently deal with spills and drips, that make these steps go much smoother and overall make the process much less of a headache. Plus, with quick clean-up, you won't have to worry about lying in an old oil spot on your floor when you're putting this all back together.
[Fluids drained and radiator support removed]
With the radiator and condenser out, you can unbolt your radiator support and set it aside. Now that the front end components are cleared out of the way, you'll have lots of easier access to the rest of the parts that need to be removed. My driveshafts were already off, so next up for me was the t-case. The nuts at the top are a pain in the a$$ to get to. Thankfully I removed the transmission shifter some time ago (since I will be installing an OEM Dodge Challenger shifter for the 8HP70), which allowed me to reach down through the hole in the transmission tunnel to get to them easily. You may need to drop your driveline down some to get to the top nuts, depending on what you're doing for your swap.
When removed, set the t-case aside someplace safe and out of your way. With those items out of the way, you'll need to start removing the other stuff attached to the engine: exhaust collector to manifolds (I left the manifolds on the engine as they gave a good place to throw a chain around!), TIPM, battery, heater hoses, etc. Depending on the condition of your rig, you may want to hit many of these connector points with some WD-40 or penetrating fluid ahead of time.
You'll have to disconnect some of the large engine harness connectors at the firewall, but the harness itself can stay on the engine. I did remove the starter from the engine before removing, only because I was worried that it would get hung up during the removal on the frame mounts, but it appears that this was unnecessary as that section clears nicely.
[Me being not so limber and nimble, strapping the trans to cherry picker]
At this point, I used a scissor-style transmission jack under the transmission pan, and removed the transmission crossmember. There's really not much left once you get to this point. Run your hands back and around places as you start to lift the engine out to make sure you're not forgetting something. Take your time and ideally have a helper with you. An extra set of eyes really has an advantage, though you can 100% do this safely if you take your time and don't rush things. Once lifted, never put any part of your body below the engine or transmission.
Tips
I found it much easier to get the 3.8L out by removing the driver-side motor mount from the engine block. This let me slide the engine and trans forward, giving me lots of space at the firewall and trans hump. With the mount still bolted to the engine, you'll have to lift the engine over both of the engine mounts on the frame rail to get it to clear. This makes it very tight when removing the engine and trans together, as the trans wants to constantly get caught on the trans tunnel.
Tools Needed
Aside from the obvious way to lift and remove an engine and trans, you'll only really need basic hand tools for most of this. I can't think of anything off the top of my head that needed something special I had in the toolbox.
The one item some people may not have would be a fuel-line disconnect tool. I've had this AutoZone one for over a decade now and it worked perfectly fine. It also worked for the trans cooler lines.
[Fuel and trans metal line disconnect pliers]
Weight/Balance Notes
You'll be lifting out ~600 lbs of engine and trans, so overall balance and where you lift can be a safety hazard if not done correctly. I used some heavy duty chain that I made "loops" with around each of the exhaust manifolds. I used the transmission jack to support the transmission pan as we slide the engine and trans out together. Once I had enough clearance, I threw a ratchet strap around the transmission (between the back of the pan and 4wd extension) and connected that the main eye hook on the cherry picker. I took out the slack as space made it available, which helps "lift" the rear of the transmission. This made clearing the crossmember at the front of the frame much easier.
[Leo helping me slide the engine back as I work the ratchet strap]
What to save vs throw out
Item's you'll 100% want to save:
  • EVAP Purge solenoid (near your battery box)
  • EVAP Purge hoses
  • A/C compressor
  • A/C lines
  • Fuel Lines
  • t-case to trans nuts
The rule of thumb her is to save everything until you know otherwise. That said, I've already purged a few items I know I'll not be reusing, like the OEM airbox, air tube, etc.
Things to Photograph / Label
Honestly there isn't a whole lot of stuff you're going to reuse and when things go back together, it should seem fairly intuitive. That said, a few small zip-lock bags and a Sharpie is always a good idea.
Frame & Engine Bay Prep
Motor mounts
There are many companies that make new frame mounts to facilitate Hemi or LS swaps. JSS offers both weld-on style mounts and "bolt-on mounts". The former requires you to cut off your OEM 3.8L frame mounts, while the latter allows you to keep your OEM frame mounts in place. Both are good options, though the "bolt-on" mounts come at a much higher cost ($295 vs. $750) and make an even tighter engine bay even more so. They also require you to shave some accessory bolts down (e.g., the hold down for the oil dipstick, and the knock sensor mounting bolt), and they also make replacing the knock sensor impossible with the engine in place (not that OEM knock sensors go bad all that often). Not only that, the bolt-on mounts also limit what exhaust manifold/header options you have available to you.
Since I'm reasonably handy with a welder, I'm going with the weld-in mounts for my swap. This will keep things simple and have better clearance overall. Removal of the old mounts is fairly straight forward and can be done in less than an hour with an angle grinder and BFH.
You can see how I removed the old mounts later in this thread, post #23: Frame Prep: Removing the 3.8L Engine Frame Mounts
The weld-in JSS mounts are beefy and work with both Hemi and LS applications:
The difference between using them for an LS or a Hemi is how you align them. Todd has a video but it's kind of hard to see exactly what he's talking about as the video-quality looks worse than videos I've captured with my iPhone 3. Additionally, when you do a search on the JSS Facebook page, people sometimes use terms a bit loosely. As a result, I made these to help with those looking to use these mounts.
JSS doesn't provide any guidance on where to weld the brackets to the frame, so I ended up following the AEV guidance (for which the JSS mounts are very similar to as JSS and AEV worked together on them).
I used some aluminum foil to keep heat and spatter off parts like brake lines and ratchet straps (the straps are keeping the suspension sucked down). To keep the mounts and frame from potentially distorting, I welded the mounts in opposing patterns, about 3/4" to 1" at a time. The frame is thinner than you think it is and I almost had a blow through on the rear, underside of the passenger side mount (the one I welded first), where I put a little too much heat into the puddle. The engine mounts are 1/4" and (from the best I can measure), the frame is not even 3/16" thick, so be mindful where you put your heat.
Steering Shaft Relocation
The steering shaft will not clear the engine/exhaust manifold in the factory location. Thankfully, many vendors, including JSS, make a "steering relocation bracket":
The concept is simple: you grind away some of the sheet metal on the firewall where the OEM pillow bearing is mounted until the OEM bearing + relocation bracket no longer hits the firewall.
Note that although the relocation bracket fits all JK's, the earlier year JK's (2007-2010) have studs on the inside of the body, whereas the later year JK's have studs that extend out of the firewall into the engine bay. The installation process is the same, but you will mount them differently.
Todd has a video of the process and you can see the difference between how my pillow bearing mounts and how the later year mounts:
I started by roughly drawing a line down the center of each of the studs. I used these lines to align the relocation bracket on the firewall and then used the same marker to draw the clearance needed for the pillow block by "tracing" the inner radius of the relocation bracket.
