I dealt with this also, my driver side would intermittently stick . Replaced both front calipers, pads and replaced all 4 brake lines. Because the lines can cause the sticking problem I just did those as well including the back as I was going to need to do a full bleed. This is also the time to do a Brake fluid flush. My fluid was so dirty it probably was contributing to the issue
