No brake light or turn signal
chrispeel2001
Denton, TX
Got the quick flash on my turn signal. Turns out the rear turn signal bulb was burnt out. I replaced the bulb with a new one and it still doesn't come on. I replaced that bulb and still no turn signal. The bulb lights up when I turn the lights on. I also found out the same bulb isn't lighting when the brake pedal is depressed. I check M18 and M17 and the fuses are fine. Anyone have any ideas?
I’d check the ground. Was it replaced with a standard bulb or LED? If LED bulb I’d pull it and put in stand bulb.
