Removing crossmember, where to support?
eastbloc
state
Greetings gentleman and ladies.
2008 automatic, trying to save it before the rust does its thing on it.
Will be removing crossmember, where should i place the jackstands in order to support engine-transm-transc?
Should i replace those 4x 18mm bolts with something better?
If your removing the trans crossmember then you can put a jack under the trans close to the crossmember. I always put a piece of wood between the jack and trans, and for safety you could always put a jackstand somewhere.
Yep, X2 to what he said. I do it the same way.
I always put a piece of wood on the jack and then jack from the transmission housing itself, then remove the crossmember.
