Those of you with ADHD will understand the joys of a good "side quest".
It is a curse! But gets things done.
You managed way more room than I thought was possible on the ABS harness. All said, the booster swap is more than worth it.
I had to completely ignore the OEM push-clip retainers and cut them off... once I did that, I had enough room to "snake" it around and with the addition of that new push-clip zip tie, it stayed where it should. I did end up wrapping that section of harness with a few wraps of Tesa tape (the original tape fell off anyways).
Reactions: WSS
eBay is probably going to be your best bet for this. I ended up with Bestop core doors because of sticker shock with the OEMs.
finally getting the full doors off has finally inspired me to start looking for some OEM half-doors as well for summer driving...
I haven't thought about eBay, I just assumed shipping would be remarkably insane (even more than what people are getting for these half doors!).
I have seen a handful in my area go up for sale... with the rust eating Jeeps out fairly aggressively for those that don't maintain undercoat and clean during the winter, you see a few sets pop up from time to time. I am not so worried about getting ones to match the paint. Now that I have the sandblasting and powder coating place I like and can trust, I am sure I can find something he can use (even if just a semi-gloss black) to make me happy...
A quick look at listings shows about $4000 for two doors and two tops. Shipping varies to included in price or about $100 per door. I'm assuming these all come unassembled as well.
By the way, I was mistaken; I have the Element doors and shells, not the Core. https://www.motortrend.com/how-to/1707-bestop-jk-element-door-review
I see a handful of sets in the $3500-4000 range (this is for 4 doors, not 2) but very few sell. The ones that I have followed and that have eventually been marked as sold or deleted are in the ~$2200-2500 range. For 4 clean doors with keys and latches that work, I'd be willing to spend that much, especially with tops. Anything more than that, and I'll just use the Quadratec "bar doors" that I got with the Islander. Speaking of doors, I should probably look at getting some of those wall-mounts for them...
Trying to keep crossing off other items on the build sheet...
Before I built the 14B, I originally ordered both the UD60 front and rear axles together. While the UD front showed up in just a few days, the rear axle was "backordered" for week and weeks before eventually getting cancelled. However, in the time that it was still on backorder, Jegs very confidently told me numerous times that it was "on its way!", so I went ahead and ordered the Mopar-designed e-brake cables to go with said UD60 rear axle:
Unfortunately, Jegs eventually cancelled the order and I started working on the 14B instead. Some time ago, I noticed that the brake cable ends weren't going to work and I did some work to see if I could modify them to accept the Jeep/Mopar style "hook" end, instead of the GM loop end. After some Facebook back and forth with others, I ended up making a video about it:
With my interior mostly back together, it was time to see if the cables would actually be something usable. For some background, the OEM JKU cables are the same length (~78" each). The cables meant for the UD60 rear are two different lengths: 56052970AE is ~22" longer than stock (~98"), and 68002669AD is ~12" longer than stock (90").
As you can see above, one cable is a tad too short, and the other is a tad too long (though usable). I think this is because of the difference in where the caliper is mounted on these axles, and thus which direction the e-brake cable needs to be oriented. On the UD60, the cable enters the mount from the front of the vehicle. On the 14B, they have to wrap around to the back. I am honestly not sure why one would need to be 8" longer, but that's what multiple install sheets have noted to use. I am a little uncertain what the best course of action is here. They do still sell these cables on Amazon and from other Mopar parts dealers. I could likely get another ~98" long cable and run that in a similar fashion to the other one, though there may be some value in making some custom cable loops to help guide and keep the cable away from pinch and heat points.
On the other hand, I just recently learned about the "EPB Kit" from Range Industries:
These use 2019+ Silverado, Tahoe, or other full-size GM vehicle rear brake calipers with the electric parking brake motors built into them. They're also fully compatible with axle swap kits that use the tone-ring (like what I'm using). The kit isn't cheap, almost $500, and I would still have to find a pair of calipers (potentially hundreds of $$$). I've already got a few $$ sunk into my current setup (I had to buy new backing plates, hardware, calipers, rotors, etc.). That said, I'm not entirely off the hook for spending $$, as I would still need to buy another 98" Mopar cable ($200) and a new Mopar brake lever (~$150), as mine has a fairly worn clutch. I could potentially recoup some of the $$ by selling the brakes, as many people in the area have GMs with 14B's and many off-road rigs are running OEM disc-brake AAM's. Decisions, decision...
Speaking of decisions, one was made for me. As I was attempting to drop my gas tank (I was tired of the rust from the bottom of the skid plate constantly falling into my eyes when I was down there), I ended up snapping off not one, but two of the vent fittings on the tank. What gets me was just how absolutely careful I was being while I was dropping this - knowing just how fragile these are - and still broke two of them 😵‍💫
I was a little on the fence about my justification for going with something like the GenRight or Motobilt Rear Gas Tank Conversion to support future rear suspension modifications, but this sealed the deal for me. Looks like I'll need to message my buddy Steve at Offroad Elements soon and get the tank shipped out (I'm not sure if there's a lead time or not).
