Making some more progress in the afternoons... I got the flares pulled off to give me more access and to start cleaning the body/frame up. I will need to push the Jeep out of the garage once the motor is pulled to give it a thorough power wash, so I'll need my brakes working (see steep driveway post above!).
You can see above that the hoses on the OEM calipers comes from the rear. The 14B however comes from the front, so I need to think about how I need to route them...
Just thinking about overall fitment and protection, the above seems like it would be the best option.
This was my first inclination, but I think the control arms are going to be problematic in the long term, and the hose would need to be filed down a bit since the block at the end of the hose is about 1/32" too long and the bolt won't sit centered.
This is less obvious but does take out some length of these Metalcloak hoses and lets me route it around the springs a little better. However, I think the lower control arm would end up hitting at full droop.
In my attempt to "cross one thing off the list per day", I was able to get the axle shafts cleaned, painted, and installed before calling it a day. Unfortunately, I forgot the can of Rustoleum Flat Black wasn't actually flat black, so it's got more shine than I like, but I'll hit it with some steel wool once it's fully cured to knock the shine down a bit.
Doing some cleaning while the sun was shinning and the days are sunny and in the 70's. I had some mud and salt deposits around seat brackets in the Mrs. Grand Cherokee, so I dragged the Bissell outside. While I was there, I went over Charlotte's Islander seats. Every time I do it, it serves as a good reminder that cloth seats are f*%$@#* disgusting!!!
While cleaning, I installed the Drake Billet Aluminum shift knobs in the Islander too. The t-case shift knob kept popping off and the guy I bought the Bushwhacker flares from had these for $40, so I grabbed them on a whim (I'm not one to go for stuff like this, but these served a functional purpose so I gave them a whirl). They look nice but more importantly, they don't pop off against my knee and fall on the floorboard anymore!
I starting working on the Islander axles since the weather is already cooling and winter will be here soon.
I dragged the D30 and D44 back into the garage and started stripping them down. I can't imagine why the e-brake didn't work too well:
I got lucky with another FB Marketplace score:
Got a brand new TrueTrac shipped to my door for $240 - hard to beat that! To sweeten my week even more, I found a guy on my way to Virginia that was selling a Revolution D30/44 regear kit with 5.13's and MIKs for $500... I love me some deals!
I'm going to order some small parts this week - crush sleeve eliminators, new Spicer u-joints, new Spicer rear bearings and retainers, etc. I may take a vacation day next week to get these rebuilt. With any luck, I'll throw these axles under the Islander in 2-3 weeks, before Charlotte comes home for Fall Break and needs to drive her Jeep around for a few days. With some new gears and a refreshed suspension, it's going to be like a totally different Jeep for her when she gets back into it...
While I've been messing with the Islander, I'm still making progress on my JKU too (I mean, this is my build thread after all lol). I reworked the rear-passenger brake line. The line has a plastic coating on it that makes getting in clean and smooth for a flare kind of a pain, but with a few quick passes of a MAPP torch, I was able to soften and scrape the plastic off. The SSTubes kit should arrive this week, so with any luck, I'll be able to get the brakes completely hooked up this weekend and bled. If all goes to plan, I will start pulling the 3.8L once Charlotte's axles are done and swapped out....
Having the knowledge and experience to do this yourself is huge! I've had regears done in several vehicles but never attempted it myself.
Doing gears yourself is like buying a new welder - you get to make all sorts of new friends on your block or in your Jeepin' group :)
Seriously though it's not bad. People - the most famous of all being "Jerry" (yeah, that one) - like to pretend that it's basically rocket science and that one small nanometer out of spec and the thing will grenade apart. It's simply not true and getting a proper pattern is reasonably easy, albeit time consuming at times (especially for new builders). I've seen dudes pull carriers and gears out of junkyard axles, throw them in their housing, torque stuff down and go to town - reusing old crush sleeves even.
If anyone has ever had the chance to watch someone set up some gears, the mystery disappears rather quickly. I've shown a handful of people the process and at least two of them have successfully rebuilt their own stuff (not sure if any of the others have tried).