A carbide bit on a die grinder made easy work of the sheet metal:
Once the block was clear, I used a flap disc on my drill to clean the edges up:
Here's what it looks like installed from under the dash. Remember, this is a 2008 JK, so it will look different on later year models as the studs are on the firewall side:
Easy peezy... I used some touch up paint on the freshly cut edge, as well on the spot where I made when the drill slipped out of my hand and the flap disc marked up the firewall. I ended up using some 1/8" thick "closed cell marine foam" that I found on Amazon as a seal for the steering relocation bracket to the firewall. The OEM pillow block as a rubber/foam seal, so I figured that it may be a good idea to replicate that some how. So far, it seemed to do the trick.
Paint/anti-rust work
With the engine and transmission out, and with some major pieces out of the way, this is a great time to address any surface rust issues you may have. It would also be a good time to thoroughly clean the frame and use a product like Eastwood's Internal Frame coating as you'll have easier access to all the nooks and crannies from all different angles.
Engine Prep (5.7 Hemi)
Refresh items
You have a few options when it comes to sourcing an engine. Depending on where you live, you can easily source a take-out engine, and if you look around, likely a complete take-out engine + trans (ideally from a Ram 1500 with an 8HP70 if you're looking to go that route).
You can also buy new crate motors. Although Mopar stopped making them a while ago, they're still in stock at nearly every Mopar online retailer. Perhaps now that Stellantis is offering the Hemi in trucks and cars again, perhaps we will see them making crate engine offerings again (please!!!). They not only have 345 (5.7L) crate engines, but also 6.4L, and 6.2L supercharged options. All crate engine options are LX-based, meaning they will need some changes made to them in order to fit into a JKU (see below).
My Crate Hemi is rated for 383hp/417tq. You'll note that this is slightly less HP than the Ram Truck 5.7L (395hp) and slightly more torque (410 ft-lbs), which is often credited to the differences in the intake. The Ram 5.7's have a taller intake with "SRV" (Short Runner Valve), which changes the length of the intake manifold's runners. It uses longer runners at lower RPMs for better torque and shorter runners at higher RPMs for better horsepower. Remember that these are "peak" numbers and the engines are programmed a bit differently. Some say that the power characteristics of an LX engine (car/SUV) are better for a Wrangler, but I would seriously doubt anyone would notice in a side-by-side comparison.
[My 345 Mopar Performance Crate Motor, with torn apart 2010 VVT block and cylinder heads in the background on the floor]
If you happen to get a low-mile donor, you may not need to do anything. However, there are some known hemi issues that may be worthwhile to address now. The biggest issue plaguing Hemis, especially ones that have counterintuitively been driven softly or allowed to idle for long amounts of time, is the issue with the cams getting chewed up by failed lifters.
[Chewed cam lobe, third from left]
This very issue happened to the donor engine I originally purchased. What generally happens is that oil pressure is low, either due to poor maintenance, excessive idling, long, sustained stretched of low oil pressure (like say cruising for hours upon hours in hot weather with the engine only turning 1300-1600 rpm), and any combination of the three. When oil pressure is low, the needle bearings inside the rollers of the lifters get starved or clogged/gummed up. Once they do that, they stop spinning. As the cam now acts like a flat-tappet cam, you get the infamous "Hemi tick".
The constant beating of the lobe loosens and eventually destroys the needle bearings inside the roller, causing it to eventually get pushed back into the lifter body. Once there is no longer a place for the roller to move, the roller gets worn down, wearing not only the roller itself, but also the came lobe. If you catch the tick early, you can usually just swap the cam out for a new one, change the lifters, and you're good to go (most people also swap in a new oil pump and timing chain as well).
Some people take it a step further and completely eliminate the Multi-Displacement System (MDS). The MDS is what Chrysler uses to deactivate some of the cylinders of your engine, effectively turning your V8 into a 4-cylinder, saving fuel when cruising at steady speeds. Having driven in many Hemi Ram 1500's, I can confirm that the fuel savings are indeed there with MDS activated. On a drive from Houston to Phoenix one time, I averaged ~22 mpg with the A/C blasting the entire time, all while driving 80 mph across I-10.
While it's not 100% certain, it does appear that MDS equipped vehicles do experience lifter failure more often than non-MDS vehicles. Many companies, including Melling, make a "MDS Delete" kit, which includes all the parts you need to remove the MDS components from your vehicle. Note that the MDS delete will require reprogramming of your ECM (which in the case of most swaps, is automatically done).
With the exception of a catastrophic failure, the Hemi engines wear very well. In the block above, even with the chewed up cam lobe, the cam bearings looked absolutely fine, and the cylinder walls still have the factory cross-hatching on it. If you find a block with a good cam, you can generally feel safe doing the MDS delete and installing a fresh set of gaskets, knowing that doing so will provide you with reliable service life.
Oil Pans
Truck engines are rear-sump; LX platforms are front/center sump.
If you have a car engine, you'll need a rear sump pan, plus the corresponding pick up tube and windage tray. The easiest option is to buy the Mopar Performance Rear Sump Kit, PN 77072450AB. However, these are getting harder to find (though with the reintroduction of the Hemi by Stellantis, this may get easier soon!). Here are the PNs for individual parts, all of which are easily sourced at your local Mopar dealer or online.
Part DescriptionMopar P/N:
Oil pan pick-up53021522BD
Oil pan pick up bolt with stud6506333AA
Oil pickup tube nut6502756
Engine Oil dipstick53021858AD
Engine Oil dipstick tube53021322AF
Engine Oil dipstick tube O-ring53021144AA
Main bearing cap bolt6506272AA
Oil Pan windage tray53021568AE
Oil Pan, 5.7L Truck Oil pan53021334AF
Oil Pan Bolts6508065AA
Oil Pan studs6508066AA
You can find more photos and information in my Oil Pan Swap Post...
Flexplate
Depending on what you get your donor from, and what transmission you're going with, you may need to change your flex plate out.
[LEFT: 2010 VVT 5.7L w/545RFE flex plate; RIGHT: New Mopar flex plate with new backing plate]
The flex plate and backing plate is compatible with all V6 and V8 NAG1 and 8HP70/75 transmissions. You can reuse your original flex plate mounting bolts, just make sure to clean them and use some fresh Blue Loctite.
Qty
Notes:
Flex plate (NAG1 & 8-speed)4752574AB
1​
Flex plate Backing Plate4736613AA
1​
Trans TC to Flex plate Bolts6509361AA
6​
Flex plate to Crank Bolts6503465
8​
70 ft-lbs
Transmission Crank Pilot Sleeve4736283AA
1​
Needed on pre-2017 transmissions with small diameter torque converter snout
Installation is easy - the flex plate can only mount one way due to the offset of the mounting bolts. Use fresh blue Loctite and torque to 70 ft-lbs. Note that my crank still has a pilot bearing inside, because the crate motor originally came fully dressed with a Mopar Performance Clutch meant for manual trans use. I'll pick up a rental pilot bearing puller this afternoon and get this removed so I can finally get it mounted on my engine stand.
