Awesome! Thank you!Where is the grommet that goes inside the Jeep outside?
Okay I’ll look for that. I’m trying to get my cb wired in lol that is the last part to do.It's where the big wire harness is that goes into the cab.
Okay that works better. More accessibleThere is a grommet on the drivers side, below the brake booster.
If you remove the side dash panel, you will see a foam-filled passage. This is the passenger side, but it's on both sides. If you stick a rod or some such through this, it comes out right at the top of your battery. I find it a lot more accessible.
Okay awesome. I’ll do it TomorrowI poked a hole in the foam to the right of the battery. It leads to the dash, remove the side dash panel and you can access if from there. Easy to do.
That is the best! Thank you!!!Here is a video of the area.
