J8 booster talk
Reactions: WSS
Buying two right now!
How in the world do you find this stuff? You would make a excellent purchasing agent for just about any industry.
20 years in the Navy, a law degree after, multiple residential construction trade inspector licenses & housing code inspector.
Quick thinking on my feet- i just used it to my advantage for 55 years.
I'm retired now, so I have time, lol, but thanks for the compliment.
Reactions: WSS
I hadn't seen discussions about using spacers. Why are they needed? Granted, it's been a few years, but the info I saw didn't discuss the need for shims.
I did read a suggestion of trimming the non-threaded parts of the mounting bolts to give clearance when installing.
I watched this video a while ago, which I felt was pretty solid - although I think he ruined the booster in the process. It was a cringe moment when i heard the sucking of the fluid, for sure. He also didn't do the ABS bleed, which i do believe is necessary after reading up on it more.
I don't think I'll be able to keep my visit compressor mount. Even if I adapted the mount, I'm thinking clearance won't be enough for it and the relay box I have.
The rod on the old booster was .255" longer than the new J8 booster, the rod is not adjustable like my older rigs. This is a non issue 2012 and up, the early JK's used a shorter rod. Sometimes, it was just right or maybe a washer or two. I just took the JK for a test drive and the brakes engage right away, better than before with less pedal travel. The brakes release easy with no drag when my foot is off of it, so I hope it's all good.
I did not have to do the ABS disable (either time, I will get to that) because I did not run it without fluid, or "dry". The first bleed was very little air, as the bench bleed was solid and I plugged the lines as soon as I pulled them from the MC. I went back over the flare nuts on he MC due to them being a little wet on the bottom, there was my issue, the flare wrench slipped of the nut and rounded it. due to the small leak, I had to repair it. This was interesting. the tube and the thread are SAE, the head of the flare nut is the only "metric" part of it. So I cut about 3/8" off the bad end, put a flare nut with a 7/16" head and re flared it. I would have bent up a new one but the other end is a bubble flare. I do not have that tool. I did however buy 2 bubble flare to inverted flare adapters today at Mc Fadden Dale hdw. So, if it happens again, I can bend up my own for about 15 bucks.
I did two types of "bleeds" twice. First was the vacuum pull with my mighty vac and second was the 10min gravity bleed. No air for sure anywhere in the system.
I watched that video many times. Mostly so I would not trash the MC. That was "cringy". Poor guy. the brakes work way better than before. It has corrected three distinct problems, 1) the brake pedal does not pulse on downshift anymore, that was likely due to the o ring not being seated correctly. 2) easy stopping with light foot pressure on the streets, no more slick feeling brakes. 3) I can definetly bring the beast down quicker, way quicker, I can hear the rubber growling with the window down now.
VERY happy (right now lol). So far very good. Worth the effort on this project.
Hi, I'm in the process of trying to do the J8 swap. I had ordered everything a few years ago, then got delayed because the master cylinder Jegs said was in stock wasn't... for a couple years! So I finally have the master cylinder and booster, but now that I finally have the master, I found out I got the wrong reservoir! Does anyone know where to get a J8 reservoir? Every place I look shows them as out of stock.
My Jeep is a 2018 JKU on tons. I've put over 30k miles on it with the tons and stock master cylinder, but the pedal travel is very long. I'm hoping to finally get this part of the project completed.
It is a worthwhile project. Fixes the spongy feel and the long push.
I bought this one:
I bought this one:
[/URL]
Well this was a fail. I ordered the reservoir and finally got the correct one, thank you WSS. Last night I installed everything. Of course the engineers decided to use flanged nuts with flanges larger than the access holes in the firewall, so while the aluminum mounting plate was out I enlarged the holes, "just in case I have to do this again". It was a great idea. I got it installed which was pretty straightforward once I clearanced the holes. It was dark so I held off bleeding until today.
I went to bleed the system and just couldn't get a good pedal. Then I noticed fluid dripping from the master cylinder. It was coming from the line fitting at the back of the cylinder. I checked tightness and gave it a little extra, still leaked badly. I removed the fitting and the flare looked fine, but I noticed a bit of indication on the first couple threads of the fitting that looked like it was binding. I pulled the master back off and...the threads were never machined to the full depth! The fitting is bottoming before it can seal.
Now after nearly 3 years of waiting and fighting to finally get a master cylinder, it's junk. I'll get on the phone to Jegs and see if they can send me another. This weekend's trail ride is out. Hopefully there is another master available. Otherwise I'm cutting my losses and might go with hydroboost, since there doesn't seem to be any other options any more.
  • Sad
Reactions: Cimmerian
