Traction Control Help Needed
FLCoastJK
Destin, FL
I recently installed adjustable track bars as my 2016 Rubicon was lifted 2.5 inches and the original bars were still on, the axles were not centered. I installed the bars and got a traction control light and ABS light on the dash. I saw it also had the U140A front right speed sensor was flagged as bad. I replaced the sensor and on the drive the traction control light would come on and the brakes would pulse and slow the Jeep down. I cleared the codes, drove again and same thing happened.
The part that has me confused is after replacing the sensor I don't see that U140A code anymore, now it shows C123F steering angle sensor. The steering wheel is not straight after I installed the track bars, I am sure due to moving the axle. I am going to get it aligned next week, is it possible the sensor and steering wheel is tricking the ABS system somehow?
Thanks for the input. I thought that might be the case and couldnt think of what else could have changed. I will get the alignment done and hopefully it will clear up.
Maybe if the alignment shop will do it, some do and some don't. It's not really a alignment issue as far as the front suspension is concerned. It has to do with the esp.
