NineLives
I revived this thread last fall. I'm still trying to figure out what's wrong.I'm having the same issues now. I replaced the thermostat 2 times. Replaced the radiator (the coolant was dirty in the radiator), cleaned out the hoses, replaced with new coolant, and replaced the reservoir tank (the reservoir tank was leaking when the engine was running). I bleed the system using a spill free funnel and with the jeep on an incline. I then take the jeep for a test drive; the engine runs up to 240 most of the coolant runs into the reservoir tank. almost filling it up past the "max" level. The engine runs up to 240 for about a few seconds and then dropped to 208-210 and stayed there the rest of the drive. The next day I noticed the reservoir tank still had the coolant from last night's test drive. I drive the jeep again and it overheats up to 240 and stays there with the radiator fan running loud.
There is no milky oil and there's no white exhaust smoke, and there are no leaks when its running and when it's not running.
And the coolant is not boiling in the spill free funnel when I bleed it. Also, the radiator came with a new cap.
For the past couple of years, the Jeep would run hot around 215 to 230 on and off but has gotten worse in the past couple of weeks. The first time we replaced the thermostat, we had to replace the radiator fan as well (that was about 2 and half months ago)
This Jeep has been in off road parks some and some mud puddles (we stopped driving in mud puddles the 2nd time once we knew how much work we to do to clean it..) It seemed like the radiator fan kicked on more since those mud puddle adventures..
Right now, I'm thinking I need to replace the thermostat again, because the thermostat won't open until 215 (its labeled at 203)
AND why isn't the coolant not going back into the radiator? Why does it stay in the reservoir tank?
Please let me know if I'm missing something. Any help is greatly appreciated!
2015 Jeep JK Wrangler
An update on things done since my last post:
Replaced thermostat 2 more times. MotoRad. Can't find Genuine ANYWHERE. If a dealer says they have Genuine in stock, they are lying or misinformed. They have MotoRad also,but want to charge you almost triple what Advance Auto charges.
Oil cooler housing upgraded to Dorman aluminum. I did have an intake gasket that was shredded, so even though it didn't fix my coolant leak, it needed to be done.
Bubble test for radiator. Bought a kit from Harbor Freight. The dye went blue to yellow, indicating head gasket issues. That was done in February.
I am now at a point where the Jeep is essentially undrivable. I am refilling my radiator sometimes 3x a day, with the overflow coolant. The bottle is nearly full every time, to the point of spilling over. The radiator is nearly empty. When I transfer the fluid from bottle to radiator, it is almost exactly the amount needed....but sometimes I'll need to top off the radiator with a few more ounces of fresh fluid. This is from cold/overnight start and throughout the day after driving.
The temps start off normal when warming up or idling without having driven far. After sometimes only 10 miles from a cold start, the temps skyrocket to the 250s and stay between 258 and 280!! 2-8-0!!!!
I have not replaced radiator or water pump yet. Was just quoted $1200 to even get down in the engine to verify for sure head or block issues.
And I can't sell or trade the damn thing because I'm upside down on the loan.
Any input after all of this new info?