Trying to find a good spot to mount these rear brake hoses to. There's no good place that I could find that was obvious, so hopefully this one will work. I moved the control arms up and it appears to hit but it takes quite a bit of movement to get there. I suspect I'll be fully on the bump stop by then, but I'll certainly check once I get some tires and space to do so. Worst case, I will just relocate these to inside the frame rails somewhere. For now, a quick drill, a 1/4-20 tap, and a small stainless screw made short work of securing them to the frame...
While I'm back here moving control arms around, I took a few minutes to trim up the upper control arm bolts. They're 4.00" long and are about 0.35" too long and hit the backing plate bracket on the 14B:
I got the Islander D44 completely stripped and torn down. I'll start prepping the gearset and carrier this weekend. With any luck, I'll get a pattern and at least be in a good spot to fully assemble next week.
I won't be able to bolt it all back together as I found more corrosion on the backing plates than I originally realized, so I have a pair of these on order...
My daughter is coming back home for the weekend, so I won't have much time to work on her Islander (she'll be driving around seeing her friends I'm sure), but I did manage to pull the Rubi Rails off of mine and get those installed onto hers. I have been thinking about getting those 1.5" Teraflex springs for hers, but I'm really liking the stance as it sits. I think maybe I'll just install some 3/4" coil spacers and some good road-oriented shocks (Bilsteins) and call it a day. The 5.13's will be a little deep for the 285's on it, but certainly won't hurt anything, and maybe I'll grab a true set of 33"s the next time she needs a set of tires.
Making some progress on the Islander and even got a little lucky. I ordered 1x new backing plate and 1x "like new" backing plate off of Amazon. Luckily, the "like new" backing plate was actually a pack of two. I messaged Amazon and they told me to keep the second one, so I get to send the new one back. The best part is that the "used" one (actually two!) was only $68 vs. $138 of the new one.
I'm prepping the carrier and gear set and am reminded at just how nice the Revo gears are. I have, for all intents and purposes, given up regearing with Yukon kits. They no longer polish the shaft on the pinions (where the bearing sits) and the fit and finish of the teeth themselves are less than "quality inspiring". By contrast, every Revolution set I've used since ~2021 has been flawless, well marked, and well matched.
Although I noted that the Eaton D44 TrueTrac was dual drilled, I didn't pay close enough attention to the sizes. The JK44 rear ring gear bolts are 1/2", but the D44 carrier is drilled for 3/8" and 7/16". Thankfully, the JK gearset is also drilled for 7/16". The Eaton instructions call for drilling the carrier out to 1/2" size, but I saw a handful of times that many people simply run 7/16" ring gear bolts, nothing that they're plenty strong for nearly all JK uses, and that the D44 Rubicon front gear set also takes 7/16" ring gear bolts.
We had a busy weekend with my daughter in town, but still snuck out to pick up some goodies...
A guy about an hour away had a set of five, low-mile 40" Patagonia M/Ts on a set of 17" Ram 2500 aluminum wheels (one of them came on an H2 wheel). I've seen these on Marketplace for a few months now and have eyed them up for a while. He kept marking the price down and down, and for $900, I couldn't resist. These won't be my long-term option, but they serve a dual short-term purpose. First, my 18" rollers on the stock Ram 2500 steel wheels are too thin in the mounting flange and the lug nuts are bottoming out before the wheel gets snug to the hub, causing the rear wheels to "wobble" against the hubs (not good!). So while these wheels have way too much backspacing (~6.2") to be useful with big tires, a cheap set of 31-32" rollers would be perfect for my needs.
The second, and main reason for these tires, is to confirm that the Jeep will still fit in the garage on a set of 40"s (or anything under 40" really). Fortunately, by the metaphorical skin of my teeth, with only ~3/4" to spare (at 30 psig):
These things are big. I've run 38.5" bias-ply tires many, many, MANY moons ago and I swear these seem 10" bigger.
I mocked up the rear Bushwhacker flare (my humble attempt to somewhat try to pass PA inspection laws) to check the coverage and they are surprisingly decent. Again though, these wheels are not the correct backspacing. I will need 3.5" BS to run 38-40" tires, so these will stick out about 3" more on each side, but should (fingers crossed!) keep most eyes away as I'm going down the road.
