LPick6 New Member Joined May 2, 2020 Messages 5 Location Pennsylvania Aug 5, 2020 #1 I just put in new halo headlights.The turn signal(which is now in the headlight its self) is now going way faster than normal. How can I fix this? A new flasher? Solid state flasher?
MacGuyver JK Addict Supporting Member Joined May 13, 2020 Messages 1,006 Location Wisconsin Aug 5, 2020 #2 I'm pretty sure that means you wired them wrong. The halo turn signals are meant to be in addition to your normal turn signals, not a replacement. Jeeps flasher module is built in and not changeable, FYI
15' JK 4 Me Member Joined Apr 26, 2020 Messages 82 Location Cape Coral FL Aug 6, 2020 #3 You may need a load resistor. Reactions: napcop
Chris Administrator Staff Member Joined Sep 28, 2015 Messages 32,472 Location Gillette, WY Aug 6, 2020 #4 Yep, I believe you'll need load resistors. Did you use the CANBUS anti-flicker harness as well?
