I am not sure with the Hemi but I removed the EVAP canister completely. It's not needed in the LS Swap.
For sake of emissions compliance (now and in the future), and not wanting to deal with fuel vapor smells in the garage, I'm retaining the EVAP for sure. This is actually quite an easy process as the JSS Swap Kit integrates the EVAP control into their kit.
I forgot you are in a state that has emissions testing/state inspection. I actually do not get any vapor smells in the garage......because my wife keeps her vehicle and the golf cart in there. If I have my toys at home they say in the driveway.
Reactions: pc1p
I went with the MetalCloak Aluminum Fender Flares. They are SOOOOOO light!
I've thought about them - I have used MC flares is in the past and loved the quality (though the powdercoat does leave a little to be desired). I really like the thought of using aluminum though something simple like the KBD flares are also quite appealing.
I picked up a cheap set of Bushwhacker Flat Flares a while ago, but something about them kinda irks me at times. Sometimes I think they look great, then sometimes I think they look like batwings flying through the air... I don't know - I may just install them to get them out of my way and give me something in the short term, but long term I may still find a different option. I do want to go with some aluminum inners and want to pick up some on a Christmas Sale, though I wish there was a nice option without a STUPID F&*$%# LOGO ON THEM!!!! Seriously, for any company making Jeep products out there that read this - don't put your stupid looking logo on your parts, or at least offer a logo-less option. I don't need a giant "A", "MC", or whatever on any part on my Jeep.. ever. Like, never, ever...
I had a set that looked like bat wings. If I could go back now I would go with the smaller ones or just delete them. MetalCloak is having a pretty large sale, but they are still not cheap, plus they want +221 for the power coating, But it is a very good powder coating and has held up very well.
Reactions: pc1p
As a full time Environmental Compliance Manager, I will say that eliminating EVAP is a violation of federal standards, but will leave it at that :)
At the state level, you can usually get away with a lot, though I am always reminded of when I lived in Arizona. The state was known for having zero emissions testing and many Californian hot-rodders would get a PO Box or use a friend/family members address for registration. Then, when Maricopa and Pima Counties were having non-attainment issues and faced losing their federal highway funding, they implemented some heavy requirements.
I had just put a big-block into a D200 Dodge project I was working on and got the notice in the mail saying that as a Pinal County resident, I was now required to get emissions tested as well. There was no way my truck was going to pass the emissions inspection (it did not have the OEM air pump and EGR, so would automatically fail), even though it would have passed the roller test. I sold it to a guy who lived outside the area and wouldn't have to worry about it. There was some getting around the testing requirements for a while (using a PO box for example), but the ADEQ got smart to that and would require a physical address on all registrations. Unless you knew someone who could send you mail from their out-of-range location, it became harder and harder.
Even when you tried to comply, like in the case of my YJ, you often had to deal with some nonsense. My YJ had low miles, a perfectly running 4.0L, and a brand new cat, but every now and then, one of the guys running it on the rollers would fail the test because he missed the up or downshifts, which would cause him to lug or overrev and throw off the results (it was quite a narrow window!). There were at least two times that I ended up doing the "driving" during the IM147 roller emissions testing because the person didn't know how to properly shift...
Thankfully in PA it's just an equipment visual and simple OBD-II check. As long as you have the necessary equipment (cats) and your CEL works but is not on when the engine is running, and your gas cap passes the test, you're good to go.
I've had two sets of MC flares with MC powder coating... in both cases, they developed a small rust line where the tub meets the flat steel section of the flare. Granted, these were the steel versions. If I went with the MC flares this time, they would absolutely be aluminum...
This always annoyed me and is the primary reason (besides that I genuinely like how they look) that I went with thermoplastic MCE fenders. I left my inner fenders off but I do have a set of aluminum ones that are unbranded and don't have stupid shit like flag or skull designs on it.
Reactions: pc1p
Which ones did you go with?? I can't seem to find a set I like that don't make me look like some Truck-Nutz sporting d-bag... :ROFLMAO:
I have been looking at these, but they're expensive for what they are, and I still can't figure out who actually makes them: https://www.extremeterrain.com/jeep...kit-bare-metal-j0054407.html#customer_reviews
Honestly? Some cheap shit chinesium off eBay that was probably like $40 shipped. It's just an aluminum plate to cover a hole, didn't need anything fancy.
E: am I reading that right? $670 dollars?!?
Reactions: pc1p
Well I did not put CATS back on after the swap. I know its not great for the environment that way. Here in SC there is no inspection or emissions. If you run into the wrong police officer they can give your vehicle and "inspection" if you get pulled over for another offense.
Reactions: pc1p
Yeah, almost $700 for some bent sheet metal!!! It's the style that I like (simple!) but ridiculously priced. The ones you shared are perfect - I'm gonna check into them now actually...
I found these on Amazon, similarly priced: https://www.amazon.com/JMTAAT-Aluminum-Fender-2007-2017-Wrangler/dp/B082SCGK9F/?tag=wranglerorg-20
And apparently we're not the only ones wanting a simple option lol... these indeed are hard to find, these are on PAGE 3!!!!