On Monday, I drew the short straw and got to spend 5 hours driving my daughter back to school. Always seeing the silver lining in things, I scoured the Marketplace listings near her school and found this for a killer deal:
A Mopar Rubicon 10th Anniversary Off Road Rear Bumper and AEV Tire Carrier. The bumper offers better looks and clearance than the OEM plastic nonsense, but is also compatible with the OEM trailer hitch. It also supports the AEV tire carrier, which itself is exactly what I am looking for in a carrier: one handed operation that works with the OEM tailgate latch, and something that handles up to a 40" tire. The only thing I'll need to work on is how best to adapt this to a 8 x 6.5" pattern. The seller was also kind enough to throw in the Rugged Ridge spare tire delete panel.
Admittedly, I'm at a bit of a decision point. On the 40"s (since they're all the same size and actually snug up to the hubs), it's clear that the Jeep has a very distinct rake, rear to front. I have a few options to address this. First, I can order a set of 4.5" Metalcloak springs for the front. My concern with this option is that it may cause some clearance issues into the garage (at least on 40"s).
Alternatively, I can install the set of 2.5" springs (that I already have) in the rear. The concern with the second option (using shorter rear springs) is that I think I'm going to lose a decent amount of up travel with the 40"s and will be mainly riding on the bump stops, even with HEAVY clearancing. I may already have an issue with up-travel in the rear. I'd really need to install a set of 4.5" springs out back and 5.5" springs up front.
Unfortunately, my front bumper is already ~26" high. PA limits front bumper height to 22". Just like the risk with uncovered tires, I will use a set of small "rollers" for annual inspections, but this issue does often catch the glances of State Troopers, so something for me to also be mindful of. The more and more I map this out, the more it becomes clear that I'm better off dropping my rear down on 2.5" springs and running a set of 37-38"s... decisions decisions decisions.
They say to "make hay while the sun is shinning". In my case, it's "wash everything while it's still warm and sunny!"
I thoroughly degreased the frame, engine, trans, t-case, and firewall, then focused my attention on other nooks and crannies, such as in the rear crossmember, behind the rear tire (above that little foam cover thing), and inside every frame and body weep point I could spot. Overall, I spent about 3 hours constantly spraying, degreasing (Simple Clean is the best!), soaking, high-pressure blasting, and repeating.
This of course it to serve multiple purposes. The first is that I want to get some of the rust spots touched up on the inner fenders and fender support areas. Those Bushwhacker flares take up the entirety of the rear hatch area and I want them out as I need that space to start storing items for the Hemi swap. Plus I really want to rip out all the carpet soon, as it is straight gross and makes the garage smelly musty (I'll be going with a BedRug or ArmorLite in spring). The second reason is that I want to coat the frame (inside) with the Eastwood Frame Coating and Rust Encapsulator while the weather permits. While everything is apart and out, there's no better time than with mid 70° days and nice breezes... I would be a fool to pass up on this opportunity.
The final reason: although I've got some axle work to wrap up, as well as some house projects (replacing the 60 year old windows in the basement!), the 3.8L and trans will be getting ripped out in just a few weeks - hopefully by the beginning of November. The good thing about doing the deep clean this weekend is that I'll be gone for a good portion of this week on a work trip, so everything will have ample time to dry. I'm taking some PTO days next week and will spend some time doing this, as well as finalizing the D30/D44 regear.
I'm waiting on an AEV swing-arm "hardware and bushing" kit to arrive from AEV. It includes new bushings (which I won't use) but also new seals and an endcap (which I came to find out that mine was missing). As I wait for those parts (which I need to finalize the position and adjustments), I started to ponder the best way to convert the carrier to a 8x6.5" lug pattern. The AEV carrier comes with studs in the standard JK 5x5" pattern, but is also drilled for a 5x5.5" pattern. The studs just bang out and what you're left with is a fairly stout 1/4" plate.
I ordered a Barnes Tire Carrier Plate, which is drilled for multiple patterns. I'm unsure the best way to make this work, but what first came to mind was to simply weld in some studs to the 5x5" holes on the Barnes plate, and then simply bolt the two pieces together. I could drill out and use a stud at the top-most hole of both the Barnes plate, as well as the AEV plate, further "linking" them together. Unfortunately, the two sets of holes don't align properly and redrilling them out "figure 8" at least one of the AEV plate holes, making it less than ideal. I would also prefer the "pair" of studs to be at the top of the plate, which would allow my Alpine Rear Camera mount to sit in the proper location. I'll figure something out - my 15 hours in the car this coming week will give me something to think about (alongside my Italian and Spanish language lessons of course!).
