Would I need to replace anything else with a 3" lift?
Jeepgurl330
Phx az
Looking to put a 3" lift on my jku sport on 33 inch geolanders. Would i need to replace anything else besides what comes with the kit? Looking at fabtech sport kit with shocks or zone offroad kit with nitro shocks. They mainly come with shocks and springs.
Normally over 2.5" you need adjustable control arms and definitely need adjustable track bars front and rear to center the axles under the Jeep.
You may have also have to recalibrate your speedometer since your going to a taller tire.
Reactions: Jeepgurl330
it looks like i need a different lift package then. Thank you so much i appreciate the help!
Do you have a lift kit in mind thats a decent price that has everything i need? Or would you pretty much have to buy something to add to any lift kit?
Not sure what a decent price means to you, it's either a complete kit with everything you need to do it right. Or buy one with half the parts needed to do the lift correctly and then buy the missing parts later when your Jeep is all over the road.
Clayton Offroad is a Forum Sponser contact them and get some prices.
Another option is a 2" lift then get flat top fenders when you decide to go taller then a 33" tire. Or flat top fenders will make your Jeep look like it has a lift.
I have the 2.5 teraflex kit with the teraflex 9550 shocks and I have been happy with it. I am sporting 285/70/17 which is essentially a 33" tire, and I have plenty of room.
If you go taller you would probably need adjustable control arms and track bar, making the build vastly more expensive.
This a 2.5" with 35" tires and factory fenders:
Thanks so much for the info!!! :)
I just purchased the 2.5” AEV lift, plan on putting on this weekend. Seems to be a full kit with everything needed. A couple of reviews shows it ends up being a little over 3” of lift, but that could depend on how much gear you install on the Jeep. Trail Recon did a review of about 6 different lifts, its on YouTube. You might find it interesting. The lift of kits ranged from 2” to 4” if I recall correctly.
You've got lots of good recommendations so far.
The other thing you need to watch for is making sure that your lift will support the shocks you have.
Some of the kits come with brackets basically that let you use your existing shocks, but doing a lift is a great time to replace the shocks.
What year is your JK?
That's a really good Jeep channel for sure. He gets bonus points for having put up with us former red crayon eaters of Uncle Sam's Misguided Children.
Reactions: Largehit71
Its a 2014, ive been looking at kits that come with shocks so those will be replaced. Not many come with control arms tho which i was told you need to replace with a lift. Is that only if you got 3 and up?
What did your kit come with and what else did you buy to put on for this lift, if you dont mind me asking?
Comes with everything listed below. I installed the rear today and overall it went fairly smooth. I installed the rear track bar out of order according to the instructions but I couldn’t see trying to install the springs after installing the tower. So I did the springs and then the tower, which worked out well. The only issue right now is the right rear brake line bracket doesn’t seem to be working out well due to where the track bar mounting bracket is on that side. Other side is fine. I did buy the geometry correction brackets since it is separate but that is it. I’ll have to see what I want to do with the brake lines.
Yes the sweet spot is about 2.5" of actual lift in terms of cost and function.
Even that's a little complicated though because the advertised lift height might not be the actual lift height.
It depends on the company that makes the kit, as well as how heavy your vehicle is.
A kit from one company on a lightly loaded without heavy steel bumpers might give you 3.5", and the same kit on a heavy jeep might be 1.5".
The main thing to evaluate when you're looking at a body lift is what size tires do you want to run.
The spring/spacer lift only increases the distance from the body to the tires.
The tires determine how high the axle is from the ground.
So unless you plan on running 37's or bigger, a lift larger than 2.5 - 3 inches of actual lift is unnecessary and very costly in terms of all the parts you need to do it right.
As you lift the body of the Jeep, the body of the Jeep moves towards the passenger side and is no longer centered over the axle. The front and rear axles move inward getting closer to each other as you lift as well.
The higher the lift, the more pronounced that is, and the more problems/cost you have on your hands.
The most noticeable issue is severely affected steering response that makes the Jeep feel flighty and difficult to control at high speeds, which is not a great feeling if you've ever driven a Jeep that was lifted over 3" or so with a cheap kit.
With 2.5" of lift, you can get away with needing to replace things like the control arms, drive shaft, drag link flipping and a host of other changes/parts that would be needed.
A 2.5" lift can fit up to a 35" tire if you get some aftermarket flat fenders so it's a great compromise in terms of performance and cost.
Nice
Nice and yea some of those instructions seam backwards half the time lol thanks for the info!!
A 2.5" lift can fit up to a 35" tire if you get some aftermarket flat fenders so it's a great compromise in terms of alot of answers i had questions to. Thank you so much
Alot of great answers i had questions to thank you so much!!! Im sticking with 33s for now, then later the biggest i want are 35s. Maybe just buy the extra stuff to lift it a little higher later on. I have flat tube fenders coming in next week and a sick couple of side decals on wed. Plenty of time for other stuff. Thanks again!!
Reactions: mrjp and Vman
