New oil filter housing, oil pressure issues
cjk
America
2016 JKU
Recently replaced oil filter housing/cooler with new aluminum one that come with new sensors.
Now randomly the oil light pops up on the dash and the go to menu to check the oil pressure, it reads 0. It also seems to only happen going up hills.
Everything seems to be running smooth with no odd noises, oil level is good.
After stoping, restart and everything is good . Running 45PSI running and 24/25 idling.
Have went for 1.5 hours and have no issues and on the way back this happened 3 different times, each time going up hill
Have cleaned out the oil pan to make sure it's nothing in the oil.
Was wondering if it could be problems with the sensors that come with the new oil filter housing. Does any one have any ideas or suggestions?
Thank
I believe someone else had a similar issue after changing the oil housing and came to realize there were two different filters depending on year. I believe this was for a Dorman style.
2016 JKU
YEP JEEPS DONT LIKE CHINA JUNK PARTS
GET REAL JEEP SENSOR
Reactions: Evan