Speaking of wheels and tire carriers...
I found a set that I'm gonna try out. They're Vision Manx2 in Satin Grey. American's Tire (aka East Coast Discount Tire) had them for $217 a pop and could get them in less than a week. Unlike many of the wheels out there, this doesn't have any machined or clear-coated surfaces, which don't seem to last more than 2 seasons (at best!) of winter driving here in PA. A friend of a friend was in need of some 40"s and had a fresh set of 37" Delium Terra Raider M/Ts. We made the swap and this will keep me going for a while. I'm going to eventually stuff the biggest tire possible in there, with the limitations noted in an earlier post, but for now these will keep the project rolling (plus they'll probably make a great set of winter wheels/tires). With being only a 12.5" wide tire and on 4.5" of backspacing, it's very likely that these will be completely covered by the Bushwhacker Flat Flares as well, eliminating the need to keep the baby rollers around once I'm done with the build.
I saw on an old forum post somewhere where someone talked about what rear track bar fits the 14B with the Artec Apex Truss. They said the "Rubicon Express" TB works, but I've been unable to find one, though I did find what I think was an actual photo of one. It was similar to the Skyjacker JK Rear TB designed for 1.5-3.5" lifts. AutoZone had it for a good price and was able to get it to me in a day (for free!), so I ordered it. You can see in the photo above that the Metalcloak bar has the bar designed for vertical clearance, whereas the Skyjacker bar is more for horizontal.
Unfortunately, I'm still going to smash the bar into the diff cover, just in a different spot. I may need to rethink the Yukon diff cover, as I think the larger profile is adding to the issue. Someone on FB said that they had no issues clearing their TMR cover with the factory TB, so perhaps I may need more of a stamped-steel style cover than the nodular one. I'll order one this week and see if there is a difference before sending the Skyjacker bar back.
In a complete shock, someone on FB told me that they used the OEM rear track bar with the Artec Apex truss kit and sure as can be, it fits perfectly and has a lot of clearance! The nodular Yukon cover I got may be problematic at full stuff, but I'll have to check that when I get everything bolted together. For now, it should get be moving and checking on things...
Reactions: WSS and tJKrider
Nice! You have to take the little wins when you can!!
Reactions: pc1p
Had a work trip the first half of the week and decided to take a little PTO time when I got back to wrap up some stuff around the house, plus get some dedicated and uninterrupted time working on both the JKU's...
First up, getting those 37"s I traded the 40"s for mounted up. I liked the design of those Vision wheels but many of the photos online made the wheels look almost textured and not a traditional smooth finish. When the arrived at America's Tire, I was happy to see that those images must have just been an optical illusion (likely due to the flake in the paint itself). The finish on the wheels is super smooth and the color compliments the silver of the Jeep well. They're not quite grey, not quite silver, and the contrast of the ring gives it a decent look.
In typical fashion, I checked the local ad pages while I was traveling and found a brand-new, still-with-the-sticker, 37" Falken M/T and took that home with me. I brought it, as well as the four Deliums to America's Tire and dropped them off. Before they started mounting them, I ran one of the wheels back to the house and did a quick test fit...
They're tight but I have plenty of clearance for the calipers! I called the shop and told them to start mounting the tires as I worked my way back down with the 5th wheel...
Overall I'm really happy with the fit and stance. I still need to decide what I want to do with the rake as my preference is usually for more of a level stance. I may need to get a set of 4.5" springs up front afterall, or maybe just get some 3/4"-1" coil spacers and see how it looks first. I may wait until I get the Hemi swapped in before doing any tweaks, but it's highly likely that I'll need to do something.
Between some lingering house projects, the axle builds for the Islander, and parts of my JKU all over the place, the garage (and side yard) is a bit disorganized and kind of a mess. My goal for this weekend is to get the D30/44 axles completely rebuilt and then turn my attention to getting the house prepped for winter. I had a F150 as a rental (for my work trip) and before returning it back to Enterprise yesterday, I also used it to take a quick trip to the landfill and got 95% of the crap that has been building up out of my way. I'm a big fan of purging and while I can deal with disorganization for a short term, it really saps my energy and motivation.
