Steering Shaft Snapped!
ArttyG
Memphis, TN
I was out wheeling this past weekend in my 2010 JK 2 door. I went over a flexy spot on the trail that required a hard right hand turn, and snapped the output shaft on the steering gear. Has anyone else had this issue?
Any suggestions on preventing this in the future?
I am considering trying to find the parts to rebuild the gear box, but would like some input from others with more experience.
Is there a beefier box, or beefier parts I should consider using?
Thanks!
P.S. When I get the steering box figured out, I am going to have to do some work on the steering wheel. Unfortunately, I spun the steering wheel too far when the steering failed and screwed with the airbag, ESP, Traction control, and Cruise control.
Please tell me where I can get informed on how to fix this issue as well.
Thanks!
Thanks!
The only thing I know of to prevent it from happening in the future is to quit wheeling. It's just one of those things that can happen when you do things like that.
Ok, I guess I walked right into that one. I guess my question is,
Is this a common failure?
Is there something better than stock that I should consider replacing the gear box with?
Thanks!
I don't know if you could make this work or not. I had one on my Dodge Ram and when I junked it I kept the brace and modified it to work on my Blazer.
I have the Synergy Support on my current setup and still have concern. The previous owner installed it and has had zero issues with the sector shaft in 10+ years of wheeling.
And yes the Sector Shaft is a known weak link and can easily cripple a rig. Which I am always cognizant of. If I'm getting too much restriction on the steering I have to Austin Powers it back and forth, knowing I can snap that thing in half.
Some solutions:
-The Synergy Kit. Its an insurance plan not an upgrade.
-PSC Big Bore box. The steering box by itself is an upgrade with a larger sector shaft and larger internals. For full benefit you'll need the pump and reservoir.
-PSC (or similar) hydro assist. Can be done on the cheap (<$700) but a proper kit can be upwards of $2500 not installed.
Regardless, good luck getting her up and running.
Reactions: Vman
I am currently running this rig in stock condition. It came with 32" tires.
It seems like hydro assist would be overkill? Would it be?
I heard with big tires the hydro assist is good, but with hydro assist you still have a steering gear box.
I have the non-hydro assist version of the PSC big bore running 35's. It is hands down awesome. Steering on and off road is perfect. I can turn the wheel with one finger while stopped.
Full kit of pump, hoses, reservoir, cooler, gear box, fluid and pitman arm is about $1700. Or was before 2021/2022 crazyness.
Thanks!
Broken clock spring i suppose. Just unhook the battery for a while and replace it
