Yes, I have and it’s dry insideCan you pop out those 2 black rubber plugs and see if anything comes out?
It looks kinda like it's coming down the left side, have you checked the valve cover gasket?
Any oil around upper oil pan gasket?
I replaced the oil cooler back in February, cleaned the area out nicely, made sure I got a good seal when putting the new one on. I will use some break clean and see if I can find the source. Will return if I can’t solve the issue. Thank you both for your help for now.Have you replaced the oil cooler and maybe not have cleaned all the oil off the engine?
I would say buy a couple cans of brake cleaner and spray the area good and then watch it real close to see if you can find where it's coming from. Maybe just start it up and let it run without driving it and see if you can find the leak. When you drive the Jeep it could blow the oil from one area to another and it will make it hard to find the leak.