Engine Crank Sleeve
I did not see this mentioned anywhere in the JSS YouTube videos or in Todd's BOM documents, but JKB Off-road mentioned something of note in his Episode 5 of his JKU Hemi swap series. It looks like for pre-2017 (and perhaps some early 2017) Ram 1500's came with an 8HP70 transmission that has a small "snout" on the end of the torque converter.
[Screen shot from JKB Off-road Episode #5 video showing the size of the "small" snout on his 8HP70]
If you have a transmission with a snout this size, you'll need Mopar 4736283AA Sleeve-Crank Shaft Pilot:
However, from ~2017 and up, the Ram 1500 8HP70/75 transmissions came with torque converters that had a larger snout:
Which matches the size of the crank pilot hole perfectly and negates the need to use the sleeve.
Transmission (8HP70) & T-Case Prep
Trans Cooler Fitting & Cooler Lines
If you use a Ram 1500 sourced 8HP70, you'll need to tap (but not drill) your cooler ports to accept OEM Mopar trans cooler fittings. Alternatively, some people tap their ports and run -AN fittings.
Whatever you decide to do, the process is straightforward but it is crucial that it be done correctly, as messing it up will essentially render your 8HP70 unusable.
Todd at JSS has a short video that explains it here:
If you want to see more information on the process, check out Post #47 in this thread: 8HP70 Trans Cooler Fittings
There are lots of options for cooler lines and coolers, including some that have fallen out of favor. While some choose to do their own lines, most people have historically opted for the WK2/Grand Cherokee or Durango style lines. This allowed for easy fitment, with OEM quality and style.
However, with the advent of the 392 JLU, most people (including JSS) are opting to run these lines, and the matching cooler. Just like with the WK/Durango lines, they offer bolt-in and off-the-shelf replacement convenience with OEM quality.
Part DescriptionOEM Part#
Transmission Cooler (JL 392 Style)68481176AA
Transmission Cooler Fittings68489743AA
Transmission Cooler Lines (JL 392 Style)68481147AE
Shifter Conversion
Since the shifting on the 8HP70 is all done electronically, the OEM shifter gets removed and replaced with either a Charger or Challenger shifter. I found a shifter from a 2018 Challenger, Part# 68205233AJ, on eBay for a good price, complete with leather boot and illuminated shifter handle.
The JSS 8HP70 Swap Kit includes the shifter mounting bracket that allows the 8HP70 shifter to mount to the factory mounting studs on the OEM floor plates. I'm going to bring my floor plates to the powder coater since he's reasonable and I'd spend two hours or more cleaning and painting them.
TCM Updating
On the 8HP70, the TCM is integrated into the valve body when installed. This means that in order to remove and send your TCM in for programming, you'll need to tear it apart. The process is fairly straight forward, but you'll want to have a nice, big, and clean working area to do this. Rusty Nuts Media has a nice video on the process. I suggest you read through the process below, then watch the video once or twice before digging into yours.
The basic steps are:
1) Drain the fluid.
You'll need a 10mm Allen Head for the plastic drain pan found on Ram 1500's. Note that the drain plug is also plastic and "ratchets" open (makes a bunch of clicking sounds that feels like you're stripping it!). The 8HP70 holds ~9 qts of fluid, so have a pan ready to catch at least 7 quarts!
2) Plug the vent on the top of the case (to prevent fluid from dripping out), and flip the transmission on it's top and remove the pan. The pan uses T40 bolts around the perimeter and should come off without any headache.
3) Remove the Valve Body (VB) + TCM bolts. The VB+TCM are held to the transmission with 18 total T40 bolts, 14 of which are "long" and 4 of which are "short" in length:
[T40 "Long" bolts securing the VB+TCM to the case]
[T40 "short" bolt locations]
4) Remove the electrical case plug from the case.
One of the T40 short bolts that you've just removed holds down a small metal retaining arm for the case plug. With the bolt remove, you simply need to "lift" the retaining up and it will allow you to pull the plug out of the case.
With the retainer lifted, the plug can be removed. Note that this can seem "stuck", especially on transmissions with heavy mileage. There are two very tight fitted o-rings on the plug. I used my hands and simply wiggled and applied steady, consistent pressure rearward, and the plug slowly started working its way out, until it finally "popped" loose.
[Photo above shows case with the plug missing]
5) Remove the VB+TCM from the case;
with the case plug out of the way, you can now remove the VB+TCM from the case. First, ensure that the electronic connector/plug that was previously secured by one of the short T40 bolts is completely free (the tan "arm" below):
Then grab the sides of the VB and slowly lift straight up. You may need to manually move the neutral-selector on the side of the case to clear the pin on the VB itself:
Make sure to have a secure grip as the VB is heavier than it looks and is covered in transmission fluid. Have a clean place to set it down so you can begin the next step in in the process.
6) Separate the TCM from the VB. The TCM is secured to the VB with five T27 bolts:
Once the bolts are removed, you can disconnect the tan electrical connector and move it to the side. Note that the wires here give just enough room to clear, so don't go pulling too hard during removal, or you risk ripping the connector or wires.
The TCM "snaps" into place and is aligned via three long dowel pins. To remove it, you simply work your way around each of the solenoid valves (the orange and white items in the photo below) and lift the TCM equally at the dowel pin locations. It is a snug fit, but everything moves easily.
7) TCM + VB (aka the "mechatronic") Reinstallation
You should know by now that I HATE, with a passion, ambiguity in instructions and details. When it came time for me to reassemble the TCM and VB, I was once again blown away at how poorly documented and referenced the process was. Even JSS does not provide a spec or sequence, and they're selling the parts to do the swap!! This truly blows my mind...
But alas, I did 3 hours of reading and searching to come up with what I consider reliable information. Here's what I found:
- There is a specific bolt tightening sequence on the mechatronic to case, T-40 bolts. Here's an easy-to-read screenshot taken from my bud's YouTube video:
Here's a screenshot taken from the ZF-supplied 8HP Service Manual, in case there was any doubt:
- The torque spec on the T40 bolts, officially referred to as the "#9, Cylindrical Screw, Mechatronic CU, TX40" in the ZF manual is 8-Nm, or 71 INCH-lbs. You can download a copy of the 2025 edition of the ZF reference here: https://avtgr.ru/upload/data/pdf/zf_instructions/8HP70.pdf. This torque spec is also referenced in the ATSG Service Manual.
