I am having a problem with my 2013 JKU. The Electronic Stability Control (ESC) light and Engine light come on and lose power while towing a trailer. Help
Cam Sensor and I've replaced them. and Im still having the same problemWhat code is the check engine light throwing when you scan it with a scanner?
This is what I found. ??? I didn't see a Towing Button. I don't know what this is. ThanksThere is a towing button below the radio try to push that button if it improves.
YesThis is what I found. ??? I didn't see a Towing Button. I don't know what this is. Thanks
No I didn't see anything like that.I know on the 3.8's there is supposed to be a paper shim stuck on the end of the cam sensor so it has the proper gap. Does yours have that when you installed it if the 3.6's use it?
At the end it says to disconnect the negative over night. I'm gonna try that. ThanksI just read about it and the 2013 doesn't use a spacer paper, but it says the ECM needs a relearn if replacing it.
Jeep Wrangler JK 2007 to Present How to Replace Camshaft Position Sensor
If your Wrangler starter is cranking longer than it used to, or continues to crank after you have released the key, this may be a sign th...www.jk-forum.com
No I didn’t reset it. But I have the battery disconnected now and I’ll reconnect it in the morning before work. ThanksI wondered if maybe you didn't do a reset, most of the time when doing electrical R&R you need to.
It was the Cam Sensor. I replaced both of them. I disconnected the Battery over night to reset the computer. I'm gonna pull the trailer to deer camp and mow. If the same thing happens I'll just unplug my trailer lights and hope for the best. And mess with it when I get home. Hey Thanks for Help. I've never been on a Forum before. This is cool. Thanks AgainWhat code is the check engine light throwing when you scan it with a scanner?
I tried to drive my Jeep to deer camp with my trailer and before I got out of town the ESC Light and the Engine Light came on and lost power again. I pulled over turned off the ignition then turned it back on the ESC light was gone. So I unplugged my trailer lights and it happened again just a few miles down the road. And another thing it seems to be happening at 70mph. Got off of the interstate and drove about 60mph and the ESC light didn’t come on. Any ideas????
Thanks, I cleared the engine light. so I'll have to try to pull the trailer again soon.Try doing what I suggested on my post no. 15 on this thread. https://wranglerjkforum.net/threads/2011-jku-sputtering-on-cold-start.26250/#post-427075
