I’m wanting to swap from a manual to an auto as my wife hates it and my daughter refuses to drive it. I’ve read several threads about different swaps but I’m wanting to know about the 09 specifically. Main things I’m concerned about are the wiring and pcm. Can the pcm just be reflashed or does it need to be changed and is there a separate harness for the transmission? I have HP tuners and can change anything in the pcm I need to and it also gives me the option to change the transmission type. I could probably even get a stock tune file from an auto and reflash it with that if the file is the only difference.