- There is NO OFFICIAL TORQUE SPEC on the T-27 bolts that hold the TCM to the VB. According to ZF: "The mechatronic is treated in the instructions as a complete unit and should not be dismantled by personnel who do not have the special skills required to do so and instead should be replaced in full. Separate instructions are planned for the mechatronic". This approach is also FCA's official approach, as the FCA Student Repair Manual says "The valve body assembly is comprised of the valve body and the transmission control module assembly (TCMA). The valve body and TCMA are serviced as an assembly", found on Page 12 here: https://akpphelp.ru/images/contents/files/zf8hp45_70_rukovodstvo_manual.pdf
ATRA, the "Automatic Trans Rebuilders Association" has a ZF training PPT and reference material that specifically shows a torque spec on the T-27 bolts that hold the TCM to the VB. It shows 8-Nm (71 INCH-lbs) as the spec here. Although this is not official, I think this is a reliable spec, as other T-27 bolts serving a similar function also are listed as 8-Nm in the ZF service manual (linked above). There is no torque sequence listed in any document I have seen for the T-27 TCM-to-VB bolts. I would start on the solenoid side and hand-tighten moving away from the solenoids, then go back and repeat hitting the torque spec before moving to the next. There's no load here, so this is likely plenty sufficient.
Fun Fact I did not know until doing this level of depth research - apparently the TCM has a little notch in the side that will allow you to "flip back" the speed sensor (near bolt #18) and keep the tip out of harms ways during install and removal. See the screen shot of "Figure 16" from the FCA manual:
With the above guidelines, installation of the VB back into the trans is the reverse of removal. Take your time and don't damage the tip of the speed sensor. Make sure it fully engages into the slot BEFORE attempting to install and tighten bolt #18 in the above tightening sequence diagram.
8) Oil Pan Installation
Install the oil pan with a new gasket and filter, tightening the bolts in the proper sequence outlined below. Note that some people have said that the steel pan has a different torque spec than the plastic pan. This is incorrect. Both FCA references 10-Nm (89 INCH-lbs) as the correct spec.
T-Case Selection
If you intend to run the 8-speed, you will need a t-case from either a 2007-11 Jeep JK with Auto Trans or a 2007-18 Jeep JK with Manual Trans. If you have a 2012-2018 JK with Auto Trans, you'll simply need to source a used t-case from a manual trans or an earlier year.
You can run a Sport case (2.72:1 ratio) or a Rubi case (4:1 ratio). However, many of the people that have decided to run a Rubi case behind a Hemi + 8HP70 wish that they went with a Sport case. Some of the people I've talked to have even decided to switch to a Sport case after going with a Rubi case. Why? Well it comes down to gearing.
The 8HP70 has a great gear spread:
  • 1st Gear: ~4.714
  • 2nd Gear: ~3.143
  • 3rd Gear: ~2.106
  • 4th Gear: ~1.667
  • 5th Gear: ~1.285
  • 6th Gear: 1.000 (Direct)
  • 7th Gear: ~0.839
  • 8th Gear: ~0.667 (Overdrive)
  • Reverse: ~3.317
If you've got 5.13's gears and a Sport Case, you'll have the following crawl ratio: 4.714 x 2.72 x 5.13 = ~66:1. Unlike with a manual transmission, you'll get additional torque multiplication of ~1.6 to ~1.8x, bringing you from ~66:1 to ~118:1. This is well over the "golden target" of 100:1 crawl ratio that many manual transmission owners shoot for. Now, if you had a Rubi case, you'll have a crawl ratio of ~97:1 up to ~175:1 at max converter stall. This is a crazy crawl ratio and with even a bone stock 5.7L, you'll likely be pushing through your brakes constantly.
T-Case Shifter Bracket Mod
You will need to buy and modify the t-case shifter bracket. Unlike the OEM bracket that attached directly to the transmission case, the one for the Hemi + 8HP70 swap mounts to the flange face of the trans-to-t-case.
Not only do you need to modify the shift cable bracket, you need to modify the transmission case a little bit too. The rib needs to be ground down (but not too deep that it cuts into the inner cavity) and smoothed over. A cut off disc and flap disc make short work of this.
Here's what the shift cable bracket looks like when modified:
Mocked up in place. The bracket is retained to the t-case flange by the t-case stud nuts.
Reactions: MichaelGH and Chris
Engine & Transmission Installation
Mounting
Mating the engine and transmission is a simple affair. The first step is to ensure that you have the torque converter full seated on the pump. There's nothing special about the 8HP70 TC, you have to do the spin-and-push sequence to get it fully seated. When fully seated, the mounting flange on the TC will sit roughly even with the inner scalloped section near the starter hump (in the image below, the casting area to the left of the uppermost bolt hole on the lower-left side of the image is what I'm talking about).
Before mating the halves together, make sure you install the correct intermediate plate. This is also a good time to confirm that the pilot bushing is/isn't installed in the end of the crank (see explanation in a different post about this).
The only SAE-sized threads in a Gen III Hemi are the 4 bolt holes for the transmission. On factory installations, the top two block holes (nearest the intake manifold) are actually studs (Mopar PN: 6512399AA). These will be 3/8"-16 on the side that goes into the block, and M10 x 1.5 on the other side. Many people choose NOT to use studs here and simply use standard bolts. I went with studs as it seems like a good place for wiring support brackets to go. The two remaining block bolts are also 3/8" x 1-1/2" long (Mopar PN: 6022266). The bolts that go from the engine side into the transmission are all metric, M10 x 1.5 x 45, Mopar PN: 6101985.
With the engine and trans mated, you'll need to use your fingers to spin the TC around so you can get a bolt started. The 8HP70 uses different sized bolts for the Flexplate-to-TC, Mopar PN: 6509361AA, so make sure to have six ordered and ready (not 4 like on older TC's). The torque spec here is 31 ft-lbs.
Once you have the engine and trans mated together, and the TC bolts installed, the Gen III Hemi with a rear sump uses a "Structural Dust Cover", Mopar PN: 53021491AA. This bolts to the engine block and transmission, serving as both a dust cover, and also a structural support, hence the name. The bolts here are all metric, Mopar PN: 6101985. There is a specific torque sequence here, and not following it can result in damage to the trans or structural cover itself. The process is simple, so just be mindful of it (see below for installation details)...
Best Order of Operations
We installed the engine and trans as a single unit. It is tight, and I'm glad I installed the leveler, as you really have to work over some stuff in the engine bay, why trying to avoid snagging and hitting things along the way. Having an extra set of hands here is really helpful!
You could easily install the engine and then mate up the transmission from below. It all will depend on your setup, access to lift and tools, helpers, etc.
