Regearing 4:56 vs 4:88
Ratbikerod
Carrollton, TX
I have a 2015 Rubicon JKU that I am currently running 33" tires on and have 3:73 gears. I will, at some point, probably move up to 35" tires. This is my daily driver and I tend to drive longer distances to do any off-roading, which is generally pretty mild.
Thus, I want to maintain some semblance of ok milage (typically get about 15 mpg today), but improve both driving and off-roading performance. Should I go with 4:56 or 4:88 gears. Won't be going to 35" until the 33" wear out.
Thoughts?
You're in Texas flatlands and have a 0.83 OD ratio. Seeing how the 3.6L is powerful enough to manage moderate hills and headwind, many are happy with 4.56's with 35"s. However, if it were me I'd go with the 4.88's (actually I'd probably go 5.13's b/c ~2860 RPM at 70 MPH is quite smooth still and I'm in the "Endless Mountain" region of the northeast).
Yea, I am mainly in Texas, so pretty much not a lot of big hill country. I do travel to New Mexico to vacation and it would come in more there. Sorry to be dumb, but OD to me is overdrive and the 5 speed has no OD I am aware of - school me if it does. The gear shop is pushing 4:88 and I am sure they know best. Just do not want to go too far on this as I do have to drive it on the highway frequently.
Reactions: pc1p
Here are the gear ratios for the 5spd auto. As you can see 5th is indeed an overdrive as @pc1p stated:
1st (3.59), 2nd (2.19), 3rd (1.41), 4th (1.00), and 5th (0.83)
Ok, yea thanks, we are on the same page. I did not look at 5th gear as OD. All good, thank you. So on your chart either 4:56 or 4:88's would work for either tire size in the blue performance band, but I slip into green on the 35's with 4:56. That would be in line with what I am being told, then.
Reactions: tJKrider and pc1p
You are correct - OD is indeed "overdrive". The W5A580 in your JK, commonly referred to as the "NAG1" is a Mercedes developed 5-speed Auto that replaced the older (and arguably WORSE transmission ever installed in a Jeep), the (in)famous 42RLE.
4.88's would keep you in the "blue". I always err on the "blue side" of gearing, as the Wrangler is essentially an aerodynamic "box" driving down the road and the engines all benefit from some additional torque multiplication.
FWIW, I'm running 5.13's in my daughter's 2010 Islander on 32"s, but her 42RLE is only a 4-speed auto and has a 0.79 OD ratio, plus the 3.8L falls a bit short of the 3.6L in power.
Great info, thank you. Definitely will go with the 4:88's I think. Interestingly, I have a 2015 Ram 2 door short bed pickup with the same 3.6 motor but the 8 speed. Man does that 8 speed really wake the 3.6 up. I am hoping this gear change will as well.
Reactions: pc1p and tJKrider
Let me throw another fact out here for discussion. The JL Wranglers with an 8 spd auto and factory 35s (315/70R17) have a 4.56 final drive. OEM gears are typically a best fit to balance all use cases, fuel economy, etc. A big difference, however, is that the 8spd has a 4.71 first gear. To match that in a JK auto you would need a 5.98 final drive! (4.71/3.59) * 4.56 = 5.98
If you compare 2nd in the JL to first in the JK it looks a bit better:
(3.13/3.59) * 4.56 = 3.98
Something in between the two would be a good compromise, which would be 4.98. Closest actual gear choices would be the 4.88 or 5.13 depending on how you would want to hedge your own usage.
Reactions: Ratbikerod and pc1p
The first time I drove a WK2 with a ZF 8-speed, I would have swore it had a V8. It really adds a whole new level of performance. When it came time to do my Hemi swap in my JKU, there was no question whether or not I was going with the 8HP70!
When in doubt, go deeper….
I’ve never met someone who said “wow, I hate this gearing, it just provides too much torque multiplication and throttle control!”, but I’ve met dozens of people that have said “I should have gone 4.88/5.13/5.38/ whatever ratio is the next deeper than the one they got”.
Also probably worth noting that most of the Extreme Recon packaged JLUR’s in my area were optioned with 4.88’s - AND - the JLUR shed ~200 lbs compared to the JKUR. Given all that and the better transmission, I for sure would be going 5.13’s (but I’d also be dropping in a Hemi so, 🤷🏻‍♂️ lol)
I have really contemplated an 8 speed change. I just expect that it would be so god awful expensive. In my little 2 door short bed Ram it will completely light up the tires and scratch them hitting second. When I bought the Ram I wanted a Hemi, 2 door short bed in any color other than black. They had one remaining 2 door, it was black with the 3.6. I was impressed enough to buy it. I have 120k miles on it and it still runs like a bat outta hell. Working on it is easy as you can stand between the motor and the radiator. LOL
I was pissed and still make jokes as much as possible, that my wife wouldn’t buy the Overland WK2 we looked at the dealership with a 5.7L (it had a moonroof which hit my head unfortunately, and we needed a replacement somewhat quick to her recently wrecked Subaru). That said, her 3.6L is still going strong with near 120k as well and other than a small crack in the radiator, runs great for what she needs.
If I had a major problem with my 5spd I would consider an 8spd upgrade knowing that it would probably be ~$10k. Of course it's easy to spend money before I'm actually at the point that I would have to write the proverbial check! 😉
I'm much more up to speed on the Hemi + 8HP70 swap, but I would guess much less than that... you can find 8HP's for dirt cheap (I bought two for $500 each) and the nice thing about their programming is that the are very much "self protecting", preventing unnecessary hard shifts, monitoring pressures and fluid levels, etc. This means that even one with moderate mileage is still likely a good swap candidate. Figure ~$800 for the trans, $100 for the fluids, $50 for new filter and gasket, $1900 for the swap kit, and $400 for shifter, cooler fittings, and misc items, and you' could conceivably swap to a ZF for ~$3500.
Lots of good resources for it too: https://www.facebook.com/share/g/1D63AZ8SeL/
Yea, I think my first step will be the gear swap as that will be helpful with either transmission. Then, if my trans started acting up I would look at a swap for an 8 speed.
Yeah looks like the Jeep Speed shop swap is a lot more affordable. I was looking at the ATS swap and that was $9600! 😲
Reactions: pc1p
Theirs looks sweet though, and is all "new", so perhaps the price is somewhat warranted, though I don't know if I'd pony up nearly $10,000 for just a transmission update, especially since a Hemi swap isn't that much more :)
Yeah totally agree. No shade meant towards ATS it definitely looks like a well thought out swap. I always take a "value" approach to my upgrades accounting for my willingness to what I can as a part of the journey. 😉
Reactions: pc1p
At $10k you have to consider whether it is better to upgrade to a JL to be honest in my mind. Don't get me wrong, I bought my JK used a few years back because I did not want a JL. However, I would have loved to have the option to find a JK with an 8 speed. I do agree that it can be done for about $5-6k, maybe less.
At this point, I think for the money (being quoted just under $2500 for the 4:88 swap) I think I will see how that perks up the old girl.
