The Official Jeep Wrangler JK Oxygen (O2) Sensor Thread
What does upstream and downstream mean?
Simple, upstream means the O2 sensor is "upstream" of the catalytic convertors, meaning before the catalytic convertors. Downstream means the O2 sensor is "downstream" of the catalytic convertors, meaning after the catalytic convertors.
What brand of O2 sensors should I use for replacements?
Pay close attention to this one so you can do it once and do it right! The Jeep Wrangler JK is extremely sensitive to all oxygen sensors other than NGK / NTK. Bosch O2 sensors and all the others (including the crappy Chinese brands you'll buy at your local auto part store) are very well documented as not working properly with our JKs. In other words, you plug them in and you assume all is well, until you notice your check engine light isn't going away. This is almost always due to the fact that you didn't use an NGK / NTK replacement O2 sensor.
Okay, so why don't other sensors (i.e. Bosch) work on our Jeeps?
Glad you asked! Check out this video for a detailed explanation of why other brands of O2 sensors don't work on our JKs:
So which O2 sensors do I need?
I'm going to break down which sensors you need based off what year your JK is. The part numbers (and information) below were taken directly from the NGK website, so you can assure it is 100% accurate (even double checked each individual year and model before writing this thread).
Be aware that NTK O2 sensors are the same thing as NGK and they share the same part numbers. NTK is owned by NGK, it's simply their division for O2 sensors.
2007
NTK #23566 - Upstream Left​
NTK #25186 - Upstream Left (RHD)​
NTK #25186 - Upstream Right​
NTK #23519 - Downstream Left​
NTK #23519 - Downstream Right​
2008-2009
2010
NTK #25186 - Upstream Left​
NTK #23070 - Downstream Left​
NTK #23143 - Downstream Right​
2011
NTK #23143 - Upstream Left​
NTK #23070 - Upstream Right​
2012
NTK #23162 - Upstream Left​
NTK #23161 - Upstream Right​
NTK #23162 - Upstream Right (RHD)​
NTK #23161 - Downstream Left​
NTK #23162 - Downstream Right​
2013-2018
Misc Installation Notes
When installing new O2 sensors, be certain to use some anti-seize on the threads of the new O2 sensors! This is important, and will save you a huge headache should you ever need to remove them in the future.
In addition, a O2 sensor socket will greatly aide in the installation and removal of O2 sensors. I recommend this one.
Lastly, if you notice your O2 sensor harnesses are not long enough with the new O2 sensors, these O2 sensor extensions will solve the problem.
Just a tip if all your sensors suddenly come up as bad its probably a bad ground that they share. On my 07 its under heat sheild next to exhaust manifold..easier to cut and relocate them....
Indeed, the first place to look IMHO is always the wiring.
2007
2008-2009
2010
2011
2012
2013-2018
You are the best information on o2 sensor I have found . Thank you
I tried Bosch - didn't work!
I opted to buy OEM Mopar ( expensive )
Trying to figure out which one goes where wasn't obvious but I think I got it from the Mopar part diagram.
Interesting that the OEM are made by NTK ! Shoot, I should have followed your post.
Reactions: Chris
So I found this thread after I have ordered a set of 4 from Extreme Terrain. I know this thread said to use certain brands but has anybody used the one from Extreme?
bite the bullet and buy NTK or MP sensors. Bosch have proven themselves to NOT work correctly with the unique to Chrysler 2.5v bias (the negative gray wire in sensor is ground but it has 2.5V on it from the PCM via the harness, its used to detect a 'less than zero' output from the sensor if it dips down that much. PCM ground is different than chassis ground!) as well as the heater circuit being a higher resistance causing the PCM to get a little funky with its PWM control of it. Bosch take minutes to come up to operating temp while NTK come up in less than 10 seconds. scannerdanner did a great video of this when he compared Bosch and NTK sensors on a scanner. The Bosch caused the bank it was in to pull fuel at idle until a lean surge was detected. The PCM started to add fuel to the other bank to try and compensate! Heater circuit graph on a Bosch was erratic while the NTK trace was very regular. Next time your at a self service junk yard, pull as many OEM (NTK or MP) as your budget (or pockets) allow and test each one when you get home on your scan tool and try and use them instead of new Amazon or Ebay sensors as both have counterfeits listed.
Reactions: Chris
