3 thermostats in 6 months
acproano
Arizona
Howdy. If anyone has any insight as to what I may be dealing with, that would be a life (and wallet) saver.
My 2014 Sport had the oil cooler pump fail in December. Replaced the entire cooling system due to oil getting in the radiator. So oil pump, radiator, tubes, thermostat, etc. replaced. Two months thereafter, starts overheating again. Went back to the shop and they warrantied it out. Then, again two months later—overheating, replaced yet another thermostat. Now, 6 months after a complete coolant system overhaul, I am in need of a fourth thermostat.
This most recent failure had some weird issues—high oil pressure, bogging down when I would have to accelerate quickly, running a little rough.
What could be causing these repeated failures?? Has anyone run into this issue before? Is my rig just cursed now?
I did replace head gaskets, trans hasn’t read as hotter than normal during the current mishap. Could it be the tans cooler even if it’s running at a normal temp?
Sure. Pressure in your cooling system is 16-18PSI. In your transmission lines, it's up to 200PSI. So if there is a leak, it'll be FROM the transmission INTO the coolant. So there's no real reason your transmission would get hot, especially with a small leak.
It's also entirely possible that you need to call an exorcist, or burn some sage, or something.
My Nut Bar dog girlfriends lab up the road is named Sage. And that movie again. Past post, I have no back up camera. All Good
Ever figure out your issue here? Having a new thermostat put in today, 4th one over the past two years.
Have you checked for any underlying issues with the engine or cooling system? Sometimes, a larger issue can cause repeated thermostat failures, like irregular temperature readings or contamination in the coolant system.
Also, double-check the installation process of the thermostat. If it’s not seated properly or if there’s debris preventing it from functioning, that could lead to premature failures too. Since you mentioned experiencing symptoms like high oil pressure and rough running, it might also be worth having the entire system inspected for leaks or blockages that could be adding stress to the thermostat.
Good luck with the new one! Keep us posted on how it goes!
