Got the quick flash on my turn signal. Turns out the rear turn signal bulb was burnt out. I replaced the bulb with a new one and it still doesn't come on. I replaced that bulb and still no turn signal. The bulb lights up when I turn the lights on. I also found out the same bulb isn't lighting when the brake pedal is depressed. I check M18 and M17 and the fuses are fine. Anyone have any ideas?
