radiator fan problem
wyobob
Wyoming
My 2010 wrangler JKU gets hot sometimes as the radiator fan does not come on. You can turn the ignition off and back on and the fan comes on. I have been looking for loose or broken wires and can't find anything. Any suggestions?
I'm pretty sure there's a relay for it and also the temp sender tells it when to come on. Bad grounds can cause electrical problems.
Reactions: BigAL07 and wyobob
If you are able to reset with the ignition I would go @BLACKJKU 's route. Check the electrical, small steps. Check conductivity, swap relays, run direct power. If the fan never triggers due to heat (but does run) I would suspect a bad temp sensor.
