Ok whole lot of info to dump, but at my wits end and ready to let the Hurricane take it away!
Bought this Jeep in June, as of day 2, code gremlins began.
Misfires in Cyl 3 & 5. Replaced plugs, coils, & fuel injectors. Still was misfiring and also started getting air/fuel ratio imbalance bank 1. But all codes would randomly clear themselves. Researched on here and started swapping sensors: Manifold absolute pressure sensor (map), Camshaft position sensor, Crankshaft sensor, Air charge sensor.
All was good for about a week, misfire codes came and went. Then got code for closed circuit injector 5 (sorry can't remember code). Was set to take to a shop that specializes in electrical/diagnostic when it went full limp mode while driving. All codes cleared but new one came up U110B.
Thinking a bad TCM could be cause of all the code gremlins, bought a new OEM, had it flashed to my VIN. Programming took, but when went to start, Auto Shut Off relay began clicking and drained the battery. Checked here, most said a bad battery could cause. New battery, issue remains. Won't start and can't keep power long enough to grab codes.
Like I said, ready to let this hurricane have it!
Any ideas??!! Many thanks in advance.
