Limp mode issue on 2015 JKU
Kidds Autos
Gadsden
New member looking for help. I bought a 2015 JKU lifted with a bad rear end and missing front drive shaft. Jeep had been sitting with no top for a few months at least. I put junkyard rear ended and front drive shaft, same gear ratio from factory so I was told. Jeep goes into limp mode with incorrect gear ratios. I can unplug rear abs sensor and drives perfect without limp mode. Any help is greatly appreciated????
Does the rear axle have a locker and your Jeep is a automatic?
Reactions: vaffanculo
This is the problem. Whatever rear end you installed does not match what the ECM originally learned. If you don't have Jscan, you need to hook it up and see what the ECM is set for versus what is installed with respect to the gearing.
I’ll check
You can check to see what gears came in the Jeep from the Factory here.
Reactions: Danarch
Sent the Jeep to the dealership to get it reflashed, they said everything matched and they THINK it’s in the transmission! But if that’s the case why does it shift perfect with the abs sensor unplugged
I sent it to Jeep dealer to get the gears and all checked and or get it flashed. They said they THINK it’s in the transmission after keeping it for two day. 🤷‍♂️