One thing that absolutely helped was removing both motor mounts from the engine. We tried to finagle the engine in and around, but ended up putting a nice dent in my brand new firewall insulator - and that's with both of us being super careful and taking our time. The problem is lifting the engine high enough to clear the frame brackets with the mounts on the engine, while not smacking the top of the trans against the back of the firewall, while also not smashing the engine into the cowl. Removing the engine mounts made it super easy at that point, and they aren't too hard to install with the engine hovering over the frame mounts.
My son and I being very happy to be done pulling this thing in and out - and me sweating because it finally warmed up outside so my garage is at a balmy 72°.
Torque Specs
Above is a screen shot from a 2014 Durango with 8HP70. Engine to Bellhousing bolts are 41 ft-lbs. I torqued the studs to the same spec. The TC to flexplate bolts are 31 ft-lbs, but you'll need a very shallow socket to get in there on a typical 1/2" torque wrench.
For the Structural Dust Cover:
  1. Hold up dust cover under engine and transmission, and ensure that it is flat against both the engine and transmission.
  2. Hand tighten bolts to the transmission side first, then engine side.
  3. Torque transmission bolts down to 80 INCH-lbs, then repeat for the engine bolts.
  4. Torque transmission bolts down to 40 ft-lbs, then repeat for the engine bolts.
More to come...
Clearance checks
Things to test before final tightening
Driveshaft details
Reactions: Chris
Wiring, CANBUS, & Electronics
Hemi Wiring & ECM
There are lots of options for wiring; you can make your own (and I certainly have in the past, including for others), but nowadays (and especially with this project), I wanted simple plug-and-play. As such, I opted to buy the harness and ECM from JSS. The harness from JSS, like every swap company, will take a while, so plan for the wait. It took ~8 weeks to get mine (JSS says 8-10 during checkout), but this of course wasn't an issue since I obviously had lots to do in the meantime.
The harness is straight forward and uses all OEM connectors. To install it, even if you're not familiar with all the connectors, is simple. Whenever I've done a harness, I usually pick the "middle" leg to start on, and work my way from there. In the case of the Hemi swap, I started at #1 below, making the connectors to nearby equipment, then inserting the harness support "struts" in the valve cover as I worked my way towards the rear of the engine (#2). I then found the other side of the engine harness, and started working the connections near #3, and then forward towards the front of the engine. Once those were secured, I went to location #4, tucked the trans connectors back down over the trans, and worked the remaining part of the harness over to #5. In the photo below, the three ECM connectors are looped around the master cylinder, as I need to remove the relay bracket and do some other things first.
Depending on your engine and options, you will need to "pin" a few wires, shown below. These get put into the corresponding pinholes on the C3 "body" plug at the ECM.
CANBUS integration
Transmission Control Module (TCM) Wiring
OBD2 retention
JK TIPM compatibility
Cooling, Fuel, Exhaust Systems
Radiator & hoses
There are a number of considerations here. Many people opt to get a "V8" radiator, which has the inlet and outlet on the passenger side. I originally tried to keep my OEM radiator, not because I was trying to be cheap, but rather because I simply see too many failures of non-OEM radiators to be comfortable with them. On all the various FB pages and forums, people are constantly battling with leaks and cracked aluminum radiators. This isn't a JK issue, just an issue overall with aftermarket aluminum radiators, so I was trying to avoid it. Plus, apparently the 3.6L engine, which uses the same radiator as the 3.8L, has a higher heat load than the 5.7L Hemi. So, from a heat handling capacity, the OEM unit should be fine, especially if I can move enough air through.
Unfortunately, with the "Long" LX front cover, it was a battle I was never going to win. If I had gone with the LX "short" accessories (aka "09-10 GC length"), I think I could have made the OEM radiator work, because I know many that have, but I opted to go with the newer and easier to source LX Long parts. As a result, I ended up ordering the Northern JK Hemi Swap option. It moves the outlet a little higher, but angles the outlet downwards, offering better fit as less hose radius is required. Fitment so far is good, although I did end up trimming 1" off the lower outlet to give me a bit more clearance on the alternator pulley.
You can check out how I did that, plus how I made some hoses that fit much better than the commonly listed/mentioned hoses here: https://wranglerjkforum.net/threads/jku-hemi-swap-reference-guide-swap-info.32731/post-472868
Heater Core Hookup
The heater core hoses you'll need will depend on what motor you use. On the 5.7/6.4 VVT Truck engines, the heater outputs are on the front of the engine, so you'll need long hoses to connect them. The part #s are on the JSS BOM Sheet, though many people end up cutting/trimming them down, and some even use little heater hose "unions" to help with fitment (cutting the hose and using a union will let them "twist" the hose without kinking).
On my LX-based crate engine, the heater core "pipes" are plumbed under the intake manifold, straight back to the rear. This is how they are in most car-based engines:
The Durango/Cherokee based engines are similar, though the pipes get offset slightly in the rear of the engine, like this:
Luckily, replacement car-style pipes are easy to find and replace. The OEM Mopar ones are cheap and available, and even Dorman makes them if you need them. For hoses, I simply used OEM 2012+ 3.6L Jeep JK hoses. You can use the original 3.8L hoses, but they're much longer and you'll need to trim a lot more. If my heater hoses were newer or in better condition, I probably would have used them. However, since I was buying new parts-store hoses anyways, I went with what was cheaper and the 3.6L hoses are much smaller and less than half the price of 3.8L hoses.
Cooling Fan Setups
Space is at a premium, even on the shallower "LX" motors. The 2009-2010 GC/Durango FEAD has the most clearance and even allowed for use of narrow OEM mechanical fan clutches. The next "roomiest" setup is the 2011+ LX-car FEAD, followed by the truck FEAD which takes the most work to make things fit. On my crate engine, between the OEM radiator and fan, there's slightly over 4" of clearance (on a truck engine, it would be ~2.5!):
The OEM 3.8L fan - which is ~4.625" wide - is a hair too thick. So what does this mean? Well you have a few options...
First, some people simply use grille support spacers (that go between the radiator support and the frame rails) that pushes the grill forward about 1/2" and gives enough room to run the 3.8L fan on a LX-short or LX-long FEAD. It's still tight, and some people even grind down the "snout" of the water pump pulley a little. This looks funny to me, as it makes some unnatural looking gaps around the hood/fenders, but does work fine and it is a cheap and simple solution.
Another option is change to a different fan setup. There are two primary candidates for this, the popular "Camaro" fan with related controller (also quite popular with those doing LS swaps) or the "Pentastar" fan swap. The Camaro fan uses a 5th/6th Gen Camaro fan, dedicated speed controller and temperature sender, and related wiring. These are brushless, are the thinnest option out there, and move the most amount of air. However, they do require more modifications to work (like a custom shroud).
