Please read the full list of solutions I’ve already tried before offering a recommendation. I’ve tried a ton of things.
I have a 2018 JKU.
When I slow down, braking and turning, like into a driveway or parking lot, I get a hard vibration in my brake pedal. Happens when brakes are 1/4 to 1/2 depressed. It recently started happening when not turning.
It’s not like an ABS vibration. It’s not as rapid. It’s harder and clunkier.
No warning lights. The only code I have is B2204 ECU configuration mismatch, which I don’t think is related. Maybe?
These are all the things that have been done:
New front and rear track bars
New tie rods
New ball joints
New rear brake pads
New front and rear wheel speed sensors
New front rotors, calipers, brake pads
New front wheel bearings
Upgraded front brake lines
4 new shocks (Fox 2.0)
Upgraded sway bar links
I also can’t see anything rubbing anywhere.
I’ve crawled under and yeeted every nut and bolt I can find on the front end.
My CV joints, rear rotors and rear calipers are good.
What am I missing?
I have a 2018 JKU.
New tie rods
New ball joints
New rear brake pads
What am I missing?