Speaking of motivation, I usually keep and maintain checklists for things (always have!). Here's what I have down for the JKU at the moment:
  • Rust treat the frame; undercoat tub, touch up axles
  • Finish AEV tire carrier install
  • Modify AEV tire plate for 8x6.5"
  • Remove front bumper and winch
  • Cut off the front crash bar
  • Install rear R10A bumper
  • Torque and cross-mark all suspension components
  • Remove t-case
  • Remove engine and trans
  • Swap master and booster
  • Install Bushwhacker Flares
  • Buy and install aluminum inner fenders (wait for Xmas sales)
  • Remove carpet, clean floor, check seam sealer
  • Buy BedRug or Armorlite flooring (undecided at the moment - wait for Xmas sales)
  • Buy PSC steering gear and hydroassist parts (wait for Xmas sales)
  • Order JSS Hemi swap parts (wait for Xmas sales)
  • Prep 5.7L Hemi - remove heads, install Truck Norris cam, do MDS delete, touch up paint on block, check rings and bearings, etc.
  • Do the engine swap...
Obviously the last few lines have a lot of sub-items related, but I update the list as I go. Timing wise, I hope I can catch some sales these next few months! :)
As expected, my long car drive down and back from Virginia proved beneficial. My first inclination was to make an adapter plate of sorts, where I could bolt the Barnes plate to the factory AEV plate in the hopes of still having the option to remove the Barnes plate and (should I decide I no longer want or need the AEV carrier) go back to the 5x5/5.5" options. And then it dawned on me - the Barnes plate has both 5x5" and 5x5.5" holes, why make it more complicated than it needs to be?
I took my angle grinder out and cut through the welds on the AEV plate. A quick tap with a min sledge and the plate came right off. I cleaned the left over weld and gave it a quick bevel, then squared it up on the Barnes plate. I gave it a slight bias on the vertical line in order to leave enough space for a stud in one of the random holes, then tacked everything in place.
Tacked in place, I eyed up where I thought my back up camera might want to sit...
I stopped by the parts store and grabbed a set of Dorman wheel studs, PN: 610-471. These have a 0.645" knurl and ~2.5" of thread length when installed. I used a 5/8" stepped drill bit to enlarge the 1/2" holes already in the plate, then whacked these in place with a hammer. Once I confirmed everything fit properly and the carrier was going to clear, I burned the rest of the tube in place.
Once it was cool, I gave it a quick touch up with some satin "wrinkle finish" paint (in my attempt to match the powercoat), and then got it mounted up. I drilled and tapped a hole for a 1/4"-20 stainless machine head screw and installed the Alpine rear camera mount. I hoisted the wheel in place, adjusted the lead length of the tire plate, and was very happy with how it all worked out!
I will need to do some tweaking before considering it "complete". As you can see below, the Rugged Ridge plate has a vent exactly where the AEV bracket sits. This should be an easy fix (I may just pound the entire vent flat with a big sledge and piece of wood. Once that's done, I'll drill the last two holes that go vertically through the AEV frame bracket into the frame and call it done!
We've got some rain and cold weather coming, so I decided to tackle one of the "to do's" on the list and get the frame touched up and painted so that I can permanently install the AEV tire carrier and R10A bumper...
The frame has been scrubbed, degreased, and hot-washed, so all that I needed to do was hit it with the Eastwood Internal Frame Coating. I ended up using 2 full cans, which covered both the frame rails, "torque boxes" under the seating area, a few crossmembers going across the frame rails and body, and then across the engine crossmember/brace and rear bumper brace.
This is after spraying. The material is quite thin but gets very stick once the solvent flashes off. This allows it to flow into the nooks and crannies of the rails, but the fast flash off helps prevent it from settling only in the low points of the frame rails.
I followed up treating the inside of the frame rails with a fresh scrub and coat of the Eastwood "Rust Encapsulator Plus", followed by hitting some spots on the tub with their Rubberized Undercoating version of the same material. I have a lot more to do, but will wait for the engine, trans, and t-case to be out of my way for that.
