Factory Grille Insert Replacement
mattybrass
Wakefield, Mass USA
I have a 16 JKU Sahara with the silver grille inserts/headlight bezels which i dislike and want to replace with black ones. I found black bezels for the lights so that's not an issue but for the headlights I've heard all of the ones available on Amazon are only if you don't have factory inserts. I found these, Mopar Black Inserts and it looks like they will work but I want to see if anyone knows they will work for sure as I'm sure returning them would be a huge PITA. Pic below of the current inserts
I would suggest doing this with some of the rubberized paint that can be pealed off if you want. The stuff is more than strong enough and in my experience less prone to chipping than standard spray paint.
That being said, I'm sure your buddy with the autobody shop knows how to do it. I'm just suggesting a non permanent option.
