Thank you again vman. I did not check pcm side because #6 has spark but I will tomorrow . Can't hurt at this point. Last ditch effort before it goes to the shop
What should I be checking for ? Voltage , resistance? With a dvm or test light ? Does it specify ?
The shop doesn't have an opening before next Friday so more testing to be done. I only had a few mins to check things today before dark and this may make me stupid but where is c2 on the pcm ? Is it the second connector from the left ? It was getting dark so I couldn't see anything labeled c2. I have found some wiring diagrams for an 07 but I'm not sure I'm reading them correctly. Where some of the wires end it says where but some just have numbers and doesn't say what it is. Very confusing to me
I ohmed c2 pin 7 to coil connection and it was ok, had 0 resistance. Anyone know how the pcm is grounded ? I found 1 ground from the case to fender , is that it ?
Ah ha ! When I tested the old coil and had no spark from #3 I replaced the coil and it worked for an hour then same no spark. I THEN replaced the wire and plug ! I have since gotten a new coil again but I'm afraid to put it in and have the same issue. I forsee a problem trying to return another coil for replacement at the parts store. Should I just say f__k it and try it since I replaced the wire and plug ? The old wire and plug dawned on me today as I was doing some testing. They were the only common things to both old and new coil. I checked pretty much everything except driving down the road to see if it's a loose wire but that's hard to test. Lol
Vman should change his name to THEEman. I tested everything humanly possible and it all checked ok so I put the new coil in with new wires and plugs and all is good so far. Idle and test drive a success. Thank you for the diagrams and me being able to bounce things off of a knowledgeable someone. Happy new year to ya from the east coast ! If something happens with this is the near future I'll be back.![]()
Outstanding! I'm glad everything is working out for you brother, and happy new year from the snow covered north west.
Been out today testing out my trutracs and playing in the snow so glad to hear you got your rig back on the road too.
I'm having the same issue with mine. And I've replaced everything even the pcm coil & wires and plugs but still no spark on 3 & 6 could you maybe help me out