While I was waiting on the back end to dry so I can reinstall the AEV carrier, I turned my attention to the front bumper. It has to be removed to accommodate the engine removal, so I figured I'd might as well get that done now. While it was off, I also used the better access to treat the front frame rails, and also took a few minutes to cut off the crash bar that supports the OEM plastic skid/shield.
A couple minutes with an angle grinder and whacks with a BFE made short work of it... Due to the angle of it all, I cut a little bit into the frame rails, so I'll go back and do some light touch up with the welder and will get them smoothed out before touching up with some chassis black.
The process for installing the R10A rear bumper involves grinding off the welded/captured nuts on the hitch. The bumper itself has threaded inserts that are what secures the bumper to the frame, sandwiching the hitch to the crossmember in the process. The process was easy, a couple hits with the angle grinder and a small whack with the hammer. The tack welds were cleaned up with a flap disc and I threw on some fresh paint.
The vented Rugged Ridge panel was modified to accommodate the AEV Tire Carrier saddle plate. While it was off, I drilled a small hole for the rear-view camera wire to come through. A 3/8" hole, some touch up paint, and a 1/4" rubber grommet makes for an OEM-look...
Getting everything snugged up (I still need to get some new hardware for the "wing" brackets on the bumper though), I threw the tire on the carrier and checked to see how the rear view camera angle was looking...
I think I'll tip it down some when the time comes, but overall the image perspective is extremely useful. This will be important in tight school parking lots since the back window is essentially useless at this point for backing up close to things...
I finally remembered to pick up a new 3-jaw puller (for the yoke!), and got started setting up for pattern on my the Islander's D44. I gotta say, I’m either getting good, or got super lucky. The first setup at +0 checking distance (as marked on the pinion), was spot on!
I’ll pull the set up bearings and slap the new ones on, confirm my 0.0065” BL hasn’t changed, and call this one done!
I've got a work trip this week, but was able to swap out the setup bearings for the final bearings. No change in pattern and no change in BL. I ended up with 0.007" on BL...
With a nicely centered pattern on the drive side that shows good feathering...
And matching coast side pattern:
I don't know about anyone else's experience with deep gears, but for me, I've often preferred looking at the transfer pattern on the coast side (vs the swipe pattern). You can usually more easily see the center "patch" and the feathering. It's essentially just a "negative" of the swipe pattern, but with less marking compound, it's easier to see if you're getting any hard lead-in or lead-out issues.
The gears were all I had time to wrap up before having to take the trip. However, I did make sure my inventory of parts was correct (just in case I needed to order something while I was on the road). The old bearings looked smooth, but there's a loose "ring" at the bottom of the bearing it self. I can't tell if it's the lower lip from the bearing race, or something from the axle seal. It looks too thick and jagged to be anything from a seal, so my guess is that the race itself has had some movement over the years (there are ~220,000 miles on this rear) and caused the edge to crack off.
New retainer plates, Spicer seals, Timken A10's, and collars. Should be quick to get these done and get the axle slapped back together. Fingers crossed that the D30 front goes back together just as easy. My goal is to finish the D30 this weekend, and plan on swapping the axles into the Islander next weekend. The weather appears to be cooling but still cooperating, so with any luck, this thing will finally be able to climb a hill in 2nd gear and maintain 70 mph on the highway when a headwind hits...
Had to order a set of these... I've been eyeing them up for a while and decided to just order them. They're a little blingy for a stock rig, but they add some functionality and I really didn't want to scrub, clean, or paint the factory covers.
Wrapping up the Islander D44 - I started by cutting off the shaft retaining collar. I find that a side angle cut-off wheel works best for this. You don't need to cut all the way through the collar. Simply work your way towards the center and you'll eventually get a distinct "tink" when it cracks and releases tension.:
I pressed both bearings, seals, and retaining plates together:
Looks like someone has been in this rear beforehand. You can see a number of slices on the shaft. This happens when people don't have a clamshell puller capable of pressing the bearings off the axle, requiring them to cut the cage off, then working carefully - or in this case not-so-carefully- cutting the inner race so where it can be punched off.
I got the D44 all slapped back together, with brakes and everything. The only thing left is to add some touch up paint where the Metalcloak rear trackbar bracket was. I then switched my attention to the D30 front axle. I remember why I have historically hated unit bearings - rust makes working on these things awful! It took almost 1.5 hours to get all the brackets off, unit-bearings off, and shafts removed. Each bolt for the unit bearings required heat and plenty of persuasion with a 3-foot, 3/4" breaker bar!
