Ok, so I purchased a used 2015 2dr jk, it has a lift on it. After research I've com to the conclusion, well according to the numbers on the coil springs, that it's a pro comp 2.5 to 3" lift. With that being said, I noticed the other day that my Rear driver's side spring had shifted about 3" towards the rear at the top. Put the Jeep on a lift today, and every one of the springs have a lot of up and down play in them, so much that I could have removed the rears without taking anything loose. So my question is, will coil spring spacers fix this issue? If so, what size should I buy? Would I need shock extenders as well? Thanks in advance for your help.
