What's leaking in this photo?
jojo
Arizona
To make a long story short, I'm fighting breast cancer and definitely struggling to stay afloat so going to a shop is a no. I don't even know what the part is that shows a leak and sounds like something is broken if I attempt to drive. I am going to have to attempt to do this on my own but I need any advice I can get on what to do. Thank you
Appears to be a rear differential seal leak. It could also be the pinion gear seal.
I'm being honest when I tell you this is not something I've had any experience with, but there will be plenty of help following behind me.
Reactions: jojo
Looks like the pinion seal. Doesn’t appear to be leaking too bad as it isn’t throwing gear oil around on adjacent surfaces. Is there any on the ground after you are parked for a while. If not, while it needs to get fixed seems like it would be okay to drive, but keep an eye on it.
Same as @Anybodyhome I’m no expert, just doesn’t seem to be that bad of a leak provided there is not any drops / puddles in the ground.
There's nothing on the garage floor, it sure sounds bad though. Thank you for the info
It shouldn’t be making any noise. Are you sure the noise is coming from the differential? Is there any play in the driveshaft?
I Asked a guy to check to see if everything was tightened under it and he said it was. But yes each bump brings a noise and vibration, kind of like a clunk sound when it goes over any bumps, even at a low speed, sounds like something is broken or going to fall off.
That seal leaking slightly won't cause that noise, did anyone check the oil level?
Bumps causing the noise and vibration would be shocks, wheel unit bearings, skid plates.
Reactions: pc1p
Nobody checked the oil level, I am having trouble with doing much on it, I had a double mastectomy and I'm limited on reaching ECT . Yes I worry a lot about possibly the wheel bearings. My Drs are over an hour from me to get to and it wouldn't be good for a bearing to go when driving on the freeway.
If it's bumps and jolts that cause the noise, getting it up on a rack would allow someone to recreate it. Moving wheels, axles, shocks, driveshafts, etc. to locate the source of the noise.
If it was the pinion or rear end, it would be making noise whenever the drive shaft was rotating.
Reactions: Danarch
On turns it wobbles hard, even in town on normal turns, I'm not sure if that's what you mean?
That would be your front suspension, turning could mean the wheel unit bearings or anything associated in the turning process.
Reactions: Danarch
The leak is minimal but also very recent as no dust or dirt stuck to it. Any new play or wear could cause the seal to oblong/deform and let a little fluid past it.
Does the noise change with acceleration? If not, then it is probably just a dry or worn seal starting to weep. If the noise does change on acceleration, it could mean some damage internally in relation to the pinion, maybe a wearing/broken bearing.
Update: no leaks apparently, I went to three different shops and they are saying the suspension is ok. Two of them mentioned the winch, not connected right and looking at it, the cable doesn't look like it's wound up right. I bought it with the winch on it already, I want to take it off but I don't have a clue how to and if I did, well I couldn't do it anyway with my health. Is there anyone on here by casa grande?; that wants to help me with it? After the winch is off I need to get the battery replaced. It's been a month of one thing after another on it .
This is probably the dumbest question but I honestly don't know what to do, I need a new battery and I'm wanting to remove the winch, Walmart automotive said they won't put in a new battery if I'm going to remove the winch, until after it's done. Couldn't they just install a new battery and not reconnect the winch? Or would that really cause problems?
If they aren't morons they can put in a new battery and just not connect the winch.
Thank you so much, I think I will just go to a different Walmart automotive, I couldn't figure out why the guy told me it couldn't be done, he said it would destroy a new battery if it wasn't done in that order.
