Overheating
warth7
West Virginia
Jeep mechanic’s, I have a problem. I have a 2012 Jeep Wrangler sport. 3.6 it all started with no heat. I changed the thermostat, then it started to over heat. So I flushed out the heater coil. Got heat for about 2 days then no heat again. Started to over and no heat so I changed the heater coolant sensor. That helped for about 3 days then started to over heat again. Went and bought a thermostat again. Still over heats. Today I been adding as much antifreeze as it will take I’m using the HOAT that it calls for. So far it’s not over heating. But I have no heat again. Anyone else experience anything like this..
If it's not pressurized, you basically have a very modest and ineffective flow of coolant thru the system. Like taking a shower in a crappy hotel with little water pressure.