This is all perfectly timed too, because as soon as I mentioned "I might install them" above (talking about the Bushwhacker Flat Flares I have), someone responded to my Facebook Marketplace listing and came and bought them. I just ordered the KBD flares with their current 15% discount code. Even though they won't cover the tire, I don't anticipate any issues with the state inspectors or local PD. If I get an issue on drives down south, then so be it. However, the more and more I spend time driving down near Philly (my daughter goes to college about 30 minutes away), and across the center of the state, I see soooooo many Jeeps with tons of tire sticking out that I'm not really worried about it anymore.
My OEM gas tank skid is rusted to shit and needs replaced…
I’m toying with the idea of spending the $500-700 I would spend on an OEM replacement for a rear-mounted setup. This would be in anticipation of an eventual 4-link setup, which I’m leaning towards anyways.
Current contenders are the Motobilt setup and GenRight setup:
There’s about a $1000 difference between the two. The GenRight setup uses OEM evap parts and looks to have some other advantages, but I’m not sold it’s worth the $1000 price difference.
Anyone use either of these???
Boy am I glad I waited to order my PSC stuff - I placed an order through Offroad Elements (if you call, ask for Steve V.!) for the PSC stuff I need. Not only was I able to take advantage of some holiday sales, I got no tax and free shipping! The savings were almost $1000 over normal retail (+tax and shipping charges)...
Everything should be here Friday - which is perfect, as it will give me some things to do over the long weekend!
I got the OEM engine mounts cut off the frame (see the process here). It's not bad and can be done in about an hour and a half...
All the PSC parts came in, though they ended up coming later in the afternoon on Saturday instead of Friday. I promised the Mrs. that I'd help get the Christmas decorations up, so I only had time to get these brought in the garage. I have a work trip this week, though with the storm headed towards the upper mid-Atlantic region on Tuesday, I may be cancelling that.
The only thing I'm really waiting on now is to order my JSS swap parts. I'm waiting until tomorrow to see if any Cyber Monday deals pop up. If not, I'm ordering everything, including their headers and exhaust kit. I was going to try to make the Mopar Performance manifolds work, but the more I look at them, the more I see that they're going to be an issue long term. Saving a few $$ at this point seems moot, especially since it will add a bit of complexity to this build (and I no longer have a good, old-school exhaust shop nearby that can make me something nice!).
We had some more 2WD weather (my TJ Forum folks will get that reference) and I'm happy to report that the 4WD on the Islander works perfectly.
As expected, the TrueTrac gave lots of nice, reliable, and consistent traction, even in 6" of fresh, powdery snow.
I got the PSC Big Bore bolted in place:
I took the time to clean and paint the frame behind the steering gear. It was pretty clean to begin with, just a small touch of surface rust inside the little "window" cutout in the frame. The Big Bore is noticeably heavier than the factory box, making it slightly unwieldy to install solo, but I made it work. I can’t imagine trying to do this with the radiator and other stuff in place, it’s tight in there even with it all torn apart!
You’re gonna need a 46mm socket to get the pitman arm but torqued down. PSC doesn't include instructions, so you gotta dig around with their install instructions. PSC says 220-225 ft-lbs of torque on the Big Bore Box 30mm shaft.
My factory steering shaft coming from the firewall down to the box is VERY stiff. Smooth, but very stiff. I will try to clean it up, perhaps there's just some gunk built up, but I'll probably find a replacement since I'm this far in…
I'm waiting for tons of parts to show up, so I'm trying to find things to keep me busy... I'll need to clearance the firewall to allow me to use the steering shaft pillow bearing relocation bracket, which would be easier with the booster out of the way. Since I need to update the master and booster to the J8 anyway, figured I might as well get started on that.
The process is easy and there are a few good videos on YouTube that show how to do it. Here's one from Eric Cantin:
Eric's video does a good job of showing not only the step-by-step, but also some important things to be mindful of. He actually damaged a Mopar J8 master cylinder because of misalignment during installation. This is not only costly, but problematic if you're trying to use OEM parts as they're nearly non-existent anymore.
In Eric's video, he also really struggled with the pushrod retaining clip. You can tell he was getting frustrated, so let me show you exactly how to take these clips off in case you ever need to. These clips are used in Dodge and Jeep vehicles for the past 30 years, so if you're working on Jeeps, you may run across them at some point. They're super easy and when you get the clip off, you realize how simple but effective they are. To remove, simply insert a small flathead screwdriver through the clip itself, UNDER the tab where the red arrow is pointing below. You lift up slightly, allowing the tab to ride over the stud on the brake pedal post. As you lift up the tab, you slide the entire clip up (in the same direction as the red arrow) and it slides right off.
My brakes were working fine, but the move to the UD60 and 14B axles necessitates a bigger option. The Mopar J8 kit is hard to find, but I snagged one not too long ago from someone on Facebook. I'll save my OEM one in case my daughter's Jeep every needs a replacement.
There was almost a quart (yes, a quart!!!) of engine oil inside the booster. I've seen oil in boosters before, usually very small amounts from PCV blowby or similar. This one had a bunch... I guess +209,000 miles will do that!
My seal against the firewall was TIGHT!! I needed to use a breaker bar in a few spots to slowly lift one corner up, which I then switched to using my fingers and small screwdrivers to work completely around the gasket (trying to keep it reusable, as the J8 kit does not include a replacement).
Side by side on the bench, the J8 looks bigger but not ridiculously so. It's tight back there and even getting the OEM booster out was a pain in the a$$.
Reactions: Cimmerian
