I have a 2011 JKU that when the weather is cooler out it sputters on start. it gives me these codes P2100, C121C, U0401 and I have looked up all the codes. With that being said I replaced my throttle body actuator and had the dealership flash the new throttle body actuator in and though that fixed the problem. It did not so I limped it to the dealership and upon arrival I shut it off to have it looked at. When the service manager told me to bring it in I started it up and it ran just fine with no issues. Should be noted that the red lightening bolt and the anti slip come on and it goes into limp mode and runs rough and no throttle response.
The dealership could not duplicate the problem and they did not have any codes for it. I left it there and the eventually got to it and said when they started it after sitting in the warm shop it was fine and no codes. I took it home and the next day started it up and it ran fine. I was thinking they jiggled a wire and the problem was fixed for now.
The next day I started it that cooler morning and it did the same thing as stated above and I limped it back down to the dealership and they left it run because it was lunch time and they wanted the tech to too see what it was doing. When they shut it off they started it up again and is said that the codes were stored but it was running fine.
I brought it home and this morning it is 50 degrees out and I tried an experiment and started my jeep. The same issue popped back p with the same codes and red lightning bolt and anti slip light staying on. I let the engine warm up for 10 minutes and shut the jeep off. I then started it up again and it is running just fine.
I am looking for help on this issue I know it has to be environmental wand temperature related but I can not find anything anywhere on this issue.
I also had the catalytic convertors checked and they are fine.
2011 Jeep JKU
Auto transmission
3.8L motor
cold air intake, throttle body spacer ( both have been on for several years)
2.5 inch lift
magnaflow muffler
33" tires
2011 Jeep JKU
Auto transmission
3.8L motor
2.5 inch lift
magnaflow muffler
33" tires