I chose to go with the 2012+ 3.6L Pentastar fan. These can move a lot more air and have better programmability than the original 3.8L fan, and they're nearly 1" thinner, so they fit without the need of radiator support spacers. Now obviously if I was Hemi swapping a 2012+ JK, I'd already have this, but thankfully, these are easy to find on the used market and they're known to be extremely reliable. Swapping to the Pentastar fan has been popular for those with 3.8L equipped JKUs, even for those who were not doing a Hemi swap, and companies like AEV and others made specific swap harnesses and controllers for them.
Below you can see my OEM 3.8L fan on the left, and the eBay-purchased, used Pentastar fan on the right. You can see that the blades are ~1" larger in diameter, and if you look real close, you can see how massively thick the wiring to the motor is. Those are what appears to be 10 AWG leads, which makes sense as this thing can pull up to 50A on high-high:
Thickness wise, you can see that it's almost an inch shallower (and is actually over 1" in the center of the fan motor):
Just like the Camaro fan, the Pentastar fan is PWM (Pulse Width Modulation) controlled. This means that the fan is controlled by a computer, which precisely controls rotational speed (RPM) by switching the power on and off in rapid cycles (rather than by simply reducing voltage). This method allows for a wider, quieter speed range, reduced power consumption, and better thermal management compared to older style 3-pin DC fans.
For factory-installed Pentastar vehicles, the "computer" that controls the fan is actually the ECM + TIPM (Totally Integrated Power Module, aka your fuse box), and it pulls temperature and "speed requests" (i.e. if you have your A/C on) directly from the CANBUS signal from the ECM. Although the Pentastar fan did not come out until 2012, most 2009+ TIPMs are capable of being programmed (by JScan or AEV Promodule) to provide the PWM output (instead of voltage controlled). In the case of my pre-2009 model year, if I were doing just the fan swap on my 3.8L, or if I wanted to have the Hemi ECM+TIPM managed my fan speed, I would have to swap my TIPM to a 2009+ version.
Rather than use the ECM/TIPM to control the fan, I'm going to use a dedicated fan controller, specifically the Extreme RPM controller, because even with a compatible TIPM, there are some limitations on performance. Standalone controllers have better programming logic and can often be adjusted to suit the demands and needs of the user. For example, some offer override options (handy if you know you're going to be idling and winching).
Note that on truck-based engine swaps, you will likely need to redrill the holes for the radiator support to front-fender bolts, though many opt to use the grille spacers, even with a Camaro fan!
(more to come here once I'm done with the install)
Fuel pump & line conversions
TBD
Exhaust manifolds/headers
I originally ordered the JSS headers + full exhaust kit. It was expensive ($2300 total) but was a "turn key" option that eliminated nearly all the headaches related to fitment in a very crammed area. However, since my OEM gas tank broke two of the plastic nipples at the top of the tank when trying to drop it, I'm going to replace it with the Motobilt Rear Gas Tank Conversion. As a result, I now have a lot of flexibility and room underneath, making the JSS kit unnecessary.
I decided to go with the JSS suggested OEM manfiold setup. I ordered two Mopar exhaust "kits", meant for later-year 5.7L Truck applications. These are known to fit and although they have changed slightly over the years (mostly just the orientation of the "ears"), they prove to be a reliable option for nearly everyone.
The problem that same people run into when looking at the BOM is that the part #s change somewhat regularly. Mopar makes a slight tweak, and rather than give it a version designation (e.g. AB --> AC), they give it a totally new part #. Mopar also changes the kit components, which then adds more confusion to the mix. Here's what I found...
The "current production" manifolds designed for 2019+ Ram 1500's, and that work on JK Hemi swaps are, as of this writing (Feb 2026), Part Numbers: 68529833AA (LH) and 68529832AA (RH). If you watch the various videos put out by Todd at JSS, these are the ones he says to use. However, you can't buy them because Mopar doesn't appear to sell just the manifolds directly. Instead, these are offered as "kits", with all new heat shields, hardware, tie bars, etc., under PN's: 68591573AC (LH) and 68591572AC (RH).
68591572ac-exhaustmanifold57r-2024-2019-ram-1500-dt-jeep-wagoneer-ws-57l-engine-exhaust-manifo...jpg
Something to note here - Mopar also sold these kits under the -AB designations (instead of the -AC), which had included the tie bars (nowadays you have to be ordered separately). The -AB kits are all over the internet, but be aware that even if you order an -AB kit, (I ordered mine from Mopar Parts Direct), you will likely get sent the -AC version. Thankfully the -AC kits are ~$92 per set. Just make sure you get the tie bars separately if you order them online.
Tie bars (68408129AA Upper L/R and 68408130AA Lower L/R) are not side (Left/Right) specific, but the top and bottom ones are different (in case it wasn't obvious).
Depending on what year engine you use, you may have 10 bolt holes to mount the exhaust, though some will have only 9. The manifolds above will work with either setup, but the tightening sequence changes slightly (see below). Torque is 18 ft-lbs dry. The bolts are coated and don't need anti-seize. They also have thread lock pre-applied, so no need to add anymore.
Once installed, there is a good amount of clearance between the manifolds and the frame rails:
Something to note here: the exhaust manifold kits referenced above come with new hardware. The hardware kit for the passenger side (RH) comes with one shorter black bolt (shown in the center spot below). The hardware kit for the driver side (LH) comes with all silver bolts (6) and studs (4). The reason for the single black bolt is because there is one spot on the RH manifold (the most "forward", noticed hole in the manifold - you can kinda see it above too) that is not covered by the tie bar. The bolt is shorter to accommodate for the lack of thickness of the tie bar.
Y-pipe and O₂ sensor placement
I ordered a Ram "Federal Only" catalytic converter kit from eBay. For $130, I was actually impressed with the welds and how it was packaged. These will work, but will need to be modified to put the O2 sensors and downpipes in the ideal locations. I'm going to cut the welds (hopefully without cutting into the underlaying pipes!) and trim/rotate as needed.
Since I'm going with a Motobilt rear gas tank, I am going to simply run the exhaust straight back into two Flowmaster FX muffler, with downpipes just ahead of the rear axle. If you're keeping the OEM tank, I think you'd be able to modify these to work, though be prepared for a lot of testing fitting.
Reactions: Chris
FEAD & Accessories (PS, AC, Alternator, Intake)
Timing Cover Differences
Mopar refers to the accessories at the front of the engine as the "Front End Accessory Drive" (FEAD). You will often see this in Mopar materials, especially on stuff that isn't vehicle specific and is intended for use on their crate engines. Accessory fitment for VVT engines is generally a result of getting the correct "length", which can be broken up into three main types:
  1. VVT LX "Short" Length (often referenced as "09-10 Grand Cherokee")
  2. VVT LX "Long" Length (2011+ Cars and SUVs), this is sometimes referred to as the "LD" length (explained below)
  3. VVT Truck Length (2009-2010 series, then later 2011+ series)
Some history that helps explain the differences:
  • The "LX" moniker is used ubiquitously across Hemi swap pages and info, including here. As you do your research into things, keep in mind that people use "LX" because this was the original Mopar platform designation that was applied to the early cars that replaced the LH platform (front wheel drive). The original "LX" cars include the Chrysler 300, Magnum, and early Chargers, generally from 2005 to 2010. For the 2011 model year, the Charger was updated and given the "LD" platform code.
