Anyone else know about this? Am I late to the party? I just came across this video.
Basically, if you hold the skinny pedal down while cranking, the engine won't fire but it the oil WILL prime. Release the ignition, release the pedal and then crank as normal and engine starts.
Down side is the starter has a bit more stress, but starters are cheaper than engines. This sounds like a great trick for those cold winter mornings...
