The idea was suggested to me when I stopped at a local shop and asked the owner if he can do a transmission fluid change on my JK. The gentleman replied that he can but is usually weary of doing them if the fluid is clean and there's no current issues. Then he looked over and saw my JK on 35's and said I should consider adding a trans cooler at some point in the future. To be clear, he didn't try to sell me on any particular brand, size, electric fan type, etc. Didn't even ask I do it with him. He simply said a 'good, basic type trans cooler can really help with longevity of auto transmissions'.
So when I got home I did a bit of searching on the topic of coolers. And it seems like a good idea because early failure can be caused by excessive heat as well as poor maintenance. However, since the 2012 and later come with a factory cooler, would it be prudent for me to add one? And further more, should I be at all concerned with changing the fluid and filter? NO flush.
STATS:
2013 / JKU / 35's / 3.73 / AEV module for tire size adjustment / 64k miles
Thanks in advance.
STATS:
Thanks in advance.
