Stability control light comes on anytime I hit a bump
Jonbev2
Tx
2015 Jeep Wrangler unlimited sport rhd stability control light comes on and stays anytime I hit a bump. The light goes off upon restart, doesn’t show any codes other than camshaft sensor. Had the sensor replaced, but still coming on, any ideas?
If you didn't use a OEM camshaft sensor that could be the problem, also sometimes you need to do a reset so the ECM can do a relearn.
On the stability control light are you referring to the lightning bolt light? If so is your steering wheel centered?
Reactions: Ghstrydr
How do you do a reset? Yes the steering wheel is centered.Mechanics I’ve talked to seem to think it is an engine issue, I think it is more of a drive ability issue(maybe steering or front end) but I’m definitely not a mechanic.
