Wizard recovery gear!
John Cooper
Bryant, Alabama
I don't know on here who all uses their winch but if you do and haven't tried any of Blaines recovery items you owe it to yourself to grab some.
Winch rope with thimble and his ST fairlead.
His now discontinued soft shackles recovery point, and soft shackles
And everything installed
I have a full recovery kit I keep in a three day assault pack. Never really got the fad around soft shackles though.
Reactions: John Cooper
I didn't either till I got them.
Please enlighten me. Always willing to learn about new things.
E: Also, dig the flag. I wish I could fly mine here but I'd likely have my possessions vandalized and pressure applied to my job to fire me. I'm from Florida originally.
  • Love
Light weight, easy to pack.
I used to always worry about the hook slipping off whatever I had it on.
You can put the soft shackles around the axle if needed.
They are simple to use.
I have never worried about the Battle flag, it's a miss understood symbol if you ask me.
I have roots from the revolution to the war of northern aggression and so on.
Reactions: Danarch
When I first learned of these I thought "why didn't someone think of these sooner?"
In my lifetime there have always been fabric tow straps and the advent of fabric winch line, so why not fabric shackles?
I don’t own any soft shackles but people in our club do so I’ve used them a few of times assisting with recoveries. I guess what I haven’t been able to wrap my head around so far is it seems like with enough force the knot would slip out the hole it is inserted through. But I’ve never heard of it happening.
I do plan on getting a couple in the future.
The ones I have are pretty tight and and require some effort to get the knot through. Once there is tension the loop clearance is reduced significantly so I don't think that knot is coming back through. Playing devil's advocate, however, anything is possible with enough force, but I'm guessing its higher than the soft shackle rating.
If you look at my picture and I'm pretty sure @Chris can confirm, there are small strings(that's what they look like) that will tighten up the loop on Blaines shackles.
Correct me if im wrong Chris.
I have at least 15 soft shackles. I keep them in a 5 gallon bucket next to my chains for use in the shop. I can hook two straps together in about 10 seconds, easier to use and safer than chain and steel shackles. We often get 10k lbs loaded pallets stuck in the nose of a 50' LTL trailer that we have to pull out. The straps and soft shackles make the day easier. For recovery, I have three in my bag and a soft shackle snatch block. Never used the block yet but do use the soft shackles. I used a large countersink bit and a flap wheel on a die grinder to soften the edges of my shackle mounts on my TJ. Still need to get around to it my JK.
