Stuck front brake caliper
Im sure that would be recommended but I had the same happen to me a couple days after a brake job. My rotors and pads were new. When the caliper seized, I just changed the shot one.
Reactions: Lxxtsy
I dealt with this also, my driver side would intermittently stick . Replaced both front calipers, pads and replaced all 4 brake lines. Because the lines can cause the sticking problem I just did those as well including the back as I was going to need to do a full bleed. This is also the time to do a Brake fluid flush. My fluid was so dirty it probably was contributing to the issue
Since it's a 07 id replace the 2 front rubber brake lines also, they can go bad and make a caliper stick .
Thanx for all replies. Replaced the front two brake hoses about a month ago when one developed a leak. Got a killer deal on two calipers today. Will do both along with new pads. Rotors were changed recently and are in good shape. Thanx for the help.
