I have a 2008 Jeep Wrangler Sahara JKU with the 3.5 Inch Metal Cloak Gamechanger and I need help.
After hitting a small-medium bump, death wobble begins between 40 and 60km/h (25-37mph), most commonly in the 50km/h (30mph) range.
Once it begins, I reduce the speed to under 40km/hr and it stops.
While the movement is side to side, my front tires are also bouncing up and down.
When driving normal roads in 4WD (winter) it takes much larger bumps to do it, but when it does the back tires get involved.
Note: Isn't death wobble normally at higher speeds and only side to side?
I have replaced:
At this point, I do not know what to do or what could be causing this… any input would be GREATLY appreciated!!!
I have replaced:
- Steering dampener (with a stronger one)
- Tie rod and all ends
- Drag link