  • All Hemi engines, regardless of platform, went to the VVT style in 2009. This engine update was not coupled with any platform change, which means that original LX platform cars like the Charger could be non-VVT or VVT. People however still referred to the engines from cars as "LX", adding "VVT" to help differentiate the two.
  • The Challenger, which is officially designated as the "LC" (2008-2014) or "LA" (2015+) is still referred to as having an "LX" motor. Note that all 2008 Challengers were equipped with the 6.1L, so any 5.7L from a Challenger will be a 2009+ VVT.
  • Just like with the cars, the Hemis in the Ram trucks went VVT in 2009+ model years. This means that non-VVT accessories won't fit VVT engines. Additionally, just like the with the LX platform update, truck engines underwent a major change in 2011, so generally 2011+ accessories will not interchange with 2009-2010 timing covers.
Some things to keep in mind with the above info:
  • Accessories are not swappable between LX and truck styles without changing the timing cover and ALL accessories.
  • Between the two different LX lengths, the timing cover is the same but accessories and crank pulley are different, making the accessory drive 1" shorter than 2011+ accessory drives.
  • All 2013+ Hemi car engines came without a belt-driven power steering pump.
  • 2011+ 5.7L and 6.4L front end accessory drives are all the same between car or SUV (truck is still different)
Todd from JSS has a good video here:
In my email discussions with Todd, he says that in the early days like 2005-2010, it was common to just use the "early" style accessory drive ("LX short"). Then, in 2011 the new LX engine came out with a slightly longer front drive (+1 inch). At that point, they (JSS) started using the 2012 Challenger accessories because it has a belt driven power steering pump and a P/S pulley that fits a lot of swap uses.
Alternator
My crate engine is based on a 2015+ Dodge Challenger block and internals. This means that nearly any alternator from that era will fit. Additionally, earlier WK (Grand Cherokee) and other 5.7L SUV alternators will fit, though they mount with "ears" similar to older style alternators. Newer alternators have mounting blocks (similar to your A/C compressor) and generally fit just by bolting in place. Older style "ear" alternators may or may not need one of the mounting bosses drilled out to accommodate the mounting bolt (the bolt goes through the timing cover and into the block for support).
Todd from JSS told me to use "2012+ Challenger accessories", including the alternator. There are lots of output offerings from that era. The base R/T Challenger comes with a 160 amp alternator, though the 180 amp alternator appears to be the most commonly installed version on factory vehicles. As I started looking for OEM Mopar options for my engine, I found that Mopar offers the correct 180 amp alternator as part of their "FEAD Basic Kit", which comes with a bunch of other items I need (idlers and belt tensioner, plus the mounting hardware). The best part - the FEAD "kit" was only $567 shipped to my door. This was about $40 cheaper than the new Mopar 04801833 alternator by itself. Throw in the fact that this includes the hardware, idlers, and tensioner, the cost savings in nearly $250! Not that any Hemi swap is "budget friendly", but saving $250 is always nice...
Although it's not required, many people choose to trim/modify the alternator mounting tabs on this style alternator. The mounting bolt head is very close to the frame rail, about 1/2" away, and as a result, you'd have to lift the engine in order to remove the alternator if it ever needed to be replaced. The easiest way to do it is to trim the center chunk out and just use the tabs that remain afterwards.
I used a grinder, multi-tool, and flap disc. Note that I left the "ears" on the opposing side in place (the ones with the "X"), just in case I ever decide to try something else and wanted to use it. It doesn't get in the way, plus give me something to hold onto while I'm installing it, so there wasn't any reason to remove it.
Power steering
You cannot run a truck power steering pump b/c the pump pressures are too high for the OEM steering gear. However, if you're going to use hydro-assist or a PSC box, you may be able to make it work. Check out Todd's BOM for more information specifically for what needs to be done for fitment of a Truck VVT Hemi and PSC boxes.
A lot of people have made the Grand Cherokee pump and reservoir work, as these seem to have better working pressures for the OEM Jeep Steering Box. This of course requires GC "short" engine front accessories, or spacers.
If you want to see how I made a PSC "Hemi Kit" work on my crate engine, see that here: https://wranglerjkforum.net/threads/jku-hemi-swap-reference-guide-swap-info.32731/post-471745 and here: https://wranglerjkforum.net/threads/jku-hemi-swap-reference-guide-swap-info.32731/post-471796
AC system (a big one!)
Depending on your swap choice, you may be able to use your OEM 3.8L compressor. You can find a more detailed post here: https://wranglerjkforum.net/threads/jku-hemi-swap-reference-guide-swap-info.32731/post-471797
I ended up using the A/C compressor designed for the Mopar Crate Hemis, Part# 68202994AA , which I bought as part of the A/C Kit, Part# 77072446AB:
In general, all A/C compressors need to have some clearance work done to clear the power steering gear. Some setups can utilize the "bevel method". This involves countersinking an Allen headed bolt and clearancing the corner of the compressor that touches the steering gear. The AEV Hemi Kit Installation Instructions show an example of how this is usually done:
Since I'm running the LX-long setup and PSC Big Bore Box, I had to do the "chop method", which involves cutting the mounting boss back to the inner "ear". It's not hard, but a pain in the a$$ as there's really no good way to get blades in there without hitting something else. All the hash marked material below has to be removed. The best method was to use a hand-held hacksaw to cut a line straight down the mounting "ear", followed by a carbide blade on a cordless multi-tool, and finished up with a 4" flap disk.
You can use the original wire clip (that was originally attached to the part cut off above). Depending on your engine configuration and what steering gear you're using, you have a few options. I simply cut off a small portion of the bottom, and drilled out the hole to accommodate the upper mounting bolt.
Belt routing
Your belt routing will depend on your engine type, which can be confusing depending on minor differences in year changes. Pay attention if you get a take-out engine and take a photo before you start taking things apart to refresh.
With the LX Long setup plus the 5" PSC pump pulley, I ended up need a 850K6 belt (85.0" and 6-rib) using the OEM belt configuration.
Intake Manifolds
Generally speaking, the LX engines, 5.7L or 6.4L, will all take the same FEAD parts. Truck 5.7L and many truck 6.4L FEAD items will interchange. The main difference between the LX and VVT Truck accessories comes down to the difference in the timing cover, which itself is different to support the difference in intake manifold designs. If you're at a junkyard or swamp meet, the easiest way to tell a Truck 5.7L apart from a LX 5.7L is to look at the intake manifold:
[2010 Truck 5.7L VVT; the throttle body faces up towards where the hood would be]
As you can easily see above, the intake on the truck engines has a throttle body that points "up". All LX (car/SUV) intakes face forward:
[LX based motor intake and throttle body - faces towards the front of the engine]
Airbox solutions
Your OEM airbox won't work. There are some OEM options, including air tubes that will work, and JSS offers an airbox replacement that uses an AEM, Mopar Performance, or similar "cone" style filter with a 3.5" inlet and ~5" long.
