I'm trying to make this cat fit on my 3.6 pentastar. Anyone put one on their JK?
The mounting flange is 1.5mm thicker than stock, so it wont seal properly to the exhaust manifold. The mounting bracket has to be tightened last, because it's made for a thinner flange.
How did you fix it, if you've got this cat on your JK?
I've tried the JB Weld extreme heat.. not the putty.
Nothing seals this catalytic converter to my engine.
1.5mm is 4.2 gaskets thick. I'm gonna cut 4 and mount the bracket. Maybe it will work, maybe it wont. I'll keep yall in the loop.
If this doesnt work, and none of yall have a good suggestion, I'm going back to a mopar cat.
