F
FLGeezer
Guest
Weird issue cropped up today on my 2009 JK. Left turn signal started flashing fast indicating a blown bulb somewhere. Rear is fine. Front off. Replaced the bulb (not LED) although the old one still looked ok. Tested it and it worked fine for about 5 or 10 seconds then quit. Rear still flashing. Tried again and before it died I Jiggled the bulb socket/harness thinking to see if it was a bad wire somewhere but it stayed on....for a few seconds.
JScan shows code B163C "front left turn lamp control circuit high". Did some Googling and searched here. Not sure on anything. Flasher relay maybe? But rear is flashing.
Ideas? Thanks.
EDIT: Ordered a "Dorman 645-118 Three Terminal Lamp Socket" from Amazon. Will see if that does anything.
Ideas? Thanks.
