Does that apply to anti rock style sway bars too? The reason for asking is I have a coilover swap coming up and "longer" sway bar links are recommended. I already have the teraflex swaybar system matched to my 4.5" lift. They sit a little high, maybe 2 degrees up.
The previous owner put spacers under the sway bar instead of adding proper length sway bar links or quick disconnects when the lift was installed. Looks terrible once I saw it on the lift. Not really a priority but they are 100% too short and can be done right for cheap.
When the axle was flexed the stock length links were really stretched out at a wierd angle. Im going to install some cheap adjustable length quick disconnects and get rid of the stock parts.
