I am working on my daughter's 2012 JK. I have replaced the throttle position sensor and the throttle pedal. Obd said there is no correlation between sensor A and B with a low voltage input on both. What am I missing? What else do I need to look at?
Ben, I don’t know if you are still in this Forum, but I am currently having the Throttle position code issues with my 2012 JK that you mentioned in this thread. Did you get a resolution and would you mind sharing with me?
BLACKJKU. We have already been messaging on my own thread with this issue. Unfortunately, absolutely nothing has worked. I have checked every chassis ground and even removed the battery and TIPM to check all wires and connections. I cannot find the issue. When I saw Ben's post I read through it but see that there was never a solution posted. Just taking a stab in the dark that he might see my question.Did you recently do any electrical parts replacement?
Tagging on to this as well to see if either of you ever found a solution. I have an 09 2D and the seller didn't tell me about the code and of course didn't pop on until I got home with it.BLACKJKU. We have already been messaging on my own thread with this issue. Unfortunately, absolutely nothing has worked. I have checked every chassis ground and even removed the battery and TIPM to check all wires and connections. I cannot find the issue. When I saw Ben's post I read through it but see that there was never a solution posted. Just taking a stab in the dark that he might see my question.
Same struggle on my 2007 JKU... Even gives me a traction control fault dash light... If I'm running down the road, turn the key off and then right back on it clears up... until it does it again... GRRRRR
I did that before posting... I may try it again now that I have 40 or so miles on it since I put the new throttle body.
Thank you...