At least now with the gas tank out of the way, I'll be able to run the wiring down the side much easier for the rock lights. One I get the engine bolted in place, I'll be able to get the battery tray installed and can start working on the rest of the auxiliary wiring.
I really like how low and sleek the MSD relay box is
Oh, and I found a spare 8HP70 that came with a lot of parts necessary for an 8HP + Hemi swap... you know, just in case I get an itch to make the Islander more fun :)
Looks like Baseline has some at the higher price point...
https://www.facebook.com/share/14VcVmPt369/
Gatekeeper Offroad UD60 Knuckle Pod Bracket Install
I'm waiting on some other parts to arrive for the engine swap, so I'm getting done what I can. I ordered these Gatekeeper Offroad Steering Arm brackets a few weeks ago. I was on the fence about them for a little bit, as they seemed a little "gimmicky". However, everyone that I talked to that has them absolutely loves them. When I saw a set on a plow truck not too long ago, the light output seems to be in the perfect spot for hunting/nighttime trails. I decided to take advantage of their holiday sale and got a set.
Their shipping was quick and the brackets were nicely packaged. I had some free time yesterday and I got to work on getting them installed. The passenger side is easy for the UD60 application; you simply unbolt the steering arm nuts, put the bracket down, and then tighten the nuts back up. Gatekeeper doesn't provide a torque spec, and there's nothing in the UD60 literature that gives a torque spec, but based on some other aftermarket steering arms using identical bolts, I went with 90 ft lbs.
The driver side takes a little more work. You can either tap the knuckle and install bolts, or simply weld them straight to the knuckle. For future ease of maintenance, I went with the drill and tap approach...
Tapping cast steel for 1/2-13 bolts is bit of a pain, but it went smooth enough. Once I get the engine fully in place, I'll get the wires run for these...
I ordered these Gatekeeper Offroad Steering Arm brackets a few weeks ago. I was on the fence about them for a little while, as they seemed a little "gimmicky". However, everyone I asked about them has loved them.
I've debated getting a set for my truck. I've had the same feedback from people who have actually used them - nothing but positives.
Reactions: pc1p
I'm still waiting on some parts before I can drop the engine and trans in place, so I'm working on what I can. In preparation for the Motobilt Rear Gas Tank, I went through the installation instructions from their website. I haven't ordered the tank yet, simply because I don't want to be tripping over it. However, once I get the engine and trans dropped in, I'll be able to clean up a significant portion of the back of the garage and will be able to order (and store) it then.
Anyway, the instructions state to cut off both exhaust hangers in the rear (for the OEM muffler). The process was easy and only took ~10 minutes for both sides. The original plan was to use a cut-off wheel, but due to the angle and location, I ended up using a Diablo metal cut off blade on my reciprocating saw.
Ta da! A quick hit with a flap disc got it smooth, then I hit it with a short shot of primer and paint.
I did the same with a broken exhaust hanger bracket on the frame near the T-case. I'm not sure if the JSS Headers + Exhaust kit will use that hanger, but it was literally just a stub, so it wasn't doing much at the moment anyways. After I was done working on cutting the stub mount off (which also was easier with a metal cut off blade instead of a cut-off disc), I started marking where I need to clean up the frame so I can weld the OHF Frame Reinforcement Brackets on:
There's BARELY any thread engagement with the OEM bolts, so I need to get some longer ones before tightening them down (so I can weld them in place). My mounts are fine, but a lot of folks have issues with the brackets cracking, especially with a V8 and skid plate whacks, so I'm proactively tackling these before they become a problem.
Turning back to the front end, I got the Rigid Pod Lights (on the knuckles), front ABS sensor wires, E-locker wiring, front axle vent tube, and brake lines secured and bundled together. I just ordered some USA-made PVC covered 14 AWG/2-conductor wire and will get the wires run to the relay box shortly. My plan is to use a few DT 2-pin connectors so they can be quickly disconnected for service and deep cleaning...
Hopefully the rest of the parts show up soon so I can get the motor and trans in. I still need to:
- Measure for driveshafts
- Modify t-case shifter bracket and clearance transmission "rib"
- Get the battery box in and start making my battery cables
- Re-loom some of the remaining factory harness (I need the engine and trans in place so I can remove the ratchet straps keeping the front end sucked down)
- Finish the install steps for the Motobilt tank (i.e. cut a big a$$ hole in the back), modify the filler pipe, etc.