I called it a night then came back to get the rest of the axle prepped. The axle tubes can be cleaned a few different ways, but the best by far I have ever found was a heavy-duty Grade 8 washer, using it as a "scraper" on a long threaded rod.
I also used some large steel brushes to get the crust at the tube ends extra clean:
Did I mention I hate balljoints and unit bearings??? More rust = more heat (and these axles aren't even bad!!). Some heat, a few whacks with a hammer, a twist of the press, some more heat, a few more whacks, and rinse and repeat a half-dozen times, and these lower joints eventually came out.
I banged out the inner races and baffle, swabbed out the bearing cap bolt holes, banged out the inner wheel seals, and sprayed everything out with a can of brake cleaner.
With the prep work done, it's time to start working on reassembly. I've probably regeared a dozen D30's at this point and each and every time I do, I am shocked at how small the ring gear is. The thing reminds me of a Subaru ring gear! Anyway, I cleaned the protective oil off and lapped the back of the ring gear. As you can see, there is barely any work that needs to be done to these Revolution Gears. They're consistently the best gears sets I've used time after time.
I ended up ordering a MOOG Complete Steering "Assembly" (all steering components pre-assembled) plus a new Monroe steering stabilizer, a set of MOOG unit bearings (these old ones were crunchy!), and a set of brake dust shields. While I was in Chicago this week, I also ordered the Bilstein HD shock set from Quadratec, which if my ears are working properly, just got delivered...
I have a busy weekend ahead of me, but the plan is to get this D30 100% back together and on a furniture dolly. I'm planning on taking off next Friday to get this Jeep torn apart and axles swapped out... my biggest concern is that the weather turns crappy and I'll miss my window of opportunity until next Spring! I happy to be freshening up the Islander for my daughter, but I have to admit - I cannot wait to be done with it so I can get back to working on my JKU. I'm at the point where I can get to the fun stuff: pulling the drivetrain out, getting the steering box swapped, and rebuilding the Hemi.
Got the gears all done in the Islander D30! After years of using long threaded rods and using blocks and old bearing races to pull inner axle seals in place, a friend told me about this thing and boy does that make it easy! Some grease on the lip, and some black RTV on the seating edge, and these went in place super easily. Just to be safe, I pushed them in (towards the "C") a fraction of an inch further than they were so as to get a fresh sealing surface on the axle shafts.
I was pretty limited on shims, both under the pinion and carrier bearings. I didn't realize the JK30 uses outboard shims, similar to the JK44's (and later-year TJ44s). As a result, when I had to do the final carrier preload, the backlash shifted from ~0.0062 to ~0.00455. Spec on the JK30 is 0.005", so it's close enough to be a rounding error and I'm not too worried.
These gears were around +0.010" short from the suggested starting shim thickness, so it took me a few attempts to dial it in. These thick-cut, high (numerical) ratios often give hard to read patterns. As a result, I almost always do a "confirmation" adjustment, where I intentionally overshoot what I think the adjustment needs just to confirm that the pattern shifted how I would have expected it to move. That was the case here too, but the pattern below was the best I could get. It's centered on drive and coast, with enough feathering at the crown to make me happy.
The drive side looked a tad better before the final carrier preload, but with a limited number of shims, this was the best I could do. I'm happy with the pattern, and generally gear D30's a bit "tight" anyways, but I would have tried to play with backlash a little more if I had a different set of shims to make it work. Such is life and I'm not worried...
With the gears done, I started reassembling... a fresh pair of balljoints for each end:
But ran into an odd thing as I was ready to start banging in the U-joints. One of the shafts has a different yoke size than the other:
It almost seems like a TJ shaft, so likely takes a TJ sized joint, so I'll need to find a u-joint that fits it. I'll likely pull the shafts from the axles currently under the Islander and steal the shafts from it - hopefully they're the correct size...
Making progress… old D44 is out and frame is prepped for some touch up paint tomorrow.
The ball joint adapters should be here tomorrow afternoon, so with any luck, I’ll have the new D44 in place and the old D30 pulled and ready…
