Halo Turn Signal Going Fast
LPick6
Pennsylvania
I just put in new halo headlights.The turn signal(which is now in the headlight its self) is now going way faster than normal. How can I fix this? A new flasher? Solid state flasher?
I'm pretty sure that means you wired them wrong. The halo turn signals are meant to be in addition to your normal turn signals, not a replacement.
Jeeps flasher module is built in and not changeable, FYI
Yep, I believe you'll need load resistors.
Did you use the CANBUS anti-flicker harness as well?
