how much does that cost?
Fluid Film is reasonably priced:
https://www.amazon.com/dp/B00CLTXPX2/?tag=jkforum-20
You'd probably spend $50 each time you did it, and I would suggest 3-4 times a year, more-so in the Winter months of course.
my guess would be you are thinking of checking transmission fluid (oil) levels. Unless there is some new design for how oil is moved about in an engine, checking the oil when it has pooled into it's home of the oil pan is how manufacturers design the hash marks on the dipstick.I noticed it looks like the whole bottom of the oil pan comes off, the gasket there seems to be seeping a bit, has anyone else experienced this? Is it an easy gasket swap?
also, do you guys check your oil with the engine running or no? I thought I read somewhere that some car manufacturers recommend checking oil while the engine is running, but I’ve never done it that way.
Brake fluid Flush. I'm in the middle of replacing front calipers and decided at the same time replacing all (4) brake hoses with SS. When I Turkey bastered out brake fluid from the reservoir It was dirrrrttty. What I'm bleeding is also dirrrrttty. The new in is Clear. The old out is Black. I'm sure it was never changed in the 11 years of life and probably contributed to my sticky caliper problems.