First Start, Tuning, Troubleshooting
  • First-start checklist
  • Common Hemi swap codes
  • Idle control issues
  • Gear ratio tuning
  • Transmission behavior
  • How the Jeep behaves with current gearing, tire size, and the 8HP70
Reactions: Chris
Driving Impressions & Performance Notes
  • How it drives vs the 3.8
  • Temps under load
  • How the 8HP shifts
  • If the gearing feels right
Reactions: Chris
Final Wrap-Up
Drivability
TBD
What I'd do differently
TBD
Thanks to vendors/sources
TBD
Total Cost
We've all seen posts on forums and Facebook where someone claims that their best friend's, neighbor's, daughter's boyfriend's dad did a Hemi/LS for $2500 and a case of Natty Ice. These same folks are often the same ones saying that they built a set of Super Duty axles for $1500 and have been beating on them in Johnson Valley with 42" stickies for 2 years and never had any issues.
Sure thing pal...
I've called bullshit on those posts for years. In the near decade that I've been keeping track of these things, I've only ever seen two people provide full build sheets with all costs listed out, and both of which were right around the $10,000 mark (both of which got new transmissions too). For a VVT Hemi swap, like anything really, much will depend on your ability to do the work yourself. If you're able to weld, are comfortable doing major changes to things, and have the necessary tools and equipment (or are willing to buy or borrow), you'll probably be around $12-15k.
My total at the moment is $14,495, though part of that total includes a ~$500 estimate on miscellaneous items such as transmission fluid, engine oil, hardware, hoses, etc. (I will update the table below as needed). I admit that my swap is on the higher side - the crate engine for example was probably 2-3x what you can find a good junkyard/recycler engine for (if those are available in your area). Remember from my build page though that I already got a Ram 1500 5.7L take-out (and the guy sent me a video of the engine starting and running!!) and it STILL had a chewed up cam. I bought four new O2 sensors b/c the ones from my 3.8L had 209,000+ miles on them - your mileage may vary on that expense. I also have nearly $800 into a PSC pump and mount setup to support my PSC box and hydro-assist. You may be able to get by perfectly fine with an OEM option...
There is one major area where you could cut and shave some $$ - the transmission. If you had a NAG1 equipped JKU and just wanted to replace a sellable engine and had an otherwise good transmission, you could conceivably come in ~$8000 if you were able to source a cheap take-out Hemi with low (ish) miles that is ready to bolt into place.
Still, no matter how you slice it, any V8 swap is pricey. If I lived out west still, I would for certain be keeping an eye out for one of the many, many Hemi-swapped builds that I see come up in my feed for sale (though admittedly, I like the "build" itself). Don't forget about the ancillary parts too that I'm not listing here. For example, the driveshafts. I'm already needing a set of driveshafts to accommodate the 1-ton swap, but you'll probably need to adjust driveshaft lengths to account for the different driveline dimensions.
Speaking of driveline, are you going to run a ~400hp+ V8 on stock axles? I don't doubt the D44 could hold up to "reasonable" use, but who the hell wants that when you just installed a V8? Same for a front D30, and especially so with larger tires. Things will escalate quickly - so be prepared for it... :)
Pilot Bushing & Bearing Removal
You may or may not have to deal with this, but thought I'd include some tips for what apparently is a common issue getting these bushings and bearings out of Gen III Hemis.
Many of the 345 Hemi Crate engines come "fully dressed" - full of oil, exhaust manifolds, spark plugs, and clutch pack factory installed and ready to go. As you can see above, mine was no exception. The pilot bearing, OEM# FC69907, is actually sold and installed as a bearing (red arrow) and bushing (green arrow) combo. While this makes installation easy, it came make removal a pain in the a$$...
What inevitably happens is the bearing will pop out independent of the bushing around it. The issue that you'll face now is that the bushing itself does not have an accessible lip that would allow you to use a pilot bushing/bearing remover to grip on to. There are a number of ways to fix this. Some people use the old bread or grease trick, which can be effective, albeit messy. For me, I simply went with the "when in doubt, weld it out" approach.
A few tack welds around the edge of a nut that your slide hammer fits into...
...followed by a few whacks of the slide hammer and it pops out without any issues.
Something to be mindful of here - make sure you prep and plan for spatter. I cleaned things up well, and lowered my gas flow just a hair to keep spatter from blowing into the crank end. I had a few small balls land on the edge, but nothing I couldn't remove with a small screwdriver and polish away with an emery cloth. If you're using a flux-core welder, you may want to be diligent with some spatter shield before doing this.
Now that the flex plate is installed and pilot bushing removed, I was finally able to get the motor on the stand and off the pallet! As you can tell by the mess in the back of the garage, I need to finish organizing some stuff and taking some things to the trash (like the pallet this came on!). Cluttered workplaces are not enjoyable...
Reactions: Chris and tJKrider
Decided to buy myself an early Christmas gift…
Unfortunately, I was unable to install it - it was welded upside down, which because of the non-mirrored bolt pattern, prevented me from using it. I returned it back to Speedway and was on backorder for about 5 weeks. I ended up cancelling the order and getting a Summit Racing Lift Plate instead, shown below in red.
It doesn't have the built in tray like the Summit one does, but worked well, and also covered the intake ports. If I ever get bored once I'm done with this project, I may grind down the sides and weld in some 1/8" plate to make my own "tray". Alternatively, I may use some magnetized rubber tool trays once I find something long and skinny.
One thing I noted is that neither manufacturer says how much to torque the bolts down to. I used the OEM pattern and torque spec of 108 in-lbs and it seemed to work well.
Like an idiot klutz caveman normal dude excited to get working on a V8 swap, I broke the terribly placed vacuum nipple at the back of the intake manifold at some point last week. I looked back there and it was dangling…
I decided to try and fix it with some mechanical support and plastic weld. I used some 3/16” brass tube and some 2-part plastic weld epoxy, and it seems to be as good as new. Actually, it may be slightly better now that the nipple will never break again…
I used a brake flare kit to put a small flare on the end to prevent the brass from getting sucked into the intake manifold.
I got this at Hobby Lobby in the craft/model car section…
I used a dowel rod and plastic clip remover to keep pressure on the tip as the epoxy was curing.
Good as new!!! I used the epoxy inside to secure the brass tube to the plastic nipple, as well as the intake hole, and then used the same epoxy to weld the pieces together for a good seal.
