142k on the clock. A few weeks ago the Jeep cut off no power inside at all. The only added feature is a couple of lights; they came on. This lasted like 20 sec (like a breaker reset). Clock & computer reset Jeep started fine. The other day it did the same thing. Today as it sat for about 2 days it's like battery is dead. No lights dash or otherwise, no crank, locks, radio, wipers and so on. I tested the battery 92% charged checked good 723 cca. I pulled out the test light no power on fuses: All "M" fuse numbers 6, 8, 15, 33, 34, 37, & 38. Cable ends are cleaned, I pulled several electrical plugs checked grounds added grounds with jumper cables. When I open the door(s) nothing at all; no interior lights, no clock, no dash aka OD door ajar, head tail brake lights. The only thing that will come on is the after market lights that are on a separate connection to the battery (fused & relayed).
Thanks in advance.
Thanks in advance.