- Relocate the EVAP, run new lines to EVAP canister (from tank), and run new evap and fuel lines to engine
- Find good locations for the KC Cyclone Rock Lights
- Order some inner fenders that aren't horrendous
- Run the new harness, ECM, fuel lines, etc.
- Modify the shifter bezel to accept the JSS one, while also putting in a "sport mode" button
- Clean interior floor, install sound deadener and new carpet kit
- Thoroughly deep clean the seats again
- Align steering
- Bleed ABS and brakes again (since the J8 install)
- Hook up the KBD flare "turn signal" lights
- Recheck and cross-mark all suspension bolt torque, including the control arm lock nuts
I'm still ahead in terms of overall progress and should be done well ahead of the May deadline, but I'd like to get this thing mostly assembled so I can work out the bugs with plenty of time and without rushing!
Reactions: WSS
If you wait long enough on the : Bleed ABS and brakes again (since the J8 install), they may self bleed (unless abs was evacked). Twice now (on two builds) I have been lucky or at least surprised to find no air in the system. To be fair, I did remove the abs on my 2000 TJ. The other was a '72 CJ5
Reactions: pc1p
Spending a few days in LSD (Lower, Slower Delaware), so per my normal MO, I scoured the local Marketplace listings before I left. I found a set of super nice (albeit very dusty!) Bestop soft half doors for a killer price. The frames are in perfect condition and with a decent scrub, these will work well until I can find a set of true Mopar steel half-doors.
Not too far from where I met the guy with the half doors for sale, I found a guy selling some Jeep parts, including a full set of OEM Mopar door hinges. As you may remember from a post a little earlier, my pins are in terrible condition and most of the threads are damaged from having to beat them off. I'm going to confirm that these fit as they should, and will then have them painted, or perhaps powder coated. The guy also had a like new EZ 4x4 4-door door cart, which is exactly what I was looking at earlier in the week - half price and already assembled? Yes please!!
As I was coming back from Philly a few weeks ago, I forgot that I picked up two sets of GM rear calipers with Electronic Parking Brakes. I have been talking with the guys at Range Industries about their 14B EPB Kit. Turns out, they're reworking the design a little, specifically to work on JKU 14B swaps. I'll give them some time to work up a new design and have offered to help beta-Test it for them.
GM has two very similar EPB calipers, one used on SUV's and one used on the 1500-series pickup trucks. They're essentially identical, the only difference being where the brake hose attaches. I got a set of each from a guy that runs a shop in Philly, where many of his clients install Brembo kits. Both of these sets are like new with less than 100 miles on both!
Despite the single digit temperatures outside, my garage is a balmy 56 degrees. I cleaned up the OHF crossmember reinforcement brackets and gave them two thin coats of Seymour Paint Thru Primer, before fitting them up. Like I said in an earlier post, my crossmember mounts aren't cracked but even on a stock rig that doesn't appear to ever had any serious wheeling done, the OEM brackets have a slight bend in them:
I took my time and straightened them out as much as I could, then installed the OHF reinforcing brackets to give as much leeway as possible to get the bolts centered. Overall the process was easy, especially with the engine and trans out of the way, but it's still not an easy spot to weld while you're hunched over underneath the tub.
Knowing how thin the frame on the JKU actually is (~1/8"), I took my time and did some stitch welds around the perimeter of the brackets. In some spots, even with the bracket completely flush against the rail, there was still some raised edges, due to the factory welds and joints. I smoothed all the high spots out, but the low spots required a couple of passes to get enough build up of material in the joint to get a proper weld to the bracket. I could have beveled the edge of the brackets a little more than I did, but I was still able to get it done just fine, despite doing "Welding Yoga" underneath.
Everything welded up and cooling down! When I'm back in town later this week, I'll hit the high spots with a flap disc and hit everything with some Eastwood Chassis Satin Black. Overall, I thought these were going to be more of a pain in the a$$ than they were, but I only had about 2 hours into the install. I'm sure if the trans was still installed, or if the insulation was still there that it would be slightly more of a pain, but even still, these aren't too hard.
I've been going back and forth about what light to try on the rear AEV carrier. Not wanting to buy another set of lights that ultimately won't work, I found this single light at Harbor Freight when I was picking up a few boxes of nitrile gloves. For $22, it's essentially a knock-off copy of the Rigid SR, and will let be figure out how I may want to mount/modify a Rigid (or if one would even work well here!). Again, this isn't a back-up light, more like a rear mounted work light, letting me throw some light on a trailer or campsite. I'll be running some wires back here this week, once my PVC coated 14AWG wire shows up!
Obviously the tire will block some light, and especially so when I go to 40"s, but this will give me an idea of how much and how I may need to modify. I'm already thinking of some options for that post, potentially making a basket/solar mount for up there. Either would give me some real estate to move the light rearward and let me angle it down more (if needed).
Reactions: Cimmerian
