Replacing my son’s catalytic converters. The existing system has a heat shield on the cross member. The new one does not and comes in two pieces and joins up at the Y into the exhaust pipe to the muffler, so certainly need to install it all then have the heat shield welded on. Do any of you have a thought if the heat shield should be reinstalled / required to be installed? If so will take to a shop to weld it on, I am not going to try and mess up the system spent 3K on (good old CA). If it should be put back on we will need to wait to re-install the skid plates.
